Helo,
have this laptop that got used on refurbished market
that i like very much but showing age slowly
it function well with devuan,
would have two minor complaint
1. the battery bridging does not function properly (that may be an issue of the aftermarket "external" battery), hence when the first battery depletes, the laptop shut down.
2. in case of such an event, after restarting the laptop,
the touchpad and pointing stick is no longer recognized (bit odd).
the "solution" is to boot into windows 10 and then reboot, again into linux/devuan, and the touchpad/touching stick is bacck.
maybe you know of more modern solution to the second issue,
thank you very much.
this is xinput with the touchpad and stick function
xinput
ERROR: ld.so: object '/usr/lib/x86_64-linux-gnu/libgtk3-nocsd.so.0' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ SynPS/2 Synaptics TouchPad id=11 [slave pointer (2)]
⎜ ↳ TPPS/2 IBM TrackPoint id=12 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Video Bus id=6 [slave keyboard (3)]
↳ Power Button id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Sleep Button id=9 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=10 [slave keyboard (3)]
↳ ThinkPad Extra Buttons id=13 [slave keyboard (3)]
↳ BRLTTY 6.9.1 Linux Screen Driver Keyboard id=14 [slave keyboard (3)with the nonfunctional trackpad/touching stick it goes only until 10 or 11 or so, not showing SynPS/2 Synaptics TouchPad and TPPS/2 IBM Trackpoint.
this had been described on other forum, but have not found a solution yet, besides the incursion of booting into windows first.
