#1 Today 07:04:40
pcalvert
Refracta Installer - possible bug found
It looks like I found bug in Refracta Installer. It appears that Refracta Installer may look for an ext2/ext3/ext4 file system, and if it doesn't find one, it assumes that the partition has not been formatted. I also tested the CLI version of Refracta Installer, and the behavior was the same.
The system and home partitions had been pre-formatted as follows:
# mkfs.nilfs2 /dev/sdc1
# mkfs.nilfs2 /dev/sdc3
I also did a final, quick test. I formatted /dev/sdc1 as ext2 to see if the installer would try to force me to format again, and it did not.
Refracta Installer screenshot 1:
Refracta Installer screenshot 2:
Refracta Installer screenshot 3:
Refracta Installer screenshot 4:
Refracta Installer screenshot 5:
Refracta Installer screenshot 6:
An idea just came to me about what might have caused this. Originally, I wasn't going to use encryption because this system is basically a test, and I'm not planning to use it for very long. However, when I saw the installer option to encrypt /home, I decided to check it. But now that I'm thinking about it, I'm not sure that this will work for a pre-formatted partition. The way the installer works, doesn't formatting the partition need to come after the encryption?
Another one is called Luxxle.
