#1 2026-09-24 11:04:49
steve_graham
[SOLVED] Upgrading kernel via apt
About a year ago, I got a Pi 4 and wrote the community-built Devuan image onto its SD card, booted, and everything worked perfectly.
I thought it was time to upgrade to a 7.x kernel and used apt to install the linux-image package and its dependencies. No problems. But when I rebooted, the system was still running the 6.x kernel.
On inspection, it seems that the original SD image has its kernel in the /boot vfat partition as kernel8, and the apt install didn't touch it.
So, clearly, I don't understand how the Pi boot process is supposed to work on a Devuan system. Is the executable in the /boot partition supposed to be a loader that boots the real kernel from the second, ext4 partition?
Or have I just done something stupid? (Quite possible.)
#2 2026-09-29 01:11:44
Re: [SOLVED] Upgrading kernel via apt
I got an answer from another party. You didn't do anything wrong. The raspberry pi has a hardware bootloader that boots the kernel binary directly. The package manager doesn't know anything about it and that's why you couldn't upgrade the kernel. I don't know if there's a way to manually upgrade it.
#3 2026-09-29 03:14:57
RedGreen925
Install Debian and convert it Deuvan then the kernel upgrade properly. With the Devuan images you are locked to the install image possibly forever. At least this is what I found when trying to do it with my Pi4. I made a couple of post on this some time back when I discovered this disturbing lack of upgrades and went the route I have mentioned. Just for the hell of it I booted it up for the first time in weeks.
zeus@9600k:~$ pi
Linux raspi 6.12.107+deb13-arm64 #1 SMP Debian 6.12.107-1 (2026-08-29) aarch64
Devuan  GNU/Linux 6 (excalibur)
Filesystem      Size  Used Avail Use% Mounted on
/dev/sda2       117G  1.6G  115G   2% /
/dev/sda1       500M  157M  344M  32% /boot/firmware
== SYSTEM
Processor:   Cortex-A72 @ 1500MHz 45°C
Online:      0-3
Memory:      7.6G 359M
Wired:       eth0 UP 192.168.0.116
Uptime:      00:05:06 up 1 min, 0 users, load average: 0.24, 0.13, 0.05
Last login: Tue Sep  8 11:15:35 2026 from 192.168.0.101
The kernels available.
zeus@raspi:~$ acp policy linux-image-arm64
linux-image-arm64:
  Installed: 6.12.107-1
  Candidate: 6.12.107-1
  Version table:
     7.1.8-1~bpo13+1 100
        100 http://gnlug.org/pub/devuan/merged excalibur-backports/main arm64 Packages
 *** 6.12.107-1 500
        500 http://gnlug.org/pub/devuan/merged excalibur-proposed-updates/main arm64 Packages
        500 http://gnlug.org/pub/devuan/merged excalibur-security/main arm64 Packages
        100 /var/lib/dpkg/status
     6.12.94-1 500
        500 http://gnlug.org/pub/devuan/merged excalibur/main arm64 Packages
Installing the version 7 from backports.
zeus@raspi:~$ su
Password:
root@raspi:/home/zeus# apt install -t excalibur-backports linux-image-arm64
Upgrading:
  linux-image-arm64
Installing dependencies:
  linux-base-7.1.8+deb13-arm64    linux-image-7.1.8+deb13-arm64
  linux-base-arm64                linux-modules-7.1.8+deb13-arm64
  linux-binary-7.1.8+deb13-arm64
Suggested packages:
  debian-kernel-handbook  linux-doc-7.1
Summary:
  Upgrading: 1, Installing: 5, Removing: 0, Not Upgrading: 32
  Download size: 101 MB
  Space needed: 282 MB / 123 GB available
Continue? [Y/n] y
Get:1 http://gnlug.org/pub/devuan/merged excalibur-backports/main arm64 linux-base-7.1.8+deb13-arm64 arm64 7.1.8-1~bpo13+1 [4,523 kB]
Get:2 http://gnlug.org/pub/devuan/merged excalibur-backports/main arm64 linux-binary-7.1.8+deb13-arm64 arm64 7.1.8-1~bpo13+1 [11.7 MB]
Get:3 http://gnlug.org/pub/devuan/merged excalibur-backports/main arm64 linux-modules-7.1.8+deb13-arm64 arm64 7.1.8-1~bpo13+1 [84.5 MB]
Get:4 http://gnlug.org/pub/devuan/merged excalibur-backports/main arm64 linux-image-7.1.8+deb13-arm64 arm64 7.1.8-1~bpo13+1 [1,892 B]
Get:5 http://gnlug.org/pub/devuan/merged excalibur-backports/main arm64 linux-base-arm64 arm64 7.1.8-1~bpo13+1 [1,240 B]
Get:6 http://gnlug.org/pub/devuan/merged excalibur-backports/main arm64 linux-image-arm64 arm64 7.1.8-1~bpo13+1 [1,664 B]
Fetched 101 MB in 3s (30.2 MB/s)
Selecting previously unselected package linux-base-7.1.8+deb13-arm64.
(Reading database ... 34649 files and directories currently installed.)
Preparing to unpack .../0-linux-base-7.1.8+deb13-arm64_7.1.8-1~bpo13+1_arm64.deb
Unpacking linux-base-7.1.8+deb13-arm64 (7.1.8-1~bpo13+1) ...
Selecting previously unselected package linux-binary-7.1.8+deb13-arm64.
Preparing to unpack .../1-linux-binary-7.1.8+deb13-arm64_7.1.8-1~bpo13+1_arm64.d
eb ...
Unpacking linux-binary-7.1.8+deb13-arm64 (7.1.8-1~bpo13+1) ...
Selecting previously unselected package linux-modules-7.1.8+deb13-arm64.
Preparing to unpack .../2-linux-modules-7.1.8+deb13-arm64_7.1.8-1~bpo13+1_arm64.
deb ...
Unpacking linux-modules-7.1.8+deb13-arm64 (7.1.8-1~bpo13+1) ...
Selecting previously unselected package linux-image-7.1.8+deb13-arm64.
Preparing to unpack .../3-linux-image-7.1.8+deb13-arm64_7.1.8-1~bpo13+1_arm64.de
b ...
Unpacking linux-image-7.1.8+deb13-arm64 (7.1.8-1~bpo13+1) ...
Selecting previously unselected package linux-base-arm64.
Preparing to unpack .../4-linux-base-arm64_7.1.8-1~bpo13+1_arm64.deb ...
Unpacking linux-base-arm64 (7.1.8-1~bpo13+1) ...
Preparing to unpack .../5-linux-image-arm64_7.1.8-1~bpo13+1_arm64.deb ...
Unpacking linux-image-arm64 (7.1.8-1~bpo13+1) over (6.12.107-1) ...
Setting up linux-base-7.1.8+deb13-arm64 (7.1.8-1~bpo13+1) ...
Setting up linux-modules-7.1.8+deb13-arm64 (7.1.8-1~bpo13+1) ...
Setting up linux-binary-7.1.8+deb13-arm64 (7.1.8-1~bpo13+1) ...
Setting up linux-base-arm64 (7.1.8-1~bpo13+1) ...
Setting up linux-image-7.1.8+deb13-arm64 (7.1.8-1~bpo13+1) ...
I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.12.107+deb13-arm64
I: /initrd.img.old is now a symlink to boot/initrd.img-6.12.107+deb13-arm64
I: /vmlinuz is now a symlink to boot/vmlinuz-7.1.8+deb13-arm64
I: /initrd.img is now a symlink to boot/initrd.img-7.1.8+deb13-arm64
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-7.1.8+deb13-arm64
Setting up linux-image-arm64 (7.1.8-1~bpo13+1) ...
root@raspi:/home/zeus# reboot
Broadcast message from root@raspi (pts/0) (Tue Sep 29 00:10:54 2026):
The system is going down for reboot NOW!
root@raspi:/home/zeus# Read from remote host raspi.lan: Connection reset by peer
Connection to raspi.lan closed.
client_loop: send disconnect: Broken pipe
And success in upgrading to the new version.
zeus@9600k:~$ pi
Linux raspi 7.1.8+deb13-arm64 #1 SMP PREEMPT Debian 7.1.8-1~bpo13+1 (2026-08-16) aarch64
/dev/sda2       117G  1.8G  115G   2% /
/dev/sda1       500M  235M  266M  47% /boot/firmware
== SYSTEM
Processor:   Cortex-A72 @ 1500MHz 54°C
Online:      0-3
Memory:      7.6G 380M
Uptime:      00:12:17 up 1 min, 0 users, load average: 0.90, 0.31, 0.11
Last login: Tue Sep 29 00:05:06 2026 from 192.168.0.101
So the solution to the problem to the original poster is to dump the Broken by design Devuan image and use a converted Debian install like I did and everything will work like it should with the normal Debian tools using Devuan sources.
#4 2026-09-29 09:47:57
steve_graham
Thank you. That's very useful.
#5 2026-09-29 12:56:03
@RedGreen925
Intresting.
Still don't have a RasPi, but sooner or later ... .
Assuming the conversion process to Devuan is similar to x86 computers:
Make Debian boot with sysv-init, then just dist-upgrade to Devuan.
Would this work?
Anything ARM specific to add?
I'm just curious.
#6 2026-09-29 15:31:50
RedGreen925
Would this work?
Am just checking through the install notes for that machine. Yes I followed the guide here after setting up the Debian.
https://www.devuan.org/os/documentation … libur.html
Nah nothing special in them notes just basic install programs wanted and some configuration options, one thing though if wanting to get rid of the annoying Welcome to Debian MOTD then this is what I changed it to.
zeus@9600k:~$ pi
Linux raspi 6.12.48+deb13-arm64 #1 SMP Debian 6.12.48-1 (2025-09-20) aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Nov  5 17:29:43 2025 from 192.168.0.101
Time for a dynamic message of the day getting sick of that.
https://unix.stackexchange.com/questions/246436/how-to-set-a-dynamic-message-of-the-day-motd-in-debian-jessie-8-2-for-ssh
https://github.com/ar51an/raspberrypi-motd
root@raspi:~# mv /etc/motd /etc/motd.old
root@raspi:~# cat /etc/update-motd.d/10-uname
uname -snrvm
root@raspi:~# nano /etc/update-motd.d/15-logo
root@raspi:~# chmod +x /etc/update-motd.d/15-logo
root@raspi:~# cat /etc/update-motd.d/15-logo
#!/bin/bash
echo
DISTRO=$(cat /etc/issue | cut -d " " -f 1)
RELEASE=$(lsb_release -a | grep "Description:" | cut -d " " -f 2-4)
echo "$DISTRO " "$RELEASE"
echo
root@raspi:~# nano /etc/update-motd.d/20-sysinfo
root@raspi:~# chmod +x /etc/update-motd.d/20-sysinfo
root@raspi:~# cat /etc/update-motd.d/20-sysinfo
#!/bin/bash
# variables
cpu=$(</sys/class/thermal/thermal_zone0/temp)
CPUT=$((cpu/1000))
CPU=`lscpu | grep "Model name" | sed -n 1p | sed 's/Model name://g' | sed -r '1s/\s+//g'`
CPUM=`lscpu | grep "CPU max MHz" | sed -n 1p | sed 's/CPU max MHz://g' | sed -r '1s/\s+//g' | sed 's/.0000//g'`
NETWORK=$(ip -o -4 -br a | grep -v '^lo'| sed 's/^/ /' | sed 's/\/..//' | sed -r '1s/\s+/ /g' | sed -r '2s/\s+/ /g')
ETH=`echo -e Wired:`
WLAN=`echo -e Wireless:`
USB=`echo -e Tether:`
# display
df -h | egrep '(Filesystem)|(/dev/mmc)|(/dev/root)|(/dev/sd)|(/dev/nvme)|(Media)'
#df -h | egrep '(Filesystem)|(/dev/mmc)|(/dev/root)|(/dev/sd)|(/dev/nvme)'
echo
echo -e "== SYSTEM"
if [[ -f "/sys/devices/system/cpu/present" ]]; then
	echo -en "Processor:  " $CPU; echo -en " @ $CPUM"; echo -e "MHz $CPUT°C";
else
	echo -e "Temperature:" $CPUT°C;
	echo -e "Cores:      " $(cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq);
fi
echo -e "Online:     " $(lscpu | grep -w "On-line CPU(s) list:" | sed "s/On-line CPU(s) list:/ /g" | sed -e "s/\s\{3,\}//g")
echo -e "Memory:     " $(free -h | sed 's/i//g' | sed 's/Mem://g' | awk '{print $1" "$2}' | sed -n 'n;p')
echo -e "$NETWORK" | sed "s/^[ \t]*//" | sed "s/eth0/$ETH       eth0/g" | sed "s/eth1/$ETH       eth1/g" | sed "s/wlan0/$WLAN    wlan0/g" | sed "s/wlan1/$WLAN    wlan1/g" | sed "s/usb0/$USB      usb0/g"
echo -e "Uptime:     " $(uptime)
echo
zeus@9600k:~$ pi
/dev/sda2       117G  1.7G  115G   2% /
/dev/sda1       500M  152M  348M  31% /boot/firmware
/dev/sdb1       3.6T  3.1T  522G  86% /home/zeus/rtorrent
== SYSTEM
Processor:   Cortex-A72 @ 1500MHz 57°C
Online:      0-3
Memory:      7.6G 492M
Uptime:      03:15:19 up 16:20, 1 user, load average: 0.21, 0.15, 0.12
Last login: Fri Nov  7 03:13:26 2025 from 192.168.0.101
Much better tells you exactly what it is and some information on the machine.
#7 2026-09-29 19:47:23
Thanks for the reply and checking your install notes.
It is intresting to see that debian / devuan systems are working equally over cpu boundaries.
I never explored that, but always feared that there are substantial differences.
Nice motd scripts, I'll borrow them smile
#8 2026-09-29 23:58:08
RedGreen925
You are welcome. It really is nothing surprising they basically use the same packages. With the Devuan modifying some to remove the systemd garbage they have. The same is true for all GNU/Linux distributions the programs are the same the only real difference is the packaging methods used, though some have their own specific patches to those programs. You may as well take them MOTD it is why I posted it and as seen in that posting I always include the URL where I borrowed them from myself.
#9 2026-10-04 19:30:09
... a hardware bootloader that boots the kernel binary directly. The package manager doesn't know anything about it and that's why you couldn't upgrade the kernel. I don't know if there's a way to manually upgrade it.
I have managed to update/upgrade my RPi 3b+ to [chimaera] via apt but, just like [steve_graham], the thingy is still using the kernel it was using before.
rpi3b:~$ cat /etc/os-release
PRETTY_NAME="Devuan GNU/Linux 4 (chimaera)"
NAME="Devuan GNU/Linux"
VERSION_ID="4"
VERSION="4 (chimaera)"
VERSION_CODENAME="chimaera"
rpi3b:~$
rpi3b:~$ uname -asrm
Linux rpi3b 4.16.14-v8+ #1 SMP PREEMPT Tue Jun 5 18:50:10 CEST 2018 aarch64 GNU/Linux
rpi3b:~$
The [/boot] directory has three kernel images ...
rpi3b:/boot# ls | grep ker
kernel.img        <--- to be removed?
kernel7.img       <--- to be removed?
kernel8.img
pi3b:/boot#
... and [/boot/config.txt] uses the [kernel=8] option:
rpi3b:~$ cat /boot/config.txt | grep kernel=
kernel=kernel8.img
rpi3b:~$
@fsmithred
Looking around I found a recent paper [*.pdf] published by the people at [raspberrypi.com]: Updating Raspberry Pi firmware.
The interesting (?) part is in p. 7:
raspberry.com wrote:
Updating only the firmware
In these circumstances, and possibly others not mentioned here, you will need to update the firmware files in the distribution manually.
The basic principle is to copy the required start and fixup files from this zip file and replace those of the same name in the destination OS image. The exact process will depend on how the OS has been set up, but the following gives an example of how it should be done for a Raspberry Pi OS image:
• Extract or open the zip file so that you can access the required files
• Open the boot folder in the destination OS image (this can be on an SD card or a disk-based copy)
• Determine which start.elf and fixup.dat files are present in the destination OS image
• Copy those files from the zip file to the destination OS image
The image should now be ready to use on the latest Raspberry Pi Ltd hardware
Is this the information you would need to manually upgrade the RPi kernel manually or maybe this would not work in Devuan?
#10 2026-10-06 14:31:56
steve_graham
I manually updated the kernel in the Devuan Arm image. Now that I know what works, I'll write a script to do it. Ideally, the script would run automatically after apt installs a kernel, but I don't know how to do that yet.
Here are the steps:
1. use apt to install linux-base-x.y.z+deb??-arm64, linux-binary-x.y.z+deb??-arm64 & linux-modules-x.y.z+deb??-arm64
2. copy /lib/modules/x.y.z+deb??-arm64/vmlinuz to kernel8.img in the /boot partition
3. copy /lib/modules/x.y.z+deb??-arm64/config to config-x.y.z+deb??-arm64 in the /boot partition
4. run "update-initramfs -c -k x.y.z+deb??-arm64"
(Step 3 allows update-initramfs to check the config, otherwise it complains. Step 4 creates initrd.img-x.y.z+deb??-arm64 in /boot, but also copies it to initrd.gz which I think will be what the bootloader looks for.)
This created a bootable system. In my case, the x.y.z from "uname -r" is 7.2.6+deb13-arm64, and lsmod shows a long list.
#11 2026-10-10 12:42:09
steve_graham
Actually, don't do the above. It booted on the Pi 4 I use as a security camera server, but when I did it on my other Pi 4, used as a media device, I found that neither analog sound nor IR control worked. Even when I added snd-bcm2835 to /etc/modules, no soundcards showed up.
Also the external drive, formatted to ext4, didn't automount from /etc/fstab although I could manually mount it.
I kept backups of kernel8 and initrd.img from /boot and was able to revert just by copying them back.
