#1 2026-08-27 06:08:36
Problem with qemu
I have a guest that cannot access the internet I have, because I forgot to install dhcpcd.
But... I cannot get inside of the qcow2 with an installation nor can I install anything remotely needed to get it working.
So I wish to ask,
Is there a way to forcibly give internet to a vm? In either virt-manager, qemu, or virtualbox.
#2 2026-08-27 16:35:27
Re: Problem with qemu
Install libguestfs-tools and mount the qcow2 image as root:
# guestmount -a devuan.qcow2 -i /mnt
Now you can copy dhcpcd_*.deb and its dependencies to /mnt/root or wherever you want within /mnt, and safely remove the disk afterwards:
# guestunmount /mnt
Boot the image and install the packages via:
# dpkg -i /root/*.deb
You can also configure /etc/network/interfaces if you wish:
auto eth0
allow-hotplug eth0
iface eth0 inet dhcp
https://dev1galaxy.org/viewtopic.php?id=6283
#3 2026-08-27 17:13:24
rbit
Another option...
With qemu, use -nic user option, and set up networking as follows
ip address add 10.0.2.15/24 dev eth0
ip link set dev eth0 up
ip route add 10.0.2.0/24 dev eth0
ip route add default via 10.0.2.2 dev eth0
Also, your /etc/resolv.conf should contain
nameserver 10.0.2.3
From there, you should be able to apt install dhcpcd-base or whatever package(s) you want.
With virtualbox, you could change the network to bridged, and set up static networking as though it were a physical device on your LAN.  For example, if your LAN uses 192.168.1.0/24 with a gateway of 192.168.1.1 (I think this is a common default setup), you could do something like this
ip address add 192.168.1.20/24 dev eth0
ip route add 192.168.1.0/24 dev eth0
ip route add default via 192.168.1.1 dev eth0
Obviously, you'd want to use an address not in use by another device.  That was just an example.
#4 2026-09-12 14:50:03
I don't remember exactly what I did, but I figured out how to get the package installed in the qcow2 anyhow.
so no issue here.
Another words getting dhcpcd installed.
