#1 2026-08-26 15:12:06
trabant-asb
[SOLVED] Xorg error on Devuan freia
Hey,
I am successfully running freia arm64 on a Raspberry Pi platform using the generic kernel (Linux aws 7.1.8+deb14.1-arm64 #1 SMP PREEMPT Debian 7.1.8-2 (2026-08-15) aarch64 GNU/Linux) and Xorg (xorg-server 2:21.1.24-1devuan1).
Accidentally, the modesetting driver runs into problems showing the following error message...
(EE) modeset(0): Failed to make 1280x984x32bpp GBM bo
...over and over a hundred times, showing different resolutions, none of them is supported by my monitor nor specified in the xorg.conf file. The exactly same configuration (hardware as well as configuration files) runs perfectly fine on Chimaera.
While this error message keeps repeating, windows disappear from the screen so only the background remains there or remainders of scrambled window parts are visible where they shouldn't be *but* if I go with the cursor over where that window should be I see the mouse cursor changing where links would be i.e. in the web browser.
Before the error messages start, the Xorg.log looks fine w/o errors...
alex@aws:~/log:(15)> cat Xorg.0.log
[    11.490]
X.Org X Server 1.21.1.24
[    11.491] Current Operating System: Linux aws 7.1.8+deb14.1-arm64 #1 SMP PREEMPT Debian 7.1.8-2 (2026-08-15) aarch64
[    11.491] Kernel command line: video=HDMI-A-1:1280x1024M@60 dma.dmachans=0x37f5 bcm2709.boardrev=0xc03115 bcm2709.serial=0x3c446b80 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=42 bcm2709.disk_led_active_low=0 smsc95xx.macaddr=E4:5F:01:A8:4B:9E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty0 root=PARTUUID=8cddaba2-889f-49b9-8c3f-084fe4956fe8 rw fsck.repair=yes net.ifnames=0  rootwait quiet logo.nologo
[    11.491] xorg-server 2:21.1.24-1devuan1 (https://www.devuan.org/os/community)
[    11.491] Current version of pixman: 0.46.4
[    11.491] 	Before reporting problems, check http://wiki.x.org
[    11.491] Markers: (--) probed, (**) from config file, (==) default setting,
[    11.491] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Aug 26 16:22:24 2026
[    11.509] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    11.509] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    11.521] (==) ServerLayout "Layout0"
[    11.521] (**) |-->Screen "Screen0" (0)
[    11.521] (**) |   |-->Monitor "AL1716"
[    11.525] (**) |   |-->Device "DRM"
[    11.525] (**) Allowing byte-swapped clients
[    11.525] (==) Automatically adding devices
[    11.525] (==) Automatically enabling devices
[    11.525] (==) Automatically adding GPU devices
[    11.525] (==) Automatically binding GPU devices
[    11.527] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    11.542] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    11.542] 	Entry deleted from font path.
[    11.569] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[    11.569] (==) ModulePath set to "/usr/lib/xorg/modules"
[    11.569] (II) The server relies on udev to provide the list of input devices.
[    11.569] (II) Loader magic: 0xaaaab4db0ea0
[    11.569] (II) Module ABI versions:
[    11.569] 	X.Org ANSI C Emulation: 0.4
[    11.569] 	X.Org Video Driver: 25.2
[    11.569] 	X.Org XInput driver : 24.4
[    11.569] 	X.Org Server Extension : 10.0
[    11.569] (++) using VT number 7
[    11.569] (II) seat-libseat: libseat integration requires -keeptty and -keeptty was not provided, disabling libseat integration
[    11.570] (II) xfree86: Adding drm device (/dev/dri/card1)
[    11.570] (II) Platform probe for /sys/devices/platform/gpu/drm/card1
[    11.587] (II) xfree86: Adding drm device (/dev/dri/card0)
[    11.587] (II) Platform probe for /sys/devices/platform/scb-bus@fc000000/fec00000.gpu/drm/card0
[    11.588] (II) no primary bus or device found
[    11.588] 	falling back to /sys/devices/platform/gpu/drm/card1
[    11.588] (II) LoadModule: "glx"
[    11.603] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    11.688] (II) Module glx: vendor="X.Org Foundation"
[    11.688] 	compiled for 1.21.1.24, module version = 1.0.0
[    11.688] 	ABI class: X.Org Server Extension, version 10.0
[    11.688] (II) LoadModule: "modesetting"
[    11.689] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    11.698] (II) Module modesetting: vendor="X.Org Foundation"
[    11.698] 	compiled for 1.21.1.24, module version = 1.21.1
[    11.698] 	Module class: X.Org Video Driver
[    11.698] 	ABI class: X.Org Video Driver, version 25.2
[    11.698] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    11.767] (II) modeset(0): using drv /dev/dri/card1
[    11.768] (**) modeset(0): Depth 24, (--) framebuffer bpp 32
[    11.768] (**) modeset(0): Option "AccelMethod" "glamor"
[    11.768] (==) modeset(0): RGB weight 888
[    11.768] (==) modeset(0): Default visual is TrueColor
[    11.768] (II) Loading sub module "glamoregl"
[    11.768] (II) LoadModule: "glamoregl"
[    11.769] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    11.820] (II) Module glamoregl: vendor="X.Org Foundation"
[    11.820] 	compiled for 1.21.1.24, module version = 1.0.1
[    11.820] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    14.462] (II) modeset(0): glamor: Using OpenGL 3.1 context.
[    14.473] (II) modeset(0): glamor X acceleration enabled on V3D 4.2.14.0
[    14.473] (II) modeset(0): glamor initialized
[    14.473] (==) modeset(0): VariableRefresh: disabled
[    14.473] (==) modeset(0): AsyncFlipSecondaries: disabled
[    14.487] (II) modeset(0): Output HDMI-1 using monitor section AL1716
[    14.490] (II) modeset(0): Output HDMI-2 has no monitor section
[    14.559] (II) modeset(0): EDID for output HDMI-1
[    14.559] (II) modeset(0): Manufacturer: ACR  Model: 6b4  Serial#: 6704
[    14.559] (II) modeset(0): Year: 2005  Week: 39
[    14.559] (II) modeset(0): EDID Version: 1.3
[    14.559] (II) modeset(0): Digital Display Input
[    14.559] (II) modeset(0): Max Image Size [cm]: horiz.: 34  vert.: 27
[    14.559] (II) modeset(0): Gamma: 2.20
[    14.559] (II) modeset(0): DPMS capabilities: Suspend Off
[    14.559] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    14.559] (II) modeset(0): Default color space is primary color space
[    14.559] (II) modeset(0): First detailed timing is preferred mode
[    14.559] (II) modeset(0): redX: 0.640 redY: 0.340   greenX: 0.290 greenY: 0.610
[    14.559] (II) modeset(0): blueX: 0.140 blueY: 0.000   whiteX: 0.313 whiteY: 0.329
[    14.560] (II) modeset(0): Supported established timings:
[    14.560] (II) modeset(0): 720x400@70Hz
[    14.560] (II) modeset(0): 640x480@60Hz
[    14.560] (II) modeset(0): 640x480@72Hz
[    14.560] (II) modeset(0): 640x480@75Hz
[    14.560] (II) modeset(0): 800x600@56Hz
[    14.560] (II) modeset(0): 800x600@60Hz
[    14.560] (II) modeset(0): 800x600@72Hz
[    14.560] (II) modeset(0): 800x600@75Hz
[    14.560] (II) modeset(0): 1024x768@60Hz
[    14.560] (II) modeset(0): 1024x768@70Hz
[    14.560] (II) modeset(0): 1024x768@75Hz
[    14.560] (II) modeset(0): 1280x1024@75Hz
[    14.560] (II) modeset(0): Manufacturer's mask: 0
[    14.560] (II) modeset(0): Supported standard timings:
[    14.560] (II) modeset(0): #0: hsize: 832  vsize 624  refresh: 75  vid: 20297
[    14.560] (II) modeset(0): #1: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[    14.560] (II) modeset(0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    14.560] (II) modeset(0): Supported detailed timing:
[    14.560] (II) modeset(0): clock: 108.0 MHz   Image Size:  338 x 270 mm
[    14.560] (II) modeset(0): h_active: 1280  h_sync: 1328  h_sync_end 1440 h_blank_end 1688 h_border: 0
[    14.560] (II) modeset(0): v_active: 1024  v_sync: 1025  v_sync_end 1028 v_blanking: 1066 v_border: 0
[    14.560] (II) modeset(0): Ranges: V min: 56 V max: 75 Hz, H min: 31 H max: 83 kHz, PixClock max 145 MHz
[    14.560] (II) modeset(0): Monitor name: AL1716
[    14.560] (II) modeset(0):  ACER
[    14.560] (II) modeset(0): EDID (in hex):
[    14.560] (II) modeset(0): 	00ffffffffffff000472b406301a0000
[    14.560] (II) modeset(0): 	270f010380221b786ec5c5a3574a9c23
[    14.560] (II) modeset(0): 	005054afcf00494f714f818001010101
[    14.560] (II) modeset(0): 	010101010101302a009851002a403070
[    14.560] (II) modeset(0): 	1300520e1100001e000000fd00384b1f
[    14.561] (II) modeset(0): 	530e000a202020202020000000fc0041
[    14.561] (II) modeset(0): 	4c313731360a202020202020000000fe
[    14.561] (II) modeset(0): 	00414345520a2020202020202020009f
[    14.561] (II) modeset(0): Printing probed modes for output HDMI-1
[    14.561] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz UeP)
[    14.561] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    14.561] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    14.561] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    14.561] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    14.561] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    14.561] (II) modeset(0): Modeline "832x624"x75.0   53.21  832 872 960 1088  624 625 628 652 -hsync +vsync (48.9 kHz)
[    14.561] (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    14.561] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    14.561] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    14.561] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    14.561] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    14.561] (II) modeset(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    14.562] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    14.562] (II) modeset(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    14.562] (II) modeset(0): EDID for output HDMI-2
[    14.562] (II) modeset(0): Output HDMI-1 connected
[    14.562] (II) modeset(0): Output HDMI-2 disconnected
[    14.562] (II) modeset(0): Using user preference for initial modes
[    14.562] (II) modeset(0): Output HDMI-1 using initial mode 1280x1024 +0+0
[    14.562] (**) modeset(0): Using gamma correction (2.2, 2.2, 2.2)
[    14.562] (**) modeset(0): Display dimensions: (340, 270) mm
[    14.562] (**) modeset(0): DPI set to (95, 96)
[    14.562] (II) Loading sub module "fb"
[    14.562] (II) LoadModule: "fb"
[    14.562] (II) Module "fb" already built-in
[    14.783] (**) modeset(0): Option "BackingStore" "false"
[    14.783] (**) modeset(0): Backing store disabled
[    14.783] (==) modeset(0): Silken mouse enabled
[    14.982] (II) modeset(0): Output HDMI-1 wants gamma correction (2.2, 2.2, 2.2)
[    14.982] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    14.983] (II) modeset(0): Output HDMI-1 wants gamma correction (2.2, 2.2, 2.2)
[    14.984] (**) modeset(0): DPMS enabled
[    14.984] (II) modeset(0): [DRI2] Setup complete
[    14.984] (II) modeset(0): [DRI2]   DRI driver: vc4
[    14.984] (II) modeset(0): [DRI2]   VDPAU driver: vc4
[    14.984] (II) Initializing extension Generic Event Extension
[    14.985] (II) Initializing extension SHAPE
[    14.986] (II) Initializing extension MIT-SHM
[    14.986] (II) Initializing extension XInputExtension
[    14.992] (II) Initializing extension XTEST
[    14.993] (II) Initializing extension BIG-REQUESTS
[    14.993] (II) Initializing extension SYNC
[    14.994] (II) Initializing extension XKEYBOARD
[    14.996] (II) Initializing extension XC-MISC
[    14.997] (II) Initializing extension SECURITY
[    14.997] (II) Initializing extension XFIXES
[    14.998] (II) Initializing extension RENDER
[    14.998] (II) Initializing extension RANDR
[    15.000] (II) Initializing extension COMPOSITE
[    15.000] (II) Initializing extension DAMAGE
[    15.001] (II) Initializing extension MIT-SCREEN-SAVER
[    15.001] (II) Initializing extension DOUBLE-BUFFER
[    15.002] (II) Initializing extension RECORD
[    15.003] (II) Initializing extension DPMS
[    15.003] (II) Initializing extension Present
[    15.004] (II) Initializing extension DRI3
[    15.005] (II) Initializing extension X-Resource
[    15.005] (II) Initializing extension XVideo
[    15.006] (II) Initializing extension XVideo-MotionCompensation
[    15.006] (II) Initializing extension SELinux
[    15.006] (II) SELinux: Disabled on system
[    15.006] (II) Initializing extension GLX
[    15.073] (II) AIGLX: Loaded and initialized vc4
[    15.073] (II) GLX: Initialized DRI2 GL provider for screen 0
[    15.073] (II) Initializing extension XFree86-VidModeExtension
[    15.073] (II) Initializing extension XFree86-DGA
[    15.074] (II) Initializing extension XFree86-DRI
[    15.074] (II) Initializing extension DRI2
[    15.081] (II) modeset(0): Damage tracking initialized
[    15.081] (II) modeset(0): Setting screen physical size to 340 x 270
[    15.279] (II) config/udev: Adding input device HID 05f3:0007 (/dev/input/event0)
[    15.279] (**) HID 05f3:0007: Applying InputClass "libinput keyboard catchall"
[    15.279] (II) LoadModule: "libinput"
[    15.279] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    15.303] (II) Module libinput: vendor="X.Org Foundation"
[    15.303] 	compiled for 1.21.1.21, module version = 1.5.0
[    15.303] 	Module class: X.Org XInput Driver
[    15.303] 	ABI class: X.Org XInput driver, version 24.4
[    15.303] (II) Using input driver 'libinput' for 'HID 05f3:0007'
[    15.304] (**) HID 05f3:0007: always reports core events
[    15.304] (**) Option "Device" "/dev/input/event0"
[    15.354] (II) event0  - HID 05f3:0007: is tagged by udev as: Keyboard
[    15.354] (II) event0  - HID 05f3:0007: device is a keyboard
[    15.354] (II) event0  - HID 05f3:0007: device removed
[    15.372] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.0/0003:05F3:0007.0001/input/input0/event0"
[    15.372] (II) XINPUT: Adding extended input device "HID 05f3:0007" (type: KEYBOARD, id 6)
[    15.372] (**) Option "xkb_model" "pc105"
[    15.372] (**) Option "xkb_layout" "us"
[    15.377] (II) event0  - HID 05f3:0007: is tagged by udev as: Keyboard
[    15.378] (II) event0  - HID 05f3:0007: device is a keyboard
[    15.380] (II) config/udev: Adding input device HID 05f3:0007 System Control (/dev/input/event1)
[    15.380] (**) HID 05f3:0007 System Control: Applying InputClass "libinput keyboard catchall"
[    15.381] (II) Using input driver 'libinput' for 'HID 05f3:0007 System Control'
[    15.381] (**) HID 05f3:0007 System Control: always reports core events
[    15.381] (**) Option "Device" "/dev/input/event1"
[    15.385] (II) event1  - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[    15.385] (II) event1  - HID 05f3:0007 System Control: device is a keyboard
[    15.386] (II) event1  - HID 05f3:0007 System Control: device removed
[    15.392] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.1/0003:05F3:0007.0002/input/input1/event1"
[    15.392] (II) XINPUT: Adding extended input device "HID 05f3:0007 System Control" (type: KEYBOARD, id 7)
[    15.392] (**) Option "xkb_model" "pc105"
[    15.392] (**) Option "xkb_layout" "us"
[    15.397] (II) event1  - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[    15.397] (II) event1  - HID 05f3:0007 System Control: device is a keyboard
[    15.400] (II) config/udev: Adding input device HID 05f3:0007 Consumer Control (/dev/input/event2)
[    15.400] (**) HID 05f3:0007 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    15.400] (II) Using input driver 'libinput' for 'HID 05f3:0007 Consumer Control'
[    15.400] (**) HID 05f3:0007 Consumer Control: always reports core events
[    15.400] (**) Option "Device" "/dev/input/event2"
[    15.404] (II) event2  - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[    15.405] (II) event2  - HID 05f3:0007 Consumer Control: device is a keyboard
[    15.405] (II) event2  - HID 05f3:0007 Consumer Control: device removed
[    15.428] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.1/0003:05F3:0007.0002/input/input2/event2"
[    15.428] (II) XINPUT: Adding extended input device "HID 05f3:0007 Consumer Control" (type: KEYBOARD, id 8)
[    15.428] (**) Option "xkb_model" "pc105"
[    15.428] (**) Option "xkb_layout" "us"
[    15.433] (II) event2  - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[    15.433] (II) event2  - HID 05f3:0007 Consumer Control: device is a keyboard
[    15.436] (II) config/udev: Adding input device Microsoft Microsoft Trackball Explorer® (/dev/input/event3)
[    15.436] (**) Microsoft Microsoft Trackball Explorer®: Applying InputClass "libinput pointer catchall"
[    15.436] (II) Using input driver 'libinput' for 'Microsoft Microsoft Trackball Explorer®'
[    15.436] (**) Microsoft Microsoft Trackball Explorer®: always reports core events
[    15.436] (**) Option "Device" "/dev/input/event3"
[    15.497] (II) event3  - Microsoft Microsoft Trackball Explorer®: is tagged by udev as: Mouse Trackball
[    15.498] (II) event3  - Microsoft Microsoft Trackball Explorer®: device is a pointer
[    15.498] (II) event3  - Microsoft Microsoft Trackball Explorer®: device removed
[    15.512] (II) libinput: Microsoft Microsoft Trackball Explorer®: Step value 0 was provided, libinput Fallback acceleration function is used.
[    15.512] (**) Option "ButtonMapping" "8 9 3 4 5 6 7 1 2 10"
[    15.512] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:045E:0024.0003/input/input3/event3"
[    15.512] (II) XINPUT: Adding extended input device "Microsoft Microsoft Trackball Explorer®" (type: MOUSE, id 9)
[    15.513] (**) Option "AccelerationScheme" "none"
[    15.513] (**) Microsoft Microsoft Trackball Explorer®: (accel) selected scheme none/0
[    15.513] (**) Microsoft Microsoft Trackball Explorer®: (accel) acceleration factor: 2.000
[    15.513] (**) Microsoft Microsoft Trackball Explorer®: (accel) acceleration threshold: 4
[    15.572] (II) event3  - Microsoft Microsoft Trackball Explorer®: is tagged by udev as: Mouse Trackball
[    15.572] (II) event3  - Microsoft Microsoft Trackball Explorer®: device is a pointer
[    15.575] (II) config/udev: Adding input device Microsoft Microsoft Trackball Explorer® (/dev/input/mouse0)
[    15.575] (II) No input driver specified, ignoring this device.
[    15.575] (II) This device may have been added with another device file.
[    15.577] (II) config/udev: Adding input device vc4-hdmi-0 (/dev/input/event4)
[    15.578] (**) vc4-hdmi-0: Ignoring device from InputClass "disable touch stick"
[    15.579] (II) config/udev: Adding input device vc4-hdmi-0 HDMI Jack (/dev/input/event5)
[    15.579] (**) vc4-hdmi-0 HDMI Jack: Ignoring device from InputClass "disable touch stick"
[    15.580] (II) config/udev: Adding input device vc4-hdmi-1 (/dev/input/event6)
[    15.585] (**) vc4-hdmi-1: Ignoring device from InputClass "disable touch stick"
[    15.586] (II) config/udev: Adding input device vc4-hdmi-1 HDMI Jack (/dev/input/event7)
[    15.586] (**) vc4-hdmi-1 HDMI Jack: Ignoring device from InputClass "disable touch stick"
[    15.602] (II) modeset(0): Disabling kernel dirty updates, not required.
[    29.459] (II) modeset(0): EDID vendor "ACR", prod id 1716
[    29.460] (II) modeset(0): Using hsync ranges from config file
[    29.460] (II) modeset(0): Using vrefresh ranges from config file
[    29.460] (II) modeset(0): Printing DDC gathered Modelines:
[    29.460] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[    29.460] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    29.460] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    29.460] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    29.460] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    29.460] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    29.460] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    29.460] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    29.460] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    29.460] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    29.460] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    29.460] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    29.460] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    29.460] (II) modeset(0): Modeline "832x624"x75.0   53.20  832 872 960 1088  624 625 628 652 -hsync +vsync (48.9 kHz e)
[    29.460] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   165.990] (EE) modeset(0): Failed to make 1280x984x32bpp GBM bo
[   466.070] (EE) modeset(0): Failed to make 1280x984x32bpp GBM bo
[   466.948] (EE) modeset(0): Failed to make 1280x984x32bpp GBM bo
[   467.042] (EE) modeset(0): Failed to make 1280x984x32bpp GBM bo
on so on.
Any ideas? I tried different desktop systems, however all based on gnome (that would be gnome 4, gnome-flashback and cinnamon. All out of the official repository, needless to say.
Greetings from Germany's north coast (Cuxhaven)
Alex
PS my xorg config file...
Section "Device"
    Identifier "DRM"
    Driver "modesetting"
    Option "Monitor-HDMI-1" "AL1716"
    Screen 0
EndSection
#Section "Extensions"
#    Option "XVideo" "Disable"
#EndSection
Section "ServerLayout"
    Identifier "Layout0"
    Screen "Screen0"
EndSection
Section "Screen"
    Identifier "Screen0"
    Monitor    "AL1716"
    Device     "DRM"
    DefaultDepth 24
    SubSection "Display"
       Depth 24
       Modes "1280x1024"
    EndSubSection
EndSection
Section "Monitor"
    Identifier "AL1716"
    ModelName "AL1716"
    VendorName "ACR"
    # Monitor Manufactured week 39 of 2005
    # EDID version 1.3
    # Digital Display
    DisplaySize 340 270
    Gamma 2.20
    Option "DPMS" "true"
    #Option "DefaultModes" "false"
    Horizsync 31-83
    VertRefresh 56-75
    # Maximum pixel clock is 140MHz
    #Not giving standard mode: 832x624, 75Hz
    #Not giving standard mode: 1152x864, 75Hz
    #Not giving standard mode: 1280x1024, 60Hz
    #Modeline   1280x1024x0.0 +hsync +vsync
EndSection
Section "InputClass"
    Identifier "disable touch stick"
    MatchProduct "vc4"
    Option "ignore" "on"
EndSection
    Identifier "libinput pointer catchall"
    MatchIsPointer "on"
    MatchDevicePath "/dev/input/event*"
    MatchProduct "Microsoft Trackball Explorer"
    Driver "libinput"
EndSection
    Identifier "libinput keyboard catchall"
    MatchIsKeyboard "on"
    Driver "libinput"
EndSection
#2 2026-08-26 22:26:26
Re: [SOLVED] Xorg error on Devuan freia
As per man xorg.conf you might possibly need to specify something for the 32bpp display option.
I've long lived without an explicit xorg.conf, and you might consider to try as well. I.e., move away your xorg.conf, or at least the sections other that InputClass.
Generally it appears that for your monitor, Xorg wants to fit a 32bpp display option into your preference specification of 1280x1024x24bpp and is unhappy with the outcome of that. Perhaps a hand made mode line for 1280x984; or perhaps a second display section with FbBpp 32 and a known mode; or perhaps a nomodeset boot parameter; will avoid the issue.
#3 2026-08-27 15:09:53
trabant-asb
I have tried my very best and went through the options you have provided, however I did not find a solution. Either my X server would not start at all (no screens available) when I hardcoded invalid resolutions or depths or when it did start, the problem remained the same.
When looking at those strange resolutions in the log files, I figured that those messages might not refer to the X server's own resolution, but reflect the size and position of the scrambled or invisible application windows. I am not sure if that makes any sense at all, and well over 30 years working with X11 I found I have no clue of how the X server is working internally.
To confirm or rule out a bug I replaced Xorg with Xlibre from a private repository mentioned in another thread here in the forum. Indeed, the error messages as well as the corrupt application windows were gone. The xlibre server however shows a noticeable and measurable decreased performance compared to Xorg in overall responiveness as well as GPU or WebGL related tests.
#4 2026-08-27 17:10:55
Likely the fly in the ointment right there. Gnome is is not known currently for it's friendliness to X11. Gnome 50 has dropped support for X11 completely last time I checked. Xlibre likely has some modded code to try and deal with that which may be why it works better.
#5 2026-08-27 17:53:43
trabant-asb wrote:
... however all based on gnome (that would be gnome 4, gnome-flashback and cinnamon) ...
The fork of Cinnamon from Gnome is way back. Some apps are the same like gnome-terminal, but I would see them as two different beasts nowadays. BTW: I am Cinnamon user on my desktop, and on xorg. I have tried xlibre in a VM, but was not really successful.
#6 2026-08-27 21:52:44
Did you try with nomodeset as kernel parameter?
#7 2026-08-28 08:53:26
trabant-asb
I did, but obviously I did not dig deep enough. With nomodset and the existing xorg.conf file --> no screens found, with the config file stripped down it probed and started with exactly the same resolution as I had previously (1280x1024x24bit/60Hz). While the modesetting driver does get loaded, it loads fbdev and fbdehw for probing.
The good news: The errors are gone, and the Cinnamon desktop feels even more responsive. The bad news: The DRI2 driver does not load the Raspberry's v3d/vc4 kernel driver, and so I do not have graphics acceleration available (i.e. in my browser with OpenGL not working). While some simple applications like the window manager feel more responsive, web applications like i.e. g***-maps are slowed down and do no provide all functions (3d mode disabled).
Graphics Feature Status
Canvas: Software only. Hardware acceleration disabled
Direct Rendering Display Compositor: Disabled
Compositing: Software only. Hardware acceleration disabled
Multiple Raster Threads: Disabled
OpenGL: Disabled
Rasterization: Software only. Hardware acceleration disabled
Raw Draw: Disabled
Skia Graphite: Disabled
TreesInViz: Disabled
Video Decode: Software only. Hardware acceleration disabled
Video Encode: Software only. Hardware acceleration disabled
Vulkan: Disabled
WebGL: Disabled
WebGPU: Disabled
WebGPU interop: Disabled
WebNN: Disabled
When I play a video the CPU rate and temperature goes up more than usual, most likely because the GPU does not work correctly, even if the log says it the gpu support had been added.
Hmm, where should I go from here...? How could I get the vc4 driver back in, or should that driver be part of the problem... I am attaching the actal Xorg.log to show the differences to the original log in the first post.
[  1082.590]
[  1082.590] Current Operating System: Linux aws 7.1.8+deb14.1-arm64 #1 SMP PREEMPT Debian 7.1.8-2 (2026-08-15) aarch64
[  1082.590] Kernel command line: video=HDMI-A-1:1280x1024M@60 dma.dmachans=0x37f5 bcm2709.boardrev=0xc03115 bcm2709.serial=0x3c446b80 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=42 bcm2709.disk_led_active_low=0 smsc95xx.macaddr=E4:5F:01:A8:4B:9E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty0 root=PARTUUID=8cddaba2-889f-49b9-8c3f-084fe4956fe8 rw fsck.repair=yes net.ifnames=0  rootwait quiet logo.nologo nomodeset
[  1082.590] xorg-server 2:21.1.24-1devuan1 (https://www.devuan.org/os/community)
[  1082.590] Current version of pixman: 0.46.4
[  1082.590] 	Before reporting problems, check http://wiki.x.org
[  1082.590] Markers: (--) probed, (**) from config file, (==) default setting,
[  1082.590] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 28 09:39:20 2026
[  1082.591] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  1082.591] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  1082.591] (==) No Layout section.  Using the first Screen section.
[  1082.591] (==) No screen section available. Using defaults.
[  1082.591] (**) |-->Screen "Default Screen Section" (0)
[  1082.591] (**) |   |-->Monitor "<default monitor>"
[  1082.591] (==) No monitor specified for screen "Default Screen Section".
[  1082.592] (**) Allowing byte-swapped clients
[  1082.592] (==) Automatically adding devices
[  1082.592] (==) Automatically enabling devices
[  1082.592] (==) Automatically adding GPU devices
[  1082.592] (==) Automatically binding GPU devices
[  1082.592] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  1082.592] (==) FontPath set to:
	/usr/share/fonts/X11/cyrillic,
	built-ins
[  1082.592] (==) ModulePath set to "/usr/lib/xorg/modules"
[  1082.592] (II) The server relies on udev to provide the list of input devices.
[  1082.592] (II) Loader magic: 0xaaaae0c90ea0
[  1082.592] (II) Module ABI versions:
[  1082.592] 	X.Org ANSI C Emulation: 0.4
[  1082.592] 	X.Org Video Driver: 25.2
[  1082.592] 	X.Org XInput driver : 24.4
[  1082.592] 	X.Org Server Extension : 10.0
[  1082.592] (++) using VT number 7
[  1082.592] (II) seat-libseat: libseat integration requires -keeptty and -keeptty was not provided, disabling libseat integration
[  1082.592] (II) xfree86: Adding drm device (/dev/dri/card0)
[  1082.592] (II) Platform probe for /sys/devices/platform/scb-bus@fc000000/fec00000.gpu/drm/card0
[  1082.593] (II) no primary bus or device found
[  1082.593] 	falling back to /sys/devices/platform/scb-bus@fc000000/fec00000.gpu/drm/card0
[  1082.593] (II) LoadModule: "glx"
[  1082.593] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  1082.595] (II) Module glx: vendor="X.Org Foundation"
[  1082.595] 	compiled for 1.21.1.24, module version = 1.0.0
[  1082.595] 	ABI class: X.Org Server Extension, version 10.0
[  1082.595] (==) Matched modesetting as autoconfigured driver 0
[  1082.595] (==) Matched fbdev as autoconfigured driver 1
[  1082.595] (==) Assigned the driver to the xf86ConfigLayout
[  1082.595] (II) LoadModule: "modesetting"
[  1082.596] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[  1082.596] (II) Module modesetting: vendor="X.Org Foundation"
[  1082.596] 	compiled for 1.21.1.24, module version = 1.21.1
[  1082.596] 	Module class: X.Org Video Driver
[  1082.596] 	ABI class: X.Org Video Driver, version 25.2
[  1082.596] (II) LoadModule: "fbdev"
[  1082.596] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[  1082.597] (II) Module fbdev: vendor="X.Org Foundation"
[  1082.597] 	compiled for 1.21.1.21, module version = 0.5.0
[  1082.597] 	Module class: X.Org Video Driver
[  1082.597] 	ABI class: X.Org Video Driver, version 25.2
[  1082.597] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[  1082.597] (II) FBDEV: driver for framebuffer: fbdev
[  1082.597] (WW) Falling back to old probe method for modesetting
[  1082.597] (WW) Falling back to old probe method for fbdev
[  1082.597] (II) Loading sub module "fbdevhw"
[  1082.597] (II) LoadModule: "fbdevhw"
[  1082.597] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[  1082.597] (II) Module fbdevhw: vendor="X.Org Foundation"
[  1082.597] 	compiled for 1.21.1.24, module version = 0.0.2
[  1082.598] (II) FBDEV(0): using default device
[  1082.598] (II) FBDEV(0): Creating default Display subsection in Screen section
[  1082.598] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[  1082.598] (==) FBDEV(0): RGB weight 888
[  1082.598] (==) FBDEV(0): Default visual is TrueColor
[  1082.598] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[  1082.598] (II) FBDEV(0): hardware: simple (video memory: 5120kB)
[  1082.598] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[  1082.598] (II) FBDEV(0): checking modes against framebuffer device...
[  1082.598] (II) FBDEV(0): checking modes against monitor...
[  1082.598] (II) FBDEV(0): Virtual size is 1280x1024 (pitch 1280)
[  1082.598] (**) FBDEV(0):  Built-in mode "current"
[  1082.598] (==) FBDEV(0): DPI set to (96, 96)
[  1082.598] (II) Loading sub module "fb"
[  1082.598] (II) LoadModule: "fb"
[  1082.598] (II) Module "fb" already built-in
[  1082.598] (**) FBDEV(0): using shadow framebuffer
[  1082.598] (II) Loading sub module "shadow"
[  1082.598] (II) LoadModule: "shadow"
[  1082.598] (II) Loading /usr/lib/xorg/modules/libshadow.so
[  1082.598] (II) Module shadow: vendor="X.Org Foundation"
[  1082.598] 	compiled for 1.21.1.24, module version = 1.1.0
[  1082.598] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  1082.598] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[  1082.599] (==) FBDEV(0): Backing store enabled
[  1082.600] (==) FBDEV(0): DPMS enabled
[  1082.600] (II) Initializing extension Generic Event Extension
[  1082.601] (II) Initializing extension SHAPE
[  1082.601] (II) Initializing extension MIT-SHM
[  1082.602] (II) Initializing extension XInputExtension
[  1082.602] (II) Initializing extension XTEST
[  1082.603] (II) Initializing extension BIG-REQUESTS
[  1082.603] (II) Initializing extension SYNC
[  1082.604] (II) Initializing extension XKEYBOARD
[  1082.604] (II) Initializing extension XC-MISC
[  1082.604] (II) Initializing extension SECURITY
[  1082.604] (II) Initializing extension XFIXES
[  1082.604] (II) Initializing extension RENDER
[  1082.605] (II) Initializing extension RANDR
[  1082.605] (II) Initializing extension COMPOSITE
[  1082.605] (II) Initializing extension DAMAGE
[  1082.605] (II) Initializing extension MIT-SCREEN-SAVER
[  1082.606] (II) Initializing extension DOUBLE-BUFFER
[  1082.606] (II) Initializing extension RECORD
[  1082.606] (II) Initializing extension DPMS
[  1082.606] (II) Initializing extension Present
[  1082.606] (II) Initializing extension DRI3
[  1082.606] (II) Initializing extension X-Resource
[  1082.606] (II) Initializing extension XVideo
[  1082.607] (II) Initializing extension XVideo-MotionCompensation
[  1082.607] (II) Initializing extension SELinux
[  1082.607] (II) SELinux: Disabled on system
[  1082.607] (II) Initializing extension GLX
[  1082.607] (II) AIGLX: Screen 0 is not DRI2 capable
[  1082.692] (II) IGLX: Loaded and initialized swrast
[  1082.692] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[  1082.692] (II) Initializing extension XFree86-VidModeExtension
[  1082.693] (II) Initializing extension XFree86-DGA
[  1082.693] (II) Initializing extension XFree86-DRI
[  1082.693] (II) Initializing extension DRI2
[  1082.762] (II) config/udev: Adding input device HID 05f3:0007 (/dev/input/event0)
[  1082.762] (**) HID 05f3:0007: Applying InputClass "libinput keyboard catchall"
[  1082.763] (II) LoadModule: "libinput"
[  1082.763] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  1082.766] (II) Module libinput: vendor="X.Org Foundation"
[  1082.766] 	compiled for 1.21.1.21, module version = 1.5.0
[  1082.766] 	Module class: X.Org XInput Driver
[  1082.766] 	ABI class: X.Org XInput driver, version 24.4
[  1082.766] (II) Using input driver 'libinput' for 'HID 05f3:0007'
[  1082.766] (**) HID 05f3:0007: always reports core events
[  1082.766] (**) Option "Device" "/dev/input/event0"
[  1082.771] (II) event0  - HID 05f3:0007: is tagged by udev as: Keyboard
[  1082.771] (II) event0  - HID 05f3:0007: device is a keyboard
[  1082.771] (II) event0  - HID 05f3:0007: device removed
[  1082.796] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.0/0003:05F3:0007.0001/input/input0/event0"
[  1082.796] (II) XINPUT: Adding extended input device "HID 05f3:0007" (type: KEYBOARD, id 6)
[  1082.796] (**) Option "xkb_model" "pc105"
[  1082.796] (**) Option "xkb_layout" "us"
[  1082.799] (II) event0  - HID 05f3:0007: is tagged by udev as: Keyboard
[  1082.799] (II) event0  - HID 05f3:0007: device is a keyboard
[  1082.800] (II) config/udev: Adding input device HID 05f3:0007 System Control (/dev/input/event1)
[  1082.800] (**) HID 05f3:0007 System Control: Applying InputClass "libinput keyboard catchall"
[  1082.800] (II) Using input driver 'libinput' for 'HID 05f3:0007 System Control'
[  1082.800] (**) HID 05f3:0007 System Control: always reports core events
[  1082.800] (**) Option "Device" "/dev/input/event1"
[  1082.802] (II) event1  - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[  1082.802] (II) event1  - HID 05f3:0007 System Control: device is a keyboard
[  1082.802] (II) event1  - HID 05f3:0007 System Control: device removed
[  1082.820] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.1/0003:05F3:0007.0002/input/input1/event1"
[  1082.820] (II) XINPUT: Adding extended input device "HID 05f3:0007 System Control" (type: KEYBOARD, id 7)
[  1082.820] (**) Option "xkb_model" "pc105"
[  1082.820] (**) Option "xkb_layout" "us"
[  1082.824] (II) event1  - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[  1082.824] (II) event1  - HID 05f3:0007 System Control: device is a keyboard
[  1082.826] (II) config/udev: Adding input device HID 05f3:0007 Consumer Control (/dev/input/event2)
[  1082.826] (**) HID 05f3:0007 Consumer Control: Applying InputClass "libinput keyboard catchall"
[  1082.826] (II) Using input driver 'libinput' for 'HID 05f3:0007 Consumer Control'
[  1082.826] (**) HID 05f3:0007 Consumer Control: always reports core events
[  1082.826] (**) Option "Device" "/dev/input/event2"
[  1082.828] (II) event2  - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[  1082.828] (II) event2  - HID 05f3:0007 Consumer Control: device is a keyboard
[  1082.828] (II) event2  - HID 05f3:0007 Consumer Control: device removed
[  1082.860] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.1/0003:05F3:0007.0002/input/input2/event2"
[  1082.860] (II) XINPUT: Adding extended input device "HID 05f3:0007 Consumer Control" (type: KEYBOARD, id 8)
[  1082.860] (**) Option "xkb_model" "pc105"
[  1082.860] (**) Option "xkb_layout" "us"
[  1082.863] (II) event2  - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[  1082.864] (II) event2  - HID 05f3:0007 Consumer Control: device is a keyboard
[  1082.865] (II) config/udev: Adding input device Microsoft Microsoft Trackball Explorer® (/dev/input/event3)
[  1082.865] (**) Microsoft Microsoft Trackball Explorer®: Applying InputClass "libinput pointer catchall"
[  1082.865] (II) Using input driver 'libinput' for 'Microsoft Microsoft Trackball Explorer®'
[  1082.865] (**) Microsoft Microsoft Trackball Explorer®: always reports core events
[  1082.865] (**) Option "Device" "/dev/input/event3"
[  1082.924] (II) event3  - Microsoft Microsoft Trackball Explorer®: is tagged by udev as: Mouse Trackball
[  1082.924] (II) event3  - Microsoft Microsoft Trackball Explorer®: device is a pointer
[  1082.925] (II) event3  - Microsoft Microsoft Trackball Explorer®: device removed
[  1082.940] (II) libinput: Microsoft Microsoft Trackball Explorer®: Step value 0 was provided, libinput Fallback acceleration function is used.
[  1082.940] (**) Option "ButtonMapping" "8 9 3 4 5 6 7 1 2 10"
[  1082.940] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:045E:0024.0003/input/input3/event3"
[  1082.940] (II) XINPUT: Adding extended input device "Microsoft Microsoft Trackball Explorer®" (type: MOUSE, id 9)
[  1082.941] (**) Option "AccelerationScheme" "none"
[  1082.941] (**) Microsoft Microsoft Trackball Explorer®: (accel) selected scheme none/0
[  1082.941] (**) Microsoft Microsoft Trackball Explorer®: (accel) acceleration factor: 2.000
[  1082.941] (**) Microsoft Microsoft Trackball Explorer®: (accel) acceleration threshold: 4
[  1083.000] (II) event3  - Microsoft Microsoft Trackball Explorer®: is tagged by udev as: Mouse Trackball
[  1083.000] (II) event3  - Microsoft Microsoft Trackball Explorer®: device is a pointer
[  1083.003] (II) config/udev: Adding input device Microsoft Microsoft Trackball Explorer® (/dev/input/mouse0)
[  1083.003] (II) No input driver specified, ignoring this device.
[  1083.003] (II) This device may have been added with another device file.
#8 2026-08-28 09:53:36
I'm guessing you know more about this than I, but I would consider moving back settings from your previous xorg.conf to see if there's a working subset. I.e., whether possibly the newer Xorg version has some sensitivity to your settings... my first test would be to add a file /etc/X11/xorg.conf.d/device.conf with your device setup for screen 0, but then avoid disabling backing store and avoid binding it to the specific monitor configuration. The file would be like this:
Section "Device"
    Identifier "DRM"
    #Option "BackingStore" "false"
    #Option "Monitor-HDMI-1" "AL1716"
    Screen 0
EndSection
The purpose with that would be to steer Xorg towards using the sub-module glamoregl which by my reading of the first log makes V3D be used.
(I guess you already have a .conf file in that directory with the InputClass specifications)
#9 2026-08-28 11:50:09
trabant-asb
In this specific case Driver "modesetting" is exactly what it breaks. If there's no driver in the config file, modesetting is loaded, sees there's nothing to do for it as nomodeset is set, so the next driver candidate is loaded, which is fbdev. If I hardcode modesetting in the config it won't start, if I set fbdev instead, it will come up smoothly but without DRI2 support, so no hardware acceleration.
So I tried to run modesetting w/o the nomodeset in the kernel's command line, but even with ignore_edid set and nailed down to one working Modeline in the config the problem returns. So I guess the issue is particularely in the modesetting driver. The module in the xorg directory has indeed a newer file date than the one in the xlibre installation, and it's even newer than the rest of the xorg drivers (Aug 15th).
So for now, I am back on Chimaera, and will see if the next Xorg update will bring a change.
#10 2026-08-28 22:37:52
You could perhaps humour me and show the Xorg.0.log from trialling my test setup, which to keep nomodeset as kernel command line parameter, and include that particular "Device" specification that only has Option "AccelMethod" "glamor".
Though maybe you moved back already.
#11 2026-08-29 09:30:59
trabant-asb
Sure I can, that is the good thing with the Raspberry Pi as a desktop. It's all on a microSD card. So I have my primary Chimaera installation on one card, the freia with Xorg on the 2nd, and freia with Xlibre on the 3rd. So it takes only a few seconds to change from one system to another.
I just redid the experiment. This is the xorg.conf with only a device section (and my input devices of course)
Section "Device"
   Identifier "DRM"
  # Driver "modesetting"
EndSectionSection "Device"
I toggled setting the driver. With the modesetting driver set and the nomodeset in the kernel cmd line X doesn't start ...
[    10.220]
[    10.220] Current Operating System: Linux aws 7.1.8+deb14.1-arm64 #1 SMP PREEMPT Debian 7.1.8-2 (2026-08-15) aarch64
[    10.220] Kernel command line: video=HDMI-A-1:1280x1024M@60 dma.dmachans=0x37f5 bcm2709.boardrev=0xc03115 bcm2709.serial=0x3c446b80 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=42 bcm2709.disk_led_active_low=0 smsc95xx.macaddr=E4:5F:01:A8:4B:9E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty0 root=PARTUUID=8cddaba2-889f-49b9-8c3f-084fe4956fe8 rw fsck.repair=yes net.ifnames=0  rootwait quiet logo.nologo nomodeset
[    10.221] xorg-server 2:21.1.24-1devuan1 (https://www.devuan.org/os/community)
[    10.221] Current version of pixman: 0.46.4
[    10.221] 	Before reporting problems, check http://wiki.x.org
[    10.221] Markers: (--) probed, (**) from config file, (==) default setting,
[    10.221] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Aug 29 13:19:48 2026
[    10.239] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    10.239] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    10.273] (==) No Layout section.  Using the first Screen section.
[    10.273] (==) No screen section available. Using defaults.
[    10.273] (**) |-->Screen "Default Screen Section" (0)
[    10.273] (**) |   |-->Monitor "<default monitor>"
[    10.278] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[    10.279] (**) |   |-->Device "DRM"
[    10.279] (==) No monitor specified for screen "Default Screen Section".
[    10.279] (**) Allowing byte-swapped clients
[    10.279] (==) Automatically adding devices
[    10.279] (==) Automatically enabling devices
[    10.279] (==) Automatically adding GPU devices
[    10.279] (==) Automatically binding GPU devices
[    10.285] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    10.341] (==) FontPath set to:
	built-ins
[    10.341] (==) ModulePath set to "/usr/lib/xorg/modules"
[    10.341] (II) The server relies on udev to provide the list of input devices.
[    10.341] (II) Loader magic: 0xaaaabfd70ea0
[    10.341] (II) Module ABI versions:
[    10.341] 	X.Org ANSI C Emulation: 0.4
[    10.341] 	X.Org Video Driver: 25.2
[    10.341] 	X.Org XInput driver : 24.4
[    10.341] 	X.Org Server Extension : 10.0
[    10.341] (++) using VT number 7
[    10.341] (II) seat-libseat: libseat integration requires -keeptty and -keeptty was not provided, disabling libseat integration
[    10.342] (II) xfree86: Adding drm device (/dev/dri/card0)
[    10.343] (II) Platform probe for /sys/devices/platform/scb-bus@fc000000/fec00000.gpu/drm/card0
[    10.344] (II) no primary bus or device found
[    10.344] 	falling back to /sys/devices/platform/scb-bus@fc000000/fec00000.gpu/drm/card0
[    10.344] (II) LoadModule: "glx"
[    10.369] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    10.465] (II) Module glx: vendor="X.Org Foundation"
[    10.465] 	compiled for 1.21.1.24, module version = 1.0.0
[    10.465] 	ABI class: X.Org Server Extension, version 10.0
[    10.465] (II) LoadModule: "modesetting"
[    10.466] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    10.481] (II) Module modesetting: vendor="X.Org Foundation"
[    10.481] 	compiled for 1.21.1.24, module version = 1.21.1
[    10.481] 	Module class: X.Org Video Driver
[    10.481] 	ABI class: X.Org Video Driver, version 25.2
[    10.481] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    10.484] (WW) Falling back to old probe method for modesetting
[    10.485] (EE) No devices detected.
[    10.485] (EE)
Fatal server error:
[    10.485] (EE) no screens found(EE)
[    10.485] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    10.485] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    10.485] (EE)
[    10.487] (EE) Server terminated with error (1). Closing log file.
... and with the driver line commented out it falls back to the fbdev driver...
[    10.234]
[    10.234] Current Operating System: Linux aws 7.1.8+deb14.1-arm64 #1 SMP PREEMPT Debian 7.1.8-2 (2026-08-15) aarch64
[    10.234] Kernel command line: video=HDMI-A-1:1280x1024M@60 dma.dmachans=0x37f5 bcm2709.boardrev=0xc03115 bcm2709.serial=0x3c446b80 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=42 bcm2709.disk_led_active_low=0 smsc95xx.macaddr=E4:5F:01:A8:4B:9E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty0 root=PARTUUID=8cddaba2-889f-49b9-8c3f-084fe4956fe8 rw fsck.repair=yes net.ifnames=0  rootwait quiet logo.nologo nomodeset
[    10.234] xorg-server 2:21.1.24-1devuan1 (https://www.devuan.org/os/community)
[    10.234] Current version of pixman: 0.46.4
[    10.234] 	Before reporting problems, check http://wiki.x.org
[    10.234] Markers: (--) probed, (**) from config file, (==) default setting,
[    10.234] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Aug 29 13:27:00 2026
[    10.257] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    10.257] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    10.272] (==) No Layout section.  Using the first Screen section.
[    10.272] (==) No screen section available. Using defaults.
[    10.272] (**) |-->Screen "Default Screen Section" (0)
[    10.272] (**) |   |-->Monitor "<default monitor>"
[    10.277] (==) No device specified for screen "Default Screen Section".
[    10.277] (**) |   |-->Device "DRM"
[    10.277] (==) No monitor specified for screen "Default Screen Section".
[    10.277] (**) Allowing byte-swapped clients
[    10.277] (==) Automatically adding devices
[    10.277] (==) Automatically enabling devices
[    10.277] (==) Automatically adding GPU devices
[    10.277] (==) Automatically binding GPU devices
[    10.284] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    10.345] (==) FontPath set to:
	built-ins
[    10.346] (==) ModulePath set to "/usr/lib/xorg/modules"
[    10.346] (II) The server relies on udev to provide the list of input devices.
[    10.346] (II) Loader magic: 0xaaaae5fc0ea0
[    10.346] (II) Module ABI versions:
[    10.346] 	X.Org ANSI C Emulation: 0.4
[    10.346] 	X.Org Video Driver: 25.2
[    10.346] 	X.Org XInput driver : 24.4
[    10.346] 	X.Org Server Extension : 10.0
[    10.346] (++) using VT number 7
[    10.346] (II) seat-libseat: libseat integration requires -keeptty and -keeptty was not provided, disabling libseat integration
[    10.346] (II) xfree86: Adding drm device (/dev/dri/card0)
[    10.346] (II) Platform probe for /sys/devices/platform/scb-bus@fc000000/fec00000.gpu/drm/card0
[    10.347] (II) no primary bus or device found
[    10.347] 	falling back to /sys/devices/platform/scb-bus@fc000000/fec00000.gpu/drm/card0
[    10.347] (II) LoadModule: "glx"
[    10.367] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    10.477] (II) Module glx: vendor="X.Org Foundation"
[    10.478] 	compiled for 1.21.1.24, module version = 1.0.0
[    10.478] 	ABI class: X.Org Server Extension, version 10.0
[    10.478] (==) Matched modesetting as autoconfigured driver 0
[    10.478] (==) Matched fbdev as autoconfigured driver 1
[    10.478] (==) Assigned the driver to the xf86ConfigLayout
[    10.478] (II) LoadModule: "modesetting"
[    10.478] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    10.486] (II) Module modesetting: vendor="X.Org Foundation"
[    10.487] 	compiled for 1.21.1.24, module version = 1.21.1
[    10.487] 	Module class: X.Org Video Driver
[    10.487] 	ABI class: X.Org Video Driver, version 25.2
[    10.487] (II) LoadModule: "fbdev"
[    10.487] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    10.491] (II) Module fbdev: vendor="X.Org Foundation"
[    10.492] 	compiled for 1.21.1.21, module version = 0.5.0
[    10.492] 	Module class: X.Org Video Driver
[    10.492] 	ABI class: X.Org Video Driver, version 25.2
[    10.492] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    10.492] (II) FBDEV: driver for framebuffer: fbdev
[    10.499] (WW) Falling back to old probe method for modesetting
[    10.499] (WW) Falling back to old probe method for fbdev
[    10.499] (II) Loading sub module "fbdevhw"
[    10.499] (II) LoadModule: "fbdevhw"
[    10.499] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    10.503] (II) Module fbdevhw: vendor="X.Org Foundation"
[    10.503] 	compiled for 1.21.1.24, module version = 0.0.2
[    10.503] 	ABI class: X.Org Video Driver, version 25.2
[    10.504] (II) FBDEV(0): using default device
[    10.504] (II) FBDEV(0): Creating default Display subsection in Screen section
[    10.504] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[    10.504] (==) FBDEV(0): RGB weight 888
[    10.504] (==) FBDEV(0): Default visual is TrueColor
[    10.504] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[    10.504] (II) FBDEV(0): hardware: simple (video memory: 5120kB)
[    10.504] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[    10.504] (II) FBDEV(0): checking modes against framebuffer device...
[    10.504] (II) FBDEV(0): checking modes against monitor...
[    10.504] (II) FBDEV(0): Virtual size is 1280x1024 (pitch 1280)
[    10.504] (**) FBDEV(0):  Built-in mode "current"
[    10.504] (==) FBDEV(0): DPI set to (96, 96)
[    10.504] (II) Loading sub module "fb"
[    10.504] (II) LoadModule: "fb"
[    10.504] (II) Module "fb" already built-in
[    10.504] (**) FBDEV(0): using shadow framebuffer
[    10.504] (II) Loading sub module "shadow"
[    10.504] (II) LoadModule: "shadow"
[    10.504] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    10.510] (II) Module shadow: vendor="X.Org Foundation"
[    10.510] 	compiled for 1.21.1.24, module version = 1.1.0
[    10.510] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    10.510] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[    10.528] (==) FBDEV(0): Backing store enabled
[    10.529] (==) FBDEV(0): DPMS enabled
[    10.532] (II) Initializing extension Generic Event Extension
[    10.532] (II) Initializing extension SHAPE
[    10.532] (II) Initializing extension MIT-SHM
[    10.533] (II) Initializing extension XInputExtension
[    10.536] (II) Initializing extension XTEST
[    10.537] (II) Initializing extension BIG-REQUESTS
[    10.537] (II) Initializing extension SYNC
[    10.537] (II) Initializing extension XKEYBOARD
[    10.538] (II) Initializing extension XC-MISC
[    10.538] (II) Initializing extension SECURITY
[    10.538] (II) Initializing extension XFIXES
[    10.538] (II) Initializing extension RENDER
[    10.539] (II) Initializing extension RANDR
[    10.539] (II) Initializing extension COMPOSITE
[    10.539] (II) Initializing extension DAMAGE
[    10.539] (II) Initializing extension MIT-SCREEN-SAVER
[    10.540] (II) Initializing extension DOUBLE-BUFFER
[    10.540] (II) Initializing extension RECORD
[    10.540] (II) Initializing extension DPMS
[    10.540] (II) Initializing extension Present
[    10.541] (II) Initializing extension DRI3
[    10.541] (II) Initializing extension X-Resource
[    10.541] (II) Initializing extension XVideo
[    10.541] (II) Initializing extension XVideo-MotionCompensation
[    10.541] (II) Initializing extension SELinux
[    10.541] (II) SELinux: Disabled on system
[    10.541] (II) Initializing extension GLX
[    10.541] (II) AIGLX: Screen 0 is not DRI2 capable
[    13.331] (II) IGLX: Loaded and initialized swrast
[    13.331] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    13.331] (II) Initializing extension XFree86-VidModeExtension
[    13.332] (II) Initializing extension XFree86-DGA
[    13.333] (II) Initializing extension XFree86-DRI
[    13.333] (II) Initializing extension DRI2
[    13.622] (II) config/udev: Adding input device HID 05f3:0007 (/dev/input/event0)
[    13.623] (**) HID 05f3:0007: Applying InputClass "libinput keyboard catchall"
[    13.623] (II) LoadModule: "libinput"
[    13.623] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    13.647] (II) Module libinput: vendor="X.Org Foundation"
[    13.647] 	compiled for 1.21.1.21, module version = 1.5.0
[    13.647] 	Module class: X.Org XInput Driver
[    13.647] 	ABI class: X.Org XInput driver, version 24.4
[    13.647] (II) Using input driver 'libinput' for 'HID 05f3:0007'
[    13.647] (**) HID 05f3:0007: always reports core events
[    13.647] (**) Option "Device" "/dev/input/event0"
[    13.697] (II) event0  - HID 05f3:0007: is tagged by udev as: Keyboard
[    13.697] (II) event0  - HID 05f3:0007: device is a keyboard
[    13.698] (II) event0  - HID 05f3:0007: device removed
[    13.712] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.0/0003:05F3:0007.0001/input/input0/event0"
[    13.712] (II) XINPUT: Adding extended input device "HID 05f3:0007" (type: KEYBOARD, id 6)
[    13.712] (**) Option "xkb_model" "pc105"
[    13.712] (**) Option "xkb_layout" "us"
[    13.717] (II) event0  - HID 05f3:0007: is tagged by udev as: Keyboard
[    13.718] (II) event0  - HID 05f3:0007: device is a keyboard
[    13.720] (II) config/udev: Adding input device HID 05f3:0007 System Control (/dev/input/event1)
[    13.720] (**) HID 05f3:0007 System Control: Applying InputClass "libinput keyboard catchall"
[    13.720] (II) Using input driver 'libinput' for 'HID 05f3:0007 System Control'
[    13.720] (**) HID 05f3:0007 System Control: always reports core events
[    13.721] (**) Option "Device" "/dev/input/event1"
[    13.725] (II) event1  - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[    13.725] (II) event1  - HID 05f3:0007 System Control: device is a keyboard
[    13.726] (II) event1  - HID 05f3:0007 System Control: device removed
[    13.732] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.1/0003:05F3:0007.0002/input/input1/event1"
[    13.732] (II) XINPUT: Adding extended input device "HID 05f3:0007 System Control" (type: KEYBOARD, id 7)
[    13.732] (**) Option "xkb_model" "pc105"
[    13.732] (**) Option "xkb_layout" "us"
[    13.737] (II) event1  - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[    13.737] (II) event1  - HID 05f3:0007 System Control: device is a keyboard
[    13.740] (II) config/udev: Adding input device HID 05f3:0007 Consumer Control (/dev/input/event2)
[    13.740] (**) HID 05f3:0007 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    13.740] (II) Using input driver 'libinput' for 'HID 05f3:0007 Consumer Control'
[    13.740] (**) HID 05f3:0007 Consumer Control: always reports core events
[    13.740] (**) Option "Device" "/dev/input/event2"
[    13.744] (II) event2  - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[    13.745] (II) event2  - HID 05f3:0007 Consumer Control: device is a keyboard
[    13.745] (II) event2  - HID 05f3:0007 Consumer Control: device removed
[    13.772] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.1/0003:05F3:0007.0002/input/input2/event2"
[    13.772] (II) XINPUT: Adding extended input device "HID 05f3:0007 Consumer Control" (type: KEYBOARD, id 8)
[    13.772] (**) Option "xkb_model" "pc105"
[    13.772] (**) Option "xkb_layout" "us"
[    13.777] (II) event2  - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[    13.778] (II) event2  - HID 05f3:0007 Consumer Control: device is a keyboard
[    13.780] (II) config/udev: Adding input device Microsoft Microsoft Trackball Explorer® (/dev/input/event3)
[    13.780] (**) Microsoft Microsoft Trackball Explorer®: Applying InputClass "libinput pointer catchall"
[    13.780] (II) Using input driver 'libinput' for 'Microsoft Microsoft Trackball Explorer®'
[    13.780] (**) Microsoft Microsoft Trackball Explorer®: always reports core events
[    13.780] (**) Option "Device" "/dev/input/event3"
[    13.840] (II) event3  - Microsoft Microsoft Trackball Explorer®: is tagged by udev as: Mouse Trackball
[    13.840] (II) event3  - Microsoft Microsoft Trackball Explorer®: device is a pointer
[    13.841] (II) event3  - Microsoft Microsoft Trackball Explorer®: device removed
[    13.856] (II) libinput: Microsoft Microsoft Trackball Explorer®: Step value 0 was provided, libinput Fallback acceleration function is used.
[    13.856] (**) Option "ButtonMapping" "8 9 3 4 5 6 7 1 2 10"
[    13.856] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:045E:0024.0003/input/input3/event3"
[    13.856] (II) XINPUT: Adding extended input device "Microsoft Microsoft Trackball Explorer®" (type: MOUSE, id 9)
[    13.857] (**) Option "AccelerationScheme" "none"
[    13.857] (**) Microsoft Microsoft Trackball Explorer®: (accel) selected scheme none/0
[    13.857] (**) Microsoft Microsoft Trackball Explorer®: (accel) acceleration factor: 2.000
[    13.857] (**) Microsoft Microsoft Trackball Explorer®: (accel) acceleration threshold: 4
[    13.916] (II) event3  - Microsoft Microsoft Trackball Explorer®: is tagged by udev as: Mouse Trackball
[    13.916] (II) event3  - Microsoft Microsoft Trackball Explorer®: device is a pointer
[    13.919] (II) config/udev: Adding input device Microsoft Microsoft Trackball Explorer® (/dev/input/mouse0)
[    13.919] (II) No input driver specified, ignoring this device.
[    13.919] (II) This device may have been added with another device file.
...however the fbdev driver can't do DRI2 or DRI3 with the Raspberry kernel drivers...
...while with modesetting enabled on the xlibre installation...
(II) Loading /usr/lib/xorg/modules/xlibre-25/libglamoregl.so
  compiled for 1.25.2.2, module version = 1.0.1
  ABI class: X.Org ANSI C Emulation, version 1.4
(II) glamor: eglInitialize() succeeded on EGL_PLATFORM_GBM_KHR
(II) glamor: Using OpenGL 3.1 context.
(II) glamor: Can texture gbm buffers
(II) glamor: DRI3 X acceleration enabled on V3D 4.2.14.0
(II) [DRI2] Setup complete
(II) [DRI2]   DRI driver: vc4
(II) [DRI2]   VDPAU driver: vc4
Both v3d and vc4 are kernel drivers supporting the Raspberry's Broadcam GPU and are available in Devuan's/Debian's generic arm64 kernel image.
Edited & replaced the logs, corrected installation problem.
#12 2026-08-29 13:31:21
Did you try the device section I suggested as well?
Section "Device"
    Identifier "DRM"
    Screen 0
EndSection
In my understanding both the Screen association and the Driver association are important. The Screen setting tells Xorg to use that Device specification for that default screen. The Driver setting tells Xorg that it concerns the modesetting driver. You would stll have the nomodeset boot parameter so as to tell the modesetting driver to avoid setting modes but rather rely on the default behaviour based on the monitor EDID.
#13 2026-08-29 15:35:26
trabant-asb
I did copy/paste the device section now to be sure, as far as I can see the result seems the same...
[    10.258]
X.Org X Server 1.21.1.24
[    10.258] Current Operating System: Linux aws 7.1.8+deb14.1-arm64 #1 SMP PREEMPT Debian 7.1.8-2 (2026-08-15) aarch64
[    10.258] Kernel command line: video=HDMI-A-1:1280x1024M@60 dma.dmachans=0x37f5 bcm2709.boardrev=0xc03115 bcm2709.serial=0x3c446b80 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=42 bcm2709.disk_led_active_low=0 smsc95xx.macaddr=E4:5F:01:A8:4B:9E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty0 root=PARTUUID=8cddaba2-889f-49b9-8c3f-084fe4956fe8 rw fsck.repair=yes net.ifnames=0  rootwait quiet logo.nologo nomodeset
[    10.258] xorg-server 2:21.1.24-1devuan1 (https://www.devuan.org/os/community)
[    10.258] Current version of pixman: 0.46.4
[    10.258] 	Before reporting problems, check http://wiki.x.org
[    10.258] Markers: (--) probed, (**) from config file, (==) default setting,
[    10.258] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Aug 29 17:24:36 2026
[    10.284] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    10.284] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    10.314] (==) No Layout section.  Using the first Screen section.
[    10.314] (==) No screen section available. Using defaults.
[    10.314] (**) |-->Screen "Default Screen Section" (0)
[    10.315] (**) |   |-->Monitor "<default monitor>"
[    10.320] (==) No device specified for screen "Default Screen Section".
[    10.320] (**) |   |-->Device "DRM"
[    10.320] (==) No monitor specified for screen "Default Screen Section".
[    10.320] (**) Allowing byte-swapped clients
[    10.320] (==) Automatically adding devices
[    10.320] (==) Automatically enabling devices
[    10.320] (==) Automatically adding GPU devices
[    10.320] (==) Automatically binding GPU devices
[    10.323] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    10.384] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[    10.384] (==) ModulePath set to "/usr/lib/xorg/modules"
[    10.384] (II) The server relies on udev to provide the list of input devices.
[    10.384] (II) Loader magic: 0xaaaab2880ea0
[    10.384] (II) Module ABI versions:
[    10.384] 	X.Org ANSI C Emulation: 0.4
[    10.384] 	X.Org Video Driver: 25.2
[    10.384] 	X.Org XInput driver : 24.4
[    10.384] 	X.Org Server Extension : 10.0
[    10.384] (++) using VT number 7
[    10.384] (II) seat-libseat: libseat integration requires -keeptty and -keeptty was not provided, disabling libseat integration
[    10.385] (II) xfree86: Adding drm device (/dev/dri/card0)
[    10.385] (II) Platform probe for /sys/devices/platform/scb-bus@fc000000/fec00000.gpu/drm/card0
[    10.386] (II) no primary bus or device found
[    10.386] 	falling back to /sys/devices/platform/scb-bus@fc000000/fec00000.gpu/drm/card0
[    10.386] (II) LoadModule: "glx"
[    10.417] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    10.503] (II) Module glx: vendor="X.Org Foundation"
[    10.503] 	compiled for 1.21.1.24, module version = 1.0.0
[    10.503] 	ABI class: X.Org Server Extension, version 10.0
[    10.503] (II) LoadModule: "modesetting"
[    10.503] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    10.518] (II) Module modesetting: vendor="X.Org Foundation"
[    10.518] 	compiled for 1.21.1.24, module version = 1.21.1
[    10.518] 	Module class: X.Org Video Driver
[    10.518] 	ABI class: X.Org Video Driver, version 25.2
[    10.518] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    10.524] (WW) Falling back to old probe method for modesetting
[    10.524] (EE) No devices detected.
[    10.524] (EE)
Fatal server error:
[    10.525] (EE) no screens found(EE)
[    10.525] (EE)
 for help.
[    10.525] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    10.525] (EE)
[    10.528] (EE) Server terminated with error (1). Closing log file.
#14 2026-08-30 01:49:55
Thanks, yes, after some more thought (and a quick visit to Luke) I now think differently. I realized that the first Xorg log in post #1 uses /dev/dri/card1 and the others only use /dev/dri/card0, and then my fog around the Xorg startup took on a different form.
Basically you have 2 GPU in the box, which for linux are known as device paths /dev/dri/card0 and /dev/dri/card1. The box is an arm64, and there is no PCI addressing involved but the kernel intially figures out those as "platform bus devices". As such they are presented by Xorg during probing via sysfs paths where in particular the "DRM" capable card turns up as /sys/devices/platform/gpu/drm/card1.
In short, I see two startup issues: one is that you want Xorg to use card1 for the HDMI monitor, and the other that something goes awry with Xorg wanting to set up the monitor to have a 5038080 byte "frame buffer" available on that card. Possibly due to Xorg initially may have asked for only 3932160 bytes (upon seeing the preferred screen resolution), or even just 2359296 bytes if using it's default screen resolution 1024x768, and then after loading/initialising, the card (driver) won't budge for a new frame buffer size.
Thus that line of thought would have you to go back to your original xorg.conf, and than add a line to the "Device" section:
       Option "NoOutputInitialSize" "1640 1312"
(or any 24 bit resolution needing more than 5038080 bytes,..) The idea here is that the driver should be initialized with a large enough frame buffer to handle all resolutions the monitor may use.
#15 2026-08-30 08:56:06
trabant-asb
I see your point. I stumbled over those two card devices yesterday as well and tried to figure out if one of them can be disabled by a kernel boot parameter or a similar setting. No way. Then I tried to find out if I can hard pin a device entry to a device file, something like BusID "vc4-hdmi-0" or similar. No success as well. I ended up in deleting the card0 device by script before X starts and see what happens. The correct way for this would probably be to configure udev accodingly.
The interesting thing is that the X server says  (EE) cannot open /dev/dri/card0 and also won't try to set it up, however it stills knows that there are 2 HDMI devices, one connected and one not, and it also knows that there should be a card0 device. And the errors remained.
Right now I gave your device option a try. And indeed, it changes something. The error messages in the X log file are gone, as well as the scrambled windows. But, at a certain point I could not open new X applications any more. In this case I had a few terminals, an email reader, a browser, everything worked so far. Then I tried to open the gnome-maps tool, which exited with the following error:
alex@aws:~:(1)> gnome-maps
DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory
MESA: error: Failed to create scanout resource
MESA: error: Failed to allocate device memory for BO
Segmentation fault
It seems that the problem has shifted... I tried that with both the card0 available or not, no difference there. I will attach both X config and log so we are on the same page.
Section "Device"
   Identifier "DRI"
   #Option "IgnoreEDID" "true"
   #BusID  "vc4-hdmi-1"
   Screen 0
EndSection
#EndSection
    Screen "Screen0"
    Option "DisableVidModeExtension" "true"
EndSection
Section "Screen"
    Monitor    "AL1716"
    Device     "DRI"
    DefaultDepth 24
    DefaultFbBpp 32
       Depth 24
       FbBpp 32
       Modes "1280x1024"
    EndSubSection
EndSection
Section "Monitor"
    Identifier "AL1716"
    ModelName "AL1716"
    VendorName "ACR"
    # EDID version 1.3
    # Digital Display
    DisplaySize 340 270
    Gamma 2.20
    #Option "DefaultModes" "true"
    Horizsync 31-83
    VertRefresh 56-75
    Modeline   "1280x1024"  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync
    #Option "PreferredMode" "1280x1024"
EndSection
    MatchProduct "vc4"
EndSection
    MatchIsPointer "on"
    Driver "libinput"
EndSection
    Driver "libinput"
EndSection
[    11.769]
[    11.769] Current Operating System: Linux aws 7.1.8+deb14.1-arm64 #1 SMP PREEMPT Debian 7.1.8-2 (2026-08-15) aarch64
[    11.769] Kernel command line: video=HDMI-A-1:1280x1024M@60 dma.dmachans=0x37f5 bcm2709.boardrev=0xc03115 bcm2709.serial=0x3c446b80 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=42 bcm2709.disk_led_active_low=0 smsc95xx.macaddr=E4:5F:01:A8:4B:9E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty0 root=PARTUUID=8cddaba2-889f-49b9-8c3f-084fe4956fe8 rw fsck.repair=yes net.ifnames=0  rootwait quiet logo.nologo
[    11.769] xorg-server 2:21.1.24-1devuan1 (https://www.devuan.org/os/community)
[    11.769] Current version of pixman: 0.46.4
[    11.769] 	Before reporting problems, check http://wiki.x.org
[    11.769] Markers: (--) probed, (**) from config file, (==) default setting,
[    11.770] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Aug 30 10:31:13 2026
[    11.794] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    11.794] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    11.813] (==) ServerLayout "Layout0"
[    11.813] (**) |-->Screen "Screen0" (0)
[    11.813] (**) |   |-->Monitor "AL1716"
[    11.818] (**) |   |-->Device "DRI"
[    11.818] (**) Option "DisableVidModeExtension" "true"
[    11.818] (**) Allowing byte-swapped clients
[    11.818] (==) Automatically adding devices
[    11.818] (==) Automatically enabling devices
[    11.818] (==) Automatically adding GPU devices
[    11.818] (==) Automatically binding GPU devices
[    11.822] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    11.884] (==) FontPath set to:
	built-ins
[    11.884] (==) ModulePath set to "/usr/lib/xorg/modules"
[    11.884] (II) The server relies on udev to provide the list of input devices.
[    11.884] (II) Loader magic: 0xaaaab1790ea0
[    11.884] (II) Module ABI versions:
[    11.884] 	X.Org ANSI C Emulation: 0.4
[    11.884] 	X.Org Video Driver: 25.2
[    11.884] 	X.Org XInput driver : 24.4
[    11.884] 	X.Org Server Extension : 10.0
[    11.884] (++) using VT number 7
[    11.884] (II) seat-libseat: libseat integration requires -keeptty and -keeptty was not provided, disabling libseat integration
[    11.886] (II) xfree86: Adding drm device (/dev/dri/card1)
[    11.886] (II) Platform probe for /sys/devices/platform/gpu/drm/card1
[    11.908] (II) xfree86: Adding drm device (/dev/dri/card0)
[    11.908] (II) Platform probe for /sys/devices/platform/scb-bus@fc000000/fec00000.gpu/drm/card0
[    11.909] (II) no primary bus or device found
[    11.909] 	falling back to /sys/devices/platform/gpu/drm/card1
[    11.909] (II) LoadModule: "glx"
[    11.928] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    11.999] (II) Module glx: vendor="X.Org Foundation"
[    11.999] 	compiled for 1.21.1.24, module version = 1.0.0
[    11.999] 	ABI class: X.Org Server Extension, version 10.0
[    11.999] (II) LoadModule: "modesetting"
[    12.000] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    12.011] (II) Module modesetting: vendor="X.Org Foundation"
[    12.011] 	compiled for 1.21.1.24, module version = 1.21.1
[    12.011] 	Module class: X.Org Video Driver
[    12.011] 	ABI class: X.Org Video Driver, version 25.2
[    12.011] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    12.051] (II) modeset(0): using drv /dev/dri/card1
[    12.051] (**) modeset(0): Depth 24, (**) framebuffer bpp 32
[    12.052] (**) modeset(0): Option "AccelMethod" "glamor"
[    12.052] (==) modeset(0): RGB weight 888
[    12.052] (==) modeset(0): Default visual is TrueColor
[    12.052] (II) Loading sub module "glamoregl"
[    12.052] (II) LoadModule: "glamoregl"
[    12.052] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    12.111] (II) Module glamoregl: vendor="X.Org Foundation"
[    12.111] 	compiled for 1.21.1.24, module version = 1.0.1
[    12.111] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    14.911] (II) modeset(0): glamor: Using OpenGL 3.1 context.
[    14.921] (II) modeset(0): glamor X acceleration enabled on V3D 4.2.14.0
[    14.921] (II) modeset(0): glamor initialized
[    14.921] (==) modeset(0): VariableRefresh: disabled
[    14.921] (==) modeset(0): AsyncFlipSecondaries: disabled
[    14.936] (II) modeset(0): Output HDMI-1 using monitor section AL1716
[    14.936] (II) modeset(0): Output HDMI-2 has no monitor section
[    14.995] (**) modeset(0): Option "NoOutputInitialSize" "1640 1312"
[    15.009] (II) modeset(0): EDID for output HDMI-1
[    15.010] (II) modeset(0): Manufacturer: ACR  Model: 6b4  Serial#: 6704
[    15.010] (II) modeset(0): Year: 2005  Week: 39
[    15.010] (II) modeset(0): EDID Version: 1.3
[    15.010] (II) modeset(0): Digital Display Input
[    15.010] (II) modeset(0): Max Image Size [cm]: horiz.: 34  vert.: 27
[    15.010] (II) modeset(0): Gamma: 2.20
[    15.010] (II) modeset(0): DPMS capabilities: Suspend Off
[    15.010] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    15.010] (II) modeset(0): Default color space is primary color space
[    15.010] (II) modeset(0): First detailed timing is preferred mode
[    15.010] (II) modeset(0): redX: 0.640 redY: 0.340   greenX: 0.290 greenY: 0.610
[    15.010] (II) modeset(0): blueX: 0.140 blueY: 0.000   whiteX: 0.313 whiteY: 0.329
[    15.010] (II) modeset(0): Supported established timings:
[    15.010] (II) modeset(0): 720x400@70Hz
[    15.010] (II) modeset(0): 640x480@60Hz
[    15.010] (II) modeset(0): 640x480@72Hz
[    15.010] (II) modeset(0): 640x480@75Hz
[    15.010] (II) modeset(0): 800x600@56Hz
[    15.010] (II) modeset(0): 800x600@60Hz
[    15.010] (II) modeset(0): 800x600@72Hz
[    15.010] (II) modeset(0): 800x600@75Hz
[    15.010] (II) modeset(0): 1024x768@60Hz
[    15.010] (II) modeset(0): 1024x768@70Hz
[    15.010] (II) modeset(0): 1024x768@75Hz
[    15.010] (II) modeset(0): 1280x1024@75Hz
[    15.010] (II) modeset(0): Manufacturer's mask: 0
[    15.010] (II) modeset(0): Supported standard timings:
[    15.010] (II) modeset(0): #0: hsize: 832  vsize 624  refresh: 75  vid: 20297
[    15.010] (II) modeset(0): #1: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[    15.010] (II) modeset(0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    15.010] (II) modeset(0): Supported detailed timing:
[    15.011] (II) modeset(0): clock: 108.0 MHz   Image Size:  338 x 270 mm
[    15.011] (II) modeset(0): h_active: 1280  h_sync: 1328  h_sync_end 1440 h_blank_end 1688 h_border: 0
[    15.011] (II) modeset(0): v_active: 1024  v_sync: 1025  v_sync_end 1028 v_blanking: 1066 v_border: 0
[    15.011] (II) modeset(0): Ranges: V min: 56 V max: 75 Hz, H min: 31 H max: 83 kHz, PixClock max 145 MHz
[    15.011] (II) modeset(0): Monitor name: AL1716
[    15.011] (II) modeset(0):  ACER
[    15.011] (II) modeset(0): EDID (in hex):
[    15.011] (II) modeset(0): 	00ffffffffffff000472b406301a0000
[    15.011] (II) modeset(0): 	270f010380221b786ec5c5a3574a9c23
[    15.011] (II) modeset(0): 	005054afcf00494f714f818001010101
[    15.011] (II) modeset(0): 	010101010101302a009851002a403070
[    15.011] (II) modeset(0): 	1300520e1100001e000000fd00384b1f
[    15.011] (II) modeset(0): 	530e000a202020202020000000fc0041
[    15.011] (II) modeset(0): 	4c313731360a202020202020000000fe
[    15.011] (II) modeset(0): 	00414345520a2020202020202020009f
[    15.011] (II) modeset(0): Printing probed modes for output HDMI-1
[    15.011] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz UeP)
[    15.011] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    15.011] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[    15.012] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    15.012] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    15.012] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    15.012] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    15.012] (II) modeset(0): Modeline "832x624"x75.0   53.21  832 872 960 1088  624 625 628 652 -hsync +vsync (48.9 kHz)
[    15.012] (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    15.012] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    15.012] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    15.012] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    15.012] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    15.012] (II) modeset(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    15.012] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    15.012] (II) modeset(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    15.012] (II) modeset(0): EDID for output HDMI-2
[    15.012] (II) modeset(0): Output HDMI-1 connected
[    15.012] (II) modeset(0): Output HDMI-2 disconnected
[    15.012] (II) modeset(0): Using user preference for initial modes
[    15.012] (II) modeset(0): Output HDMI-1 using initial mode 1280x1024 +0+0
[    15.012] (**) modeset(0): Using gamma correction (2.2, 2.2, 2.2)
[    15.012] (**) modeset(0): Display dimensions: (340, 270) mm
[    15.012] (**) modeset(0): DPI set to (95, 96)
[    15.013] (II) Loading sub module "fb"
[    15.013] (II) LoadModule: "fb"
[    15.013] (II) Module "fb" already built-in
[    15.236] (==) modeset(0): Backing store enabled
[    15.236] (==) modeset(0): Silken mouse enabled
[    15.432] (II) modeset(0): Output HDMI-1 wants gamma correction (2.2, 2.2, 2.2)
[    15.432] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    15.433] (II) modeset(0): Output HDMI-1 wants gamma correction (2.2, 2.2, 2.2)
[    15.434] (**) modeset(0): DPMS enabled
[    15.434] (II) modeset(0): [DRI2] Setup complete
[    15.434] (II) modeset(0): [DRI2]   DRI driver: vc4
[    15.434] (II) modeset(0): [DRI2]   VDPAU driver: vc4
[    15.434] (II) Initializing extension Generic Event Extension
[    15.435] (II) Initializing extension SHAPE
[    15.436] (II) Initializing extension MIT-SHM
[    15.436] (II) Initializing extension XInputExtension
[    15.442] (II) Initializing extension XTEST
[    15.443] (II) Initializing extension BIG-REQUESTS
[    15.444] (II) Initializing extension SYNC
[    15.444] (II) Initializing extension XKEYBOARD
[    15.445] (II) Initializing extension XC-MISC
[    15.446] (II) Initializing extension SECURITY
[    15.446] (II) Initializing extension XFIXES
[    15.447] (II) Initializing extension RENDER
[    15.448] (II) Initializing extension RANDR
[    15.449] (II) Initializing extension COMPOSITE
[    15.449] (II) Initializing extension DAMAGE
[    15.450] (II) Initializing extension MIT-SCREEN-SAVER
[    15.451] (II) Initializing extension DOUBLE-BUFFER
[    15.451] (II) Initializing extension RECORD
[    15.452] (II) Initializing extension DPMS
[    15.452] (II) Initializing extension Present
[    15.453] (II) Initializing extension DRI3
[    15.454] (II) Initializing extension X-Resource
[    15.454] (II) Initializing extension XVideo
[    15.455] (II) Initializing extension XVideo-MotionCompensation
[    15.455] (II) Initializing extension SELinux
[    15.455] (II) SELinux: Disabled on system
[    15.455] (II) Initializing extension GLX
[    15.522] (II) AIGLX: Loaded and initialized vc4
[    15.523] (II) GLX: Initialized DRI2 GL provider for screen 0
[    15.523] (II) Initializing extension XFree86-VidModeExtension
[    15.523] (II) Initializing extension XFree86-DGA
[    15.523] (II) Initializing extension XFree86-DRI
[    15.523] (II) Initializing extension DRI2
[    15.530] (II) modeset(0): Damage tracking initialized
[    15.530] (II) modeset(0): Setting screen physical size to 340 x 270
[    15.764] (II) config/udev: Adding input device HID 05f3:0007 (/dev/input/event0)
[    15.764] (**) HID 05f3:0007: Applying InputClass "libinput keyboard catchall"
[    15.764] (II) LoadModule: "libinput"
[    15.764] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    15.823] (II) Module libinput: vendor="X.Org Foundation"
[    15.823] 	compiled for 1.21.1.21, module version = 1.5.0
[    15.823] 	Module class: X.Org XInput Driver
[    15.823] 	ABI class: X.Org XInput driver, version 24.4
[    15.823] (II) Using input driver 'libinput' for 'HID 05f3:0007'
[    15.823] (**) HID 05f3:0007: always reports core events
[    15.823] (**) Option "Device" "/dev/input/event0"
[    15.873] (II) event0  - HID 05f3:0007: is tagged by udev as: Keyboard
[    15.874] (II) event0  - HID 05f3:0007: device is a keyboard
[    15.874] (II) event0  - HID 05f3:0007: device removed
[    15.888] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.0/0003:05F3:0007.0001/input/input0/event0"
[    15.888] (II) XINPUT: Adding extended input device "HID 05f3:0007" (type: KEYBOARD, id 6)
[    15.888] (**) Option "xkb_model" "pc105"
[    15.888] (**) Option "xkb_layout" "us"
[    15.893] (II) event0  - HID 05f3:0007: is tagged by udev as: Keyboard
[    15.894] (II) event0  - HID 05f3:0007: device is a keyboard
[    15.896] (II) config/udev: Adding input device HID 05f3:0007 System Control (/dev/input/event1)
[    15.896] (**) HID 05f3:0007 System Control: Applying InputClass "libinput keyboard catchall"
[    15.896] (II) Using input driver 'libinput' for 'HID 05f3:0007 System Control'
[    15.897] (**) HID 05f3:0007 System Control: always reports core events
[    15.897] (**) Option "Device" "/dev/input/event1"
[    15.901] (II) event1  - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[    15.901] (II) event1  - HID 05f3:0007 System Control: device is a keyboard
[    15.902] (II) event1  - HID 05f3:0007 System Control: device removed
[    15.912] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.1/0003:05F3:0007.0002/input/input1/event1"
[    15.912] (II) XINPUT: Adding extended input device "HID 05f3:0007 System Control" (type: KEYBOARD, id 7)
[    15.912] (**) Option "xkb_model" "pc105"
[    15.912] (**) Option "xkb_layout" "us"
[    15.917] (II) event1  - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[    15.917] (II) event1  - HID 05f3:0007 System Control: device is a keyboard
[    15.920] (II) config/udev: Adding input device HID 05f3:0007 Consumer Control (/dev/input/event2)
[    15.920] (**) HID 05f3:0007 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    15.920] (II) Using input driver 'libinput' for 'HID 05f3:0007 Consumer Control'
[    15.920] (**) HID 05f3:0007 Consumer Control: always reports core events
[    15.920] (**) Option "Device" "/dev/input/event2"
[    15.924] (II) event2  - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[    15.925] (II) event2  - HID 05f3:0007 Consumer Control: device is a keyboard
[    15.925] (II) event2  - HID 05f3:0007 Consumer Control: device removed
[    15.940] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.1/0003:05F3:0007.0002/input/input2/event2"
[    15.940] (II) XINPUT: Adding extended input device "HID 05f3:0007 Consumer Control" (type: KEYBOARD, id 8)
[    15.940] (**) Option "xkb_model" "pc105"
[    15.940] (**) Option "xkb_layout" "us"
[    15.945] (II) event2  - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[    15.945] (II) event2  - HID 05f3:0007 Consumer Control: device is a keyboard
[    15.948] (II) config/udev: Adding input device Microsoft Microsoft Trackball Explorer® (/dev/input/event3)
[    15.948] (**) Microsoft Microsoft Trackball Explorer®: Applying InputClass "libinput pointer catchall"
[    15.948] (II) Using input driver 'libinput' for 'Microsoft Microsoft Trackball Explorer®'
[    15.948] (**) Microsoft Microsoft Trackball Explorer®: always reports core events
[    15.948] (**) Option "Device" "/dev/input/event3"
[    16.007] (II) event3  - Microsoft Microsoft Trackball Explorer®: is tagged by udev as: Mouse Trackball
[    16.008] (II) event3  - Microsoft Microsoft Trackball Explorer®: device is a pointer
[    16.008] (II) event3  - Microsoft Microsoft Trackball Explorer®: device removed
[    16.032] (II) libinput: Microsoft Microsoft Trackball Explorer®: Step value 0 was provided, libinput Fallback acceleration function is used.
[    16.032] (**) Option "ButtonMapping" "8 9 3 4 5 6 7 1 2 10"
[    16.032] (**) Option "config_info" "udev:/sys/devices/platform/scb-bus@fc000000/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/0003:045E:0024.0003/input/input3/event3"
[    16.032] (II) XINPUT: Adding extended input device "Microsoft Microsoft Trackball Explorer®" (type: MOUSE, id 9)
[    16.033] (**) Option "AccelerationScheme" "none"
[    16.033] (**) Microsoft Microsoft Trackball Explorer®: (accel) selected scheme none/0
[    16.033] (**) Microsoft Microsoft Trackball Explorer®: (accel) acceleration factor: 2.000
[    16.033] (**) Microsoft Microsoft Trackball Explorer®: (accel) acceleration threshold: 4
[    16.092] (II) event3  - Microsoft Microsoft Trackball Explorer®: is tagged by udev as: Mouse Trackball
[    16.093] (II) event3  - Microsoft Microsoft Trackball Explorer®: device is a pointer
[    16.095] (II) config/udev: Adding input device Microsoft Microsoft Trackball Explorer® (/dev/input/mouse0)
[    16.095] (II) No input driver specified, ignoring this device.
[    16.095] (II) This device may have been added with another device file.
[    16.098] (II) config/udev: Adding input device vc4-hdmi-0 (/dev/input/event4)
[    16.098] (**) vc4-hdmi-0: Ignoring device from InputClass "disable touch stick"
[    16.099] (II) config/udev: Adding input device vc4-hdmi-0 HDMI Jack (/dev/input/event5)
[    16.099] (**) vc4-hdmi-0 HDMI Jack: Ignoring device from InputClass "disable touch stick"
[    16.100] (II) config/udev: Adding input device vc4-hdmi-1 (/dev/input/event6)
[    16.100] (**) vc4-hdmi-1: Ignoring device from InputClass "disable touch stick"
[    16.101] (II) config/udev: Adding input device vc4-hdmi-1 HDMI Jack (/dev/input/event7)
[    16.101] (**) vc4-hdmi-1 HDMI Jack: Ignoring device from InputClass "disable touch stick"
[    16.116] (II) modeset(0): Disabling kernel dirty updates, not required.
[    29.737] (II) modeset(0): EDID vendor "ACR", prod id 1716
[    29.737] (II) modeset(0): Using hsync ranges from config file
[    29.738] (II) modeset(0): Using vrefresh ranges from config file
[    29.738] (II) modeset(0): Printing DDC gathered Modelines:
[    29.738] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[    29.738] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    29.738] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    29.738] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    29.738] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    29.738] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    29.738] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    29.738] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    29.738] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    29.738] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    29.738] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    29.738] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    29.738] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    29.738] (II) modeset(0): Modeline "832x624"x75.0   53.20  832 872 960 1088  624 625 628 652 -hsync +vsync (48.9 kHz e)
[    29.738] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   534.165] (II) event0  - HID 05f3:0007: device removed
[   534.188] (II) event1  - HID 05f3:0007 System Control: device removed
[   534.214] (II) event2  - HID 05f3:0007 Consumer Control: device removed
[   534.258] (II) event3  - Microsoft Microsoft Trackball Explorer®: device removed
[   534.309] (II) AIGLX: Suspending AIGLX clients for VT switch
[   534.309] (II) AIGLX: Resuming AIGLX clients after VT switch
[   534.342] (II) modeset(0): EDID vendor "ACR", prod id 1716
[   534.342] (II) modeset(0): Using hsync ranges from config file
[   534.342] (II) modeset(0): Using vrefresh ranges from config file
[   534.342] (II) modeset(0): Printing DDC gathered Modelines:
[   534.342] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[   534.342] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   534.342] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   534.342] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   534.342] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   534.342] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   534.342] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   534.342] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   534.342] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   534.342] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   534.342] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   534.342] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   534.343] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   534.343] (II) modeset(0): Modeline "832x624"x75.0   53.20  832 872 960 1088  624 625 628 652 -hsync +vsync (48.9 kHz e)
[   534.343] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   534.407] (II) modeset(0): EDID vendor "ACR", prod id 1716
[   534.407] (II) modeset(0): Using hsync ranges from config file
[   534.407] (II) modeset(0): Using vrefresh ranges from config file
[   534.407] (II) modeset(0): Printing DDC gathered Modelines:
[   534.407] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[   534.407] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   534.407] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   534.407] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   534.407] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   534.407] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   534.407] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   534.407] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   534.407] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   534.407] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   534.407] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   534.407] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   534.407] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   534.407] (II) modeset(0): Modeline "832x624"x75.0   53.20  832 872 960 1088  624 625 628 652 -hsync +vsync (48.9 kHz e)
[   534.407] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   534.410] (II) event0  - HID 05f3:0007: is tagged by udev as: Keyboard
[   534.410] (II) event0  - HID 05f3:0007: device is a keyboard
[   534.413] (II) event1  - HID 05f3:0007 System Control: is tagged by udev as: Keyboard
[   534.413] (II) event1  - HID 05f3:0007 System Control: device is a keyboard
[   534.416] (II) event2  - HID 05f3:0007 Consumer Control: is tagged by udev as: Keyboard
[   534.417] (II) event2  - HID 05f3:0007 Consumer Control: device is a keyboard
[   534.477] (II) event3  - Microsoft Microsoft Trackball Explorer®: is tagged by udev as: Mouse Trackball
[   534.477] (II) event3  - Microsoft Microsoft Trackball Explorer®: device is a pointer
[   534.629] (II) event0  - HID 05f3:0007: device removed
[   534.664] (II) event1  - HID 05f3:0007 System Control: device removed
[   534.708] (II) event2  - HID 05f3:0007 Consumer Control: device removed
[   534.724] (II) event3  - Microsoft Microsoft Trackball Explorer®: device removed
[   534.759] (II) UnloadModule: "libinput"
[   534.763] (II) UnloadModule: "libinput"
[   534.860] (II) Server terminated successfully (0). Closing log file.
This log was created with both card devices available.
#16 2026-08-30 11:07:04
Re: [SOLVED] Xorg error on Devuan freia
The Xorg run log looks perfectly ideal smile  and yes, BusID is for PCI address selection only; I think it might be possible to declare a PrimaryGPU option in an OutputClass section (replacing the Device section I think) with a MatchDriver directive (perhaps MatchDriver "V3D"), but I didn't want to pursue that line of thought. Check man xorg.conf.
The gnome-map issue is at "user level"; the program tries to allocate GPU memory and fails. My googling (or DuckDuckGo-ing actually) led to the raspian(?) solution of adding gpu_mem=512 in some config.txt file somewhere, or via the program raspi-config. I think that particular setting would let the GPU use 512 Mb of RAM, and the hope is then that that is enough for a mortal.
Some people seemed to refer to the same setting as kernel boot parameter cma=512m. Possibly that's an alternative.
In fact, perhaps either memory setting actually supercedes the "noOutputInitialSize" setting, which also related to the GPU RAM; or maybe they just are two different blisters on the same foot.
#17 2026-08-30 16:50:32
trabant-asb
Success! I had tried gpu_mem before, however it did not change anything, as far as I know it was for the older Raspberry generations only. cma=512m in the kernel's command line however did the trick for me. On boot, the kernel writes out Skipping dt linux-cma default node in favor for "cma=" kernel par at first and once the system is up and running I see that the size of available memory has decreased (in favor of the gpu I think).
In combination with the Option "NoOutputInitialSize" "1640 1312" I could not see any more X or application errors. The interesting thing is that in the broken X setup I could start gnome-maps and all kind of other applications, but it could not display them correctly.
Thanks for looking into that with me. I will continue testing this and report back in a day or two.
#18 2026-08-30 23:50:44
That's very good!
Please "click" on the "SOLVED" button when you think it appropriate.
regards.
#19 2026-08-31 12:22:20
huge thanks and kudos for keeping us posted and especially your success!
#20 2026-09-01 07:42:28
trabant-asb
Works like a charm... :-)
