#1 2026-08-01 11:17:24
gfp
GENUEN time does not change
thanks for all all your work, I enjoy GNU linux libre.
every time I log into Genuen XFCE
the time stays at the last login.
So at first after login
I have to set the time with:
sudo date --set "2026-06-06 3:44"
here is an old time mentioned.
After that I can update and upgrade with:
sudo apt update, sudo apt upgrade
2nd question:
Are there besides XFCE also other desktops in Genuen available?
thanks for help
Gottfried
#2 2026-08-01 11:18:04
gfp
Re: GENUEN time does not change
Sorry I forgot
I have to set the date and the time.
#3 2026-08-02 00:34:38
# hwclock --set --date "2026-06-06 3:44"
# date --set "2026-06-06 3:44"
fake-hwclock is a service designed for boards that do not have a battery or a real hardware clock (such as the Raspberry Pi). What it does is save the time to a text file when the system is shut down and restore exactly that same time when it is switched on. Therefore, I guess that this is causing a conflict with the real clock and freezing the system in the past. I'll try to fix this issue..., maybe disabling fake-hwclock and moving hwclock.sh from the sysinit runlevel to the boot runlevel.
