#1 2026-06-03 18:54:15
StinkyEmptyAfterlife
[SOLVED] Using VMs with Devuan as host
Hello, today I am hoping to get some help with running VMs with Devuan 6 as the host machine. The guest machine is likely to vary a lot depending on the task but typically Linux-based. I was able to install Oracle VirtualBox and create a VM with Debian 13 as guest, but when I try running it I get this message:
VM Name: Debian
VT-x is being used by another hypervisor (VERR_VMX_IN_VMX_ROOT_MODE).
VirtualBox can't operate in VMX root mode. Please disable the KVM kernel extension, recompile your kernel and reboot (VERR_VMX_IN_VMX_ROOT_MODE).
Result Code:
NS_ERROR_FAILURE (0x80004005)
Component:
ConsoleWrap
Interface:
IConsole {6ac83d89-6ee7-4e33-8ae6-b257b2e81be8}
How do I disable the KVM kernel extension & recompile? Looking for a permanent solution hopefully. Thanks!
#2 2026-06-03 19:06:12
Re: [SOLVED] Using VMs with Devuan as host
Oh, and since it seems relevant, my PC runs an Intel processor.
#3 2026-06-03 19:25:59
JayneCobb
I had this issue as well with VBOX. I did the following:
sudo modprobe -r kvm_amd kvm kvm_intel
Then add them to the blacklist in /etc/modprobe.d. If you don.t have a blacklist then create one, blacklist.conf.
Add the lines below, then save and reboot.
blacklist kvm_intel
blacklist kvm_amd
blacklist kvm
Cheers!
#4 2026-06-03 19:37:39
Well, it depends on the kernel you use. No issue with 6.12, starts with 6.13 to I think 6.18 (not 100% sure, I am still on 6.12 and there it still works). Then its fixed again.
#5 2026-06-04 05:35:23
Thanks for the help! Worked just fine. I have some bigger fish to fry now since when I tried to install Devuan to my main PC it got pretty messed up hmm
