#1 2026-05-17 17:31:52
Big_Hat
[SOLVED] New Devuan user, strugging to get the sound working
Hello, I've recently installed Devuan, after a year with Linux Mint, looking to get away from systemd/age verification etc.
Installing and setting-up Devuan (with sysvinit and the Cinnamon DE) has has gone pretty well so far, except that the sound has only ever worked once - and didn't work the next time I rebooted :-(
First I tried the instructions in the Release Notes to get Pipewire working, which didn't help unfortunately.  I didn't have a ~/.xsessionrc file, so pasted the three lines indicated into a blank new file - but noticed that the ~/.profile file when open in Geany had the if/then/fine/continue/fi etc in bold, whereas the .xsessionrc file didn't - so I'm not sure if there was a problem with the file.  Neither file was set to be executable.
I then thought I'd use pulseaudio and pavucontrol, as I do on Mint, so installed that - but couldn't get it to work either.
Then I removed pulseaudio/pavu, and followed the instructions to set up pipewire in this forum post https://dev1galaxy.org/viewtopic.php?pid=56220#p56220 but with no success.
Now I'm at my wits' end, and would be very grateful if someone could help me get a working sound configuration, please?
#2 2026-05-17 18:30:01
Re: [SOLVED] New Devuan user, strugging to get the sound working
Welcome to dev1galaxy.
What worked for me on my Excalibur with Cinnamon on sysvinit, basically the same setup you have:
apt install pipewire-audio
Edit the users .xsessionrc and add:
# kill any existing pipewire instance to restore sound
pkill -u "$USER" -fx /usr/bin/pipewire-pulse 1>/dev/null 2>&1
pkill -u "$USER" -fx /usr/bin/wireplumber 1>/dev/null 2>&1
pkill -u "$USER" -fx /usr/bin/pipewire 1>/dev/null 2>&1
exec /usr/bin/pipewire &
# wait for pipewire to start before attempting to start related daemons
while [ "$(pgrep -f /usr/bin/pipewire)" = "" ] ; do
   sleep 1
done
exec /usr/bin/wireplumber &
exec /usr/bin/pipewire-pulse &
The file is a config file, does not need to be executable. Octal rights 644.
If you have more than one user you have to repeat that for these too.
#3 2026-05-17 19:20:57
Big_Hat
Many thanks for your welcome, rolfie, and your reply.
I followed your advice, and ran
which came back that everything was installed and up to date.
I then added your lines to ~/.xsessionrc, checked the file permissions (664), and restarted the computer.  Unfortunately, when I logged into Devuan, the screen froze as black with just the mouse pointer showing.
I had to hold the power button down to turn off the computer, then booted into Linux Mint and hashed out the addition to .xsessionrc.  This time Devuan logged in fine, but with no sound as before.
I'm wondering, what does your entire .xsession file look like, please?  With your lines added, mine was
if [ -f ~/.profile ]; then
    . ~/.profile
fi
   sleep 1
done
the first 3 lines are from the Devuan Excalibur release notes.
Also, my ~/.profile file is this, in case it makes a difference - again the last section I added from the Devuan Excalibur release notes
# ~/.profile: executed by the command interpreter for login shells.
# This file is not read by bash(1), if ~/.bash_profile or ~/.bash_login
# exists.
# see /usr/share/doc/bash/examples/startup-files for examples.
# the files are located in the bash-doc package.
# the default umask is set in /etc/profile; for setting the umask
# for ssh logins, install and configure the libpam-umask package.
#umask 022
# if running bash
if [ -n "$BASH_VERSION" ]; then
    # include .bashrc if it exists
    if [ -f "$HOME/.bashrc" ]; then
	. "$HOME/.bashrc"
    fi
fi
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
    PATH="$HOME/bin:$PATH"
fi
if [ -d "$HOME/.local/bin" ] ; then
    PATH="$HOME/.local/bin:$PATH"
fi
# Pipewire Audio snippet from Devuan release notes
if [ "$XDG_RUNTIME_DIR" = "/run/user/$(id -u)" ] ; then
                psess_pids=
                for p in pipewire wireplumber pipewire-pulse ; do
                command -v $p >/dev/null || continue
                    pgrep --exact --uid $USER $p >/dev/null && continue
                    $p &
                    psess_pids="$! ${psess_pids}"
                done
                [ "$psess_pids" ] && trap "kill $psess_pids" EXIT
fi
#4 2026-05-17 19:53:36
I guess the problem is that you are mixing several approaches, and they don't go together very well. I have taken my setup from here: https://dev1galaxy.org/viewtopic.php?pid=45747#p45747. This is the initial Daedalus approach. The same thread then talks about different approaches and daemons ... never fully understood the differences, and never changed my setup. It works 18 months now.
I have simply upgraded my Daedalus installation to Excalibur, ignored the release notes, and the old stuff simply works. Also on my travelling laptop.
You followed a different guide, and I guess you have to undo that stuff first of all. Sorry, I should have mentioned that.
I got the same snippet in front of my .xsessionrc:
    . ~/.profile
fi
But according to my notes this was because of some conf change for gnupg. I don't think this hurts.
I would remove or comment out the addition from the release note in .profile. Give it a try.
#5 2026-05-18 01:05:12
rbit
If you installed Cinnamon desktop using the excalibur 6.1.1 iso set, attempts to have some kind of sound working after installation.  Sorry it didn't work out for you.  The installer creates /etc/xdg/autostart/pipewire.desktop file that attempts to run daemon to start pipewire, pipewire-pulse, and wireplumber.  Since this method isn't working on your system, before attempting other ways of getting these processes to start up, you should first disable the xdg autostart.  You can do this in the Cinnamon GUI: Menu -> System Settings -> Startup Applications, turn the slider for Pipewire to the off position.  Then you may try other methods of starting pipewire, if that's what you want to use.
#6 2026-05-21 15:11:08
Big_Hat
Thank you both for your replies, rolfie and rbit, they were really helpful.  I’m sorry it’s taken me so long to reply, work’s been hectic this week.
Your advice rolfie about me mixing several approaches made a lot of sense, and I decided to get around this by reinstalling Devuan, and noting down what I then did.
And your advice rbit was also really helpful, that on Cinnamon the sound should work from the installation without needing scripts/adjustments etc.
So I re-installed Devuan to a new partition, booted it up, didn't fiddle with anything but played a Youtube video – and the sound worked! :-)  I have done a few other tests with offline video/audio files, and the sound keeps working, I haven’t needed to do the adjustments in the release notes or anything.
I found it didn’t help that there were no system sounds set on Devuan, so I copied the system sounds off my Mint installation, and set them up on Devuan.  This reassures me when I log into my laptop, as every time I’m greeted by the login chime – so I know the sound is still working.
Thank you again for your help, I really appreciate it :-)
