#1 2026-05-08 22:01:56
Anonymous Goldfish
[SOLVED] any way of getting cdemu working without system d
any help on compiling this to work without system d
thanks
#2 2026-05-09 19:00:43
Re: [SOLVED] any way of getting cdemu working without system d
cdemu works fine without systemd, it's only needed for dbus activation of the daemon - which you can do any way you would usually start a user daemon.
If the debian package (wherever you got it, since it's not in the stable repos AFAIK) has a depend on systemd, remove it and rebuild the package... Or just install cdemu from source to begin with.
#3 2026-05-09 22:06:44
Anonymous Goldfish
thank you steve_v
i will compile it and give it a go
#4 2026-05-12 01:58:42
Anonymous Goldfish
update it works just fine
