#1 2026-05-02 09:14:05
Giorgos
[SOLVED] How can I skip a kernel update?
Hi!  :-)
The last kernel update crashed my system, and I had to restore a previous backup.
(I'm at oldstable).
How can I skip the kernel update? (while continue installing the rest ones).
I tried Synaptic or from console (with apt mark), but nothing worked so far.
TIA!!!  :-)
#2 2026-05-02 10:55:24
Re: [SOLVED] How can I skip a kernel update?
as far as I know, just setting the current kernel version on hold should do the trick (not sure about the generic linux-image-amd64 package).
## show the installed version(s):
$ uname -a
## and/or
$ apt list --installed | grep linux-image
$ apt-mark hold linux-image-$VERSION-amd64
## or:
$ apt-mark hold linux-image-$VERSION-amd64 linux-headers-$VERSION-amd64  linux-headers-$VERSION-common
#3 2026-05-02 11:54:58
Giorgos
THANKS delgado for your post!  :-)
I already marked them as "on hold", thus:
#apt-mark hold linux-image-6.1.0-44-amd64 linux-headers-6.1.0-44-amd64  linux-headers-6.1.0-44-common
linux-image-6.1.0-44-amd64 was already set on hold.
linux-headers-6.1.0-44-amd64 was already set on hold.
linux-headers-6.1.0-44-common was already set on hold.
However, the new kernel, keeps coming:
#apt upgrade
Calculating upgrade... Done
linux-headers-6.1.0-45-amd64 linux-headers-6.1.0-45-common linux-image-6.1.0-45-amd64
linux-compiler-gcc-12-x86 linux-headers-amd64 linux-image-amd64 linux-kbuild-6.1
4 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 84.7 MB of archives.
After this operation, 472 MB of additional disk space will be used.
Do you want to continue? [Y/n] N
Abort.
#4 2026-05-02 12:22:11
Do also set on hold: linux-headers-amd64 linux-image-amd64
#5 2026-05-02 12:27:24
Giorgos
That did the trick!
MANY THANKS guys, for your help!!!  :-)
