#1 2026-04-28 11:28:29
druid
[SOLVED] Devuan+dwm+xinitrc: how to start properly?
Hello everyone,
I installed Devuan without a desktop environment, downloaded and compiled dwm, which I'm starting via .xinitrc.
I'd like to know the recommended command to launch dwm, is it:
dbus-run-session -- /usr/local/bin/dwm
or
dbus-launch --exit-with-session /usr/local/bin/dwm
or maybe a third one?
Thank you in advance for your answers.
#2 2026-04-28 12:08:28
unixuser
Re: [SOLVED] Devuan+dwm+xinitrc: how to start properly?
hi, do you have specific use of dbus there ? the normal way is to put dwm at the end of .xinitrc.
exemple :
setxkbmap -option caps:swapescape &
xset s 480 dpms 600 600 600 &
xset b off &
dwm
dwm (or any wm) MUST BE AT THE END
edit : i assume dwm is in you PATH, so you don't need to write the full path (/usr/bin/... or anything else)
#3 2026-04-28 12:18:56
druid
Yes, I use Thunar as graphical file manager and dbus allows it to display other disks.
#4 2026-04-28 12:41:52
unixuser
Yes ok but dbus is launched at boot time; so just start dwm as I suggested, doesn't it work ?
#5 2026-04-28 13:03:08
druid
No, it doesn't. I think that you must create a dbus session within .xinitrc to benefit from this service...
#6 2026-04-28 13:19:34
unixuser
No... I use this since decades lol... did you downloaded xorg-xinit ? how do you startx ?
#7 2026-04-28 13:31:26
druid
Like this: (.xinitrc)
setxkbmap be -option terminate:ctrl_alt_bksp
numlockx
xset b off
xset dpms 720 900 1200
xsetroot -solid "#282828"
redshift -m randr -t 4500:3200 &
dunst &
xfce4-clipman &
gnome-keyring-daemon --start --components=pkcs11
gnome-keyring-daemon --start --components=secrets
gnome-keyring-daemon --start --components=ssh
lxpolkit &
EIP=$(curl -s ifconfig.me)
HOST=$(hostname -s)
LIP=$(hostname -I)
showhomefreespace() {
	df -h $HOME | tail -n 1 | awk '{print $4}'
while true; do
    xsetroot -name " 💻 $HOST   $LIP  🌍 $EIP   $(showhomefreespace)  $(date +' %a %e %B %Y   %H:%M') "
    sleep 1m
done &
#exec /usr/local/bin/dwm
#dbus-run-session -- /usr/local/bin/dwm
I should clarify that X11 and dwm launch correctly. What doesn't work without creating a dbus session is mounting local disks in Thunar.
#8 2026-04-28 13:52:23
unixuser
I mean, do you use a display manager or do you start X from .bash_profile
#9 2026-04-28 14:08:42
druid
No, I start X from tty with the startx command (no lightdm)...
#10 2026-04-28 21:39:25
laurie_dev1
If it works with dbus-launch --exit-with-session /usr/local/bin/dwm then it must be ok.
My only suggestion would be to leave the full path out "/usr/local/bin/" and make sure your user has path settings correct in .profile and .profile is getting sourced correctly.
What does echo $PATH look like when you are logged in?
This is how i start dwm but i dont use elogind, polkit or gvfs stuff and it just works.
dbus-launch gets started on boot.
xrandr --output HDMI-2 --mode 1920x1080 --rate 144.00
xrdb -merge ~/.Xresources &
sxhkd &
slstatus &
exec startdwm
#11 2026-04-28 22:46:13
druid
Not being a native English speaker, I probably didn't explain myself well.
To summarize:
- dwm works correctly with or without dbus.
- Thunar doesn't display local disks without a dbus session.
My question was which dbus command is appropriate to launch dwm (dbus-run-session or dbus-launch).
Thank you for your help.
#12 2026-04-29 01:18:54
laurie_dev1
Im fairly certain dbus-launch --exit-with-session dwm might be the correct way?
dbus-user-session seems to be a systemd package.
simple interprocess messaging system (systemd --user integration)
https://packages.debian.org/trixie/dbus-user-session
Im no expert, but maybe if you run thunar as a daemon the local disks will display without the need to call dbus-launch in .xinitrc. As if you have dbus-x11 installed, dbus-launch will automatically start upon boot.
in your .xinitrc
thunar --daemon
#13 2026-05-01 21:25:49
druid
I've tried without 'dbus-launch' and with 'thunar --daemon' -> no local disks in Thunar.
It seems that the only way is to use 'dbus-launch --exit-with-session'...
Thank you for your help!
#14 2026-05-09 01:28:43
Anonymous Goldfish
i have a light setup without a desktop as well
my xinitrc is just
picom --backend glx --vsync & xrandr --output eDP-1 --brightness 0.7 --mode 1280x720 & dwm
