#1 2026-04-21 19:01:50
T480 suspend issues on devuan's current stable
For whatever reason, I used to not have this problem, but now every time I suspend for a certain length, probably an hour or more...
I can no longer press power or function key to get it to come back online on my T480.
I end up having to shut down the computer by force. Really... really annoying.
Any ideas what could be causing this?
I am 100% stumped.
I wonder if this is a libreboot issue or a T480 issue.
My guess is probably the first, but I don't know what specifically would cause this.
#2 2026-04-22 03:54:47
goat
Re: T480 suspend issues on devuan's current stable
It's possible it's the coreboot firmware.  You can rule out software by trying different OSes and OS versions temporarily.  I've run into a lot of regressions in my day, all across the board...  So, it's possible it could be a software thing.
Hardware issues are always a pain to try and figure out..  GL
Hopefully the stability and functionality of those 7/8th gen intel ports will only continue to improve over time.
#3 2026-04-22 16:23:05
blackhole
We're all 100% stumped too.
Assuming you have already searched and researched, I suggest asking the libreboot people if there are any known issues with suspend on that model?
#4 2026-04-22 17:06:52
@blackhole @goat
I have to agree it probably is...
