#1 Today 13:21:45
godane
bazinga-devuan-20260320
Here is a update of my bazinga devuan i made awhile back. This includes the full debian, devuan and its merged repos. The default desktop is lxde.
You need to make/have a Ventoy drive to use this. You will need to make bazinga-devuan-20260320 folder and put the .sb file there. The sbo files can go into modpath/apt-mirror folder on the root of your Ventoy partition. You will also need a modules and rootcopy folder in bazinga-devuan-20260320 folder.
https://archive.org/download/bazinga-devuan-20260320
I hope this helps.
