I've been trying to install a few packages for a couple hours and I keep getting messages for different files like:
Err:17 http://deb.devuan.org/merged excalibur/main amd64 yelp-xsl all 42.1-4
temporary failure resolving 'deb.devuan.org'
What's odd is I see other files on that same server it did find...
at the end it gives "failed to fetch" errors for each of the packages with problems.
Sorry, I didn't know if this was the right place to ask...
This is a long-running issue with DNS, and has been happening for at least a year. It happened to me several times. I don't know the exact cause or if the admins have tried anything serious to fix it. You can fix it by switching your DNS server to one of google's -- 8.8.8.8 or 8.8.4.4 -- those seem to always resolve the address correctly. Alternatively, you can change your sources.list file to point to a local mirror, such as ca.deb.devuan.org.
Previous posts about it:
/viewtopic.php?id=7416
/viewtopic.php?id=7066
Ok, thanks. I did search here for deb.devuan.org before asking. I wonder why it didn't find those posts? Ahhhh, its been an ongoing issue a long time, so it was 3 pages back. Very odd...
Thanks for clueing me in. I never had the problem with the older release.
That fixed it!
