#1 2026-01-03 15:08:38
erdos
display settings window keeps replicating
greetings
I'm running devuan 5 with XFCE,  and the display settings window repeatedly opens itself, especially after being idle for a while.
I keeps my pc (NUC) on for the past few days without using it, and after turning on the monitor, there are a dozen display settings windows opened on the screen.
any advice?
#2 2026-01-03 21:37:14
Re: display settings window keeps replicating
check the logs?
#3 2026-01-04 15:56:36
I have no idea really what's going on, but when troubleshooting always rule out the simple stuff first. Do you have a keyboard shortcut of some kind for the display settings gui? If so, sticky keys can cause weird behavior.
#4 2026-01-04 19:27:53
In Xfce monitor settings under Advanced, there some check boxes for screens. Are they checked? Or unchecked?
