#1 2026-01-01 12:45:39
onedevone
Fail With DOT
For years I have been managing Artix, but I had never had a success on Devuan 5. Nor do I know how to set up network on Devuan.
What is happening:
1. I put DOT capable IPs in KDEs network manager GUI. Testing shows, that not DOT is used. Plain queries sad((. It should be default, but isn't. It's been buffling me for years that you don't do this by default. This bears the question if you use your own creationa at all. If you were then you wouldn't allow plain text DNS querries, would you? I don't understand this behavior of nm.
2. I looked for "stubby-openrc" but cannot find it. I also theoreticaly could "cap_net_bind blah blah" reprogramm it (systemd has stubby working out of the box!). But I'm stuck and I don't want to dwell on it.
HOW do you (step by step) do stubby on open-rc Devuan 6? THIS IS A COMPLETE SHOWSTOPPER FOR ME. I cannot continue the setup until I have this issue resolved.
DOT via stubby works like charm on Artix runit.
How do you do this on Devuan 6 Opne-RC? Your help is going to be immensly appreciated.
Thanks.
#2 2026-01-02 04:22:54
Re: Fail With DOT
What is DOT ?
#3 2026-01-02 05:48:01
Re: Fail With DOT
ralph.ronnquist wrote:
What is DOT ?
DNS over TLS, AKA a somewhat less retarded attempt to break the 'net than DoH, from the usual paranoia crowd who think moving trust from their ISP to some other random entity (usually Google or Cloudflare) is progress.
DNS is handled on my router, because I have a brain.
Then you should probably ask RedHat, Devuan didn't write NetworkMangler.
What makes you think someone else should write your init scripts for you?
The stubby package comes with a sysvinit script, because that's the default init. OpenRC is supported, but you don't get everything handed to you on a silver platter.
If you want an openrc init script, swiping it from Artix will probably work without too much modification. Otherwise, writing your own isn't complicated.
Huh, what a coincidence. Shouting is a complete showstopper for me providing any kind of spoon feeding step-by-step instructions.
With the entitled and confrontational attitude you've displayed in all your posts so far, I'll be surprised if you get much of that.
#4 2026-01-02 06:21:16
HardSun
Re: Fail With DOT
OP reads like some AI slopper someone is posting for shits and giggles from 4chan.
#5 2026-01-02 16:43:33
trinidad
Re: Fail With DOT
https://en.wikipedia.org/wiki/DNS_over_HTTPS
@steve_v   Wow two times in one week you have put a smile on my old face. Thank you!
TC
Often unawares.
#6 2026-01-05 17:45:56
abower
Re: Fail With DOT
The initscript for stubby didn't make it in before the Debian Trixie freeze: https://tracker.debian.org/news/1650899 … erimental/
If anyone wants the current version in Excalibur it might be worth politely indicating on the Debian BTS that there would be demand for a stable backport.
#7 2026-03-06 08:40:01
onedevone
Re: Fail With DOT
Toxic answeres. DOT is not something to be laughed at as is not my alias for wget with PFS for using it among others with Devuan servers.
#8 2026-03-06 08:48:20
Re: Fail With DOT
what is PFS now? Is language too hard to be written in full?
#9 2026-03-07 02:45:11
Re: Fail With DOT
what is PFS
man wget wrote:
       --secure-protocol=protocol
           Choose the secure protocol to be used.  Legal values are auto,
           SSLv2, SSLv3, TLSv1, TLSv1_1, TLSv1_2, TLSv1_3 and PFS.  If
           auto is used, the SSL library is given the liberty of choosing
           the appropriate protocol automatically, which is achieved by
           sending a TLSv1 greeting. This is the default.
           Specifying SSLv2, SSLv3, TLSv1, TLSv1_1, TLSv1_2 or TLSv1_3
           forces the use of the corresponding protocol.  This is useful
           when talking to old and buggy SSL server implementations that
           make it hard for the underlying SSL library to choose the
           correct protocol version.  Fortunately, such servers are quite
           rare.
           Specifying PFS enforces the use of the so-called Perfect
           Forward Security cipher suites. In short, PFS adds security by
           creating a one-time key for each SSL connection. It has a bit
           more CPU impact on client and server.  We use known to be
           secure ciphers (e.g. no MD4) and the TLS protocol. This mode
           also explicitly excludes non-PFS key exchange methods, such as
           RSA.
i.e. more paranoia BS, from someone with likely little idea what it actually does or what attacks it might defend against, since they apparently need "step by step" instructions to write a trivial init script.
Next will be out-of-repo "privacy" browsers, VPNs, and whatever go-fast shiny-new-shit is popular on Arch/Artix right now.
onedevone wrote:
Toxic answeres.
"Toxic" OP, complete with entitlement, shouting, and misguided assertions that your personal preference regarding DNS should be a distro-wide default.
I'm not laughing at DoT, I'm laughing at people who consider it not being enabled by default and integrated into some random GUI a "complete showstopper".
Devuan, like Debian, comes with a standard DNS configuration by default. If you want something else, it's on you to read the documentation and set it up.
Likewise init systems - sysv is the default and best supported. If you want something else, all the parts are available but you get to assemble them.
