#1 2025-12-29 02:44:00
VH
Running Firefox in Firejail
Hello,
I always ran firefox in firejail with Daedalus.
I installed Excalibur and tried to do the same thing but it gives me the error message.
I ran firefox like this:
"admin@MySys:~$firejail --seccomp firefox"
but it gave me errors.  So I ran
"admin@MySys:~$firejail firefox"
but it still gave me errors.  What can I dd?  Below is the result.
admin@MySys:~$ firejail --seccomp firefox
Reading profile /etc/firejail/firefox.profile
Reading profile /etc/firejail/firefox-common.profile
Reading profile /etc/firejail/disable-common.inc
Reading profile /etc/firejail/disable-devel.inc
Reading profile /etc/firejail/disable-exec.inc
Reading profile /etc/firejail/disable-interpreters.inc
Reading profile /etc/firejail/disable-proc.inc
Reading profile /etc/firejail/disable-programs.inc
Reading profile /etc/firejail/whitelist-common.inc
Reading profile /etc/firejail/whitelist-run-common.inc
Reading profile /etc/firejail/whitelist-runuser-common.inc
Reading profile /etc/firejail/whitelist-usr-share-common.inc
Reading profile /etc/firejail/whitelist-var-common.inc
Warning: networking feature is disabled in Firejail configuration file
firejail version 0.9.74
Seccomp list in: !chroot, check list: @default-keep, prelist: unknown,
Parent pid 2812, child pid 2817
Warning: An abstract unix socket for session D-BUS might still be available. Use --net or remove unix from --protocol set.
Error fcopy: invalid ownership for file /etc/localtime
Error: failed to run /run/firejail/lib/fcopy, exiting...
Error: proc 2812 cannot sync with peer: unexpected EOF
Peer 2817 unexpectedly exited with status 1
admin@MySys:~$ firejail firefox
Parent pid 2832, child pid 2836
Error: proc 2832 cannot sync with peer: unexpected EOF
Peer 2836 unexpectedly exited with status 1
#2 2025-12-29 16:08:18
Re: Running Firefox in Firejail
I get the same output as you up until this line:
What does 'ls -l' have to say about that file? (Mine is a symlink owned by root.)
#3 2026-01-02 01:21:26
VH
It says:
lrwxrwxrwx   1 root root      36 Dec 28 09:09 localtime -> /usr/share/zoneinfo/America/New_York
#4 2026-01-02 13:43:07
Same as mine.
lrwxrwxrwx 1 root root 36 Aug 10  2024 /etc/localtime -> /usr/share/zoneinfo/America/New_York
Target file is also owned by root here:
-rw-r--r-- 1 root root 3552 Aug 24 16:12 /usr/share/zoneinfo/America/New_York
Check the size of fcopy, too. I'm running the same version, so it should be the same size.
$ ls -l /usr/lib/x86_64-linux-gnu/firejail/fcopy
-rwx--x--x 1 root root 30968 Apr 20  2025 /usr/lib/x86_64-linux-gnu/firejail/fcopy
Similar problem solved here:
https://discussion.fedoraproject.org/t/ … tes/161848
#5 2026-01-03 11:32:22
I always run my web browser through firejail like this:
firejail  --nogroups --caps.drop=all  --private-tmp --private-dev  --seccomp --noroot --disable-mnt librewolf
#6 2026-03-06 08:29:58
onedevone
Can you confirm that you can run:
$ firejail -seccomp falkon
with all related (profiles) to firejail installed?
Does it fail?
