#1 2025-12-13 14:49:38
gfp
[SOLVED] ublockorigin
I would like to add to Gnuinos
ublockorigin to my icecat/firefox browser.
There is one available but the file is corrupt and can´t be installed.
Is there a way to install ublockorigin?
thanks
gfp
#2 2025-12-13 15:08:18
RedGreen925
Re: [SOLVED] ublockorigin
Go to about:addons in your firefox browser URL entry bar search on uBlock Origin then use the Add to Firefox button to add it, no clue on the icecat I have never used it.
#3 2025-12-13 16:10:53
pcalvert
Which version of Icecat are you using?
Another one is called Luxxle.
#4 2025-12-14 14:10:15
gfp
this does not work because there is no possibility to add some add-ons.
but going to : plugins
there is an option to get extensions via: gnuzilla.gnu.org
oping that there is ublockorigin
but the installation failes, its corrupt.
Also from the firefox website it is corrupt and there is a possibility to download firefox with ublockorigin which I don´t want.
I am using icecat extended support release 102.11.0esr (64-bit)  GNU IceCat gnu-1.0
#5 2025-12-15 08:53:06
pcalvert
Why are you using a version of Icecat that is so old? That version of Icecat is over two years old.
#6 2025-12-15 10:52:09
Librewolf? just a thought.
#7 2025-12-15 11:48:44
gfp
In my Gnuinos /free software there exists only that icecat version, librewolf does not exist.
there is also chromium.
#8 2025-12-15 12:33:45
gfp
how did you find out that is so old?
#9 2025-12-15 13:32:00
#10 2025-12-15 15:16:04
pcalvert
I did a search on DuckDuckGo for "icecat 102.11.0esr" (no quotes) and found this:
“Version 102.11.0, first offered to ESR channel users on May 9, 2023”
Firefox ESR Release Notes
https://www.firefox.com/en-US/firefox/102.11.0/releasenotes/
#11 2025-12-16 00:46:45
I'm building the repo for excalibur. You can find a higher version there:
https://packages.genuen.org
#12 2025-12-16 07:51:31
wert
i cant it to librewolf on alpine linux.
which provided as seperate ublock package by alpine.
Error says: unsigned addon.
firefox(so derivatives) forces so hard on signed addons.
no way a workaround which i am aware of.
about:config stuff not works.
i report it to alpine and librewolf guys.
then i give up firefox and derivatives.
i dont want to bother for some reason.
#13 2025-12-16 13:49:31
gfp
Hi aitor,
I downloaded
icecat-l10n-de_128.14.0-1+6genuen1_all.deb
and during installing it asked me which version of 101 versions.
I pointed to
icecat-l10n-de
after installation it says:
icecat-l10n-de (102.11.0-1)
but that is the old version, isn`t it?
where is my mistake?
#14 2025-12-18 22:20:49
You have only downloaded the language package. You need to install icecat_128.14.0-1+6genuen1_amd64.deb, that will replace the old version 102.11~
