#1 2017-06-27 17:18:39
keos
Retention of packages, i never installed a printer ...
During installation i did not add any packages for a printer system since I haven’t a printer.
While updating the system today ... there is a retention of these packages:
python3-cupshelpers system-config-printer system-config-printer-common
system-config-printer-udev
Then I checked in the synaptic and I found too many packages related to the printer system.
How can I remove all the printer packages of the system from the command line?.
Thank you.
devuan_ascii_2.0.0-rc_amd64_desktop-live.iso  [Xfce]
Graphics: AMD Radeon HD 7640G integrated graphics
GPU: AMD/ATI Trinity [Radeon HD 7640G]
#2 2017-06-27 19:44:59
Re: Retention of packages, i never installed a printer ...
Any reason you didn't just uninstall them while you were in Synaptic?
#3 2017-06-28 12:36:17
keos
Well, i wasn't  sure about it, there are many packages relater to 'printer' ... i removed somes of them,  till now the update is ok, i did my best ...
#4 2017-06-29 19:28:51
Did you ever figure this out?  Synaptic is pretty handy when trying to figure out what you do and don't need.
The system-config-printer stuff can definitely go, that's just a helper gui for configging printers. Once you uninstall that there will likely be other packages that pop up as "autoremoveable", you can uninstall those too. A search on "cups" will list everything cups-related and you can get rid of most if not all of that, search "printer drivers" and uninstall those too.
