#1 2025-11-17 19:50:38
Simple card-switcher for ALSA
So this is another tiny utility to be added to the toolbox for AlsaTune or other interface, for use in a pure alsa system. This is just the rough prototype, I need to do more testing, and more thinking about possible errors and edge-cases and dealing with them.
It would be great if someone with multiple cards could test, I only have one machine that has two cards and I have tested on it and all the single-card machines and this works fine so far. Curious about systems with more cards and those with sub-devices, and also other possible areas to edit that aren't in my config (you can see in the script it changes for hw, plughw, and card).
This works by merely editing ~/.asoundrc, it uses aplay to get the card list, then seds your choice into the config file. It doesn't require re-booting or even re-loading alsa, you just need to close and re-open any running sound instances like your music player after editing is complete. It also creates a backup of your old config, but for testing purposes you should definitely backup whatever you have now for an .asoundrc.
#!/bin/bash
# soundswitch - simple card switcher for AlsaTune that mods ~/.asoundrc
# TO-DO: deal with subdevices? Any other prefixes common in larger asound files
# (like card, hw, or plughw below) that need added?
CARDS=$(aplay -l | grep "^card [0-9]")
CHOICE=$(echo "$CARDS" | yad --list --title="Select Sound Card" \
  --column="Card" --width=550 --height=200 --window-icon=info --button="Apply:0" --button="Cancel:1")
[ $? -ne 0 ] && exit 1
CARD_NUM=$(echo "$CHOICE" | cut -d'|' -f1 | grep -o -E '[0-9]' | head -n 1)
if [ -z "$CARD_NUM" ]; then
  yad --title="Error" --width=300 --center --text-align=center --window-icon=error \
--text="\nNo card was selected. Exiting..." --no-buttons --timeout=4
  exit 1
fi
# Backup
cp ~/.asoundrc ~/.asoundrc.bak
# Replace all card #'s with new card #'s
sed -i "s/hw:[0-9],/hw:$CARD_NUM,/g; s/plughw:[0-9],/plughw:$CARD_NUM,/g; s/card [0-9]/card $CARD_NUM/g" ~/.asoundrc
yad --window-icon=info --text-align=center --width=300 --center --title="Sound" \
--text="\nSound card switched to Card $CARD_NUM\n\nConfig backed up to ~/.asoundrc.bak" --button=gtk-ok:0
#2 2025-11-17 22:12:10
g4sra
Re: Simple card-switcher for ALSA
@greenjeans, like'ish your script...wont work for me, running a corner-case here smile
Suggestions...
Have a default when 'sed' fails/ .asoundrc is empty ore doesn't exist.
Have the window size itself to the number of entries in the list (its annoying to have to keep resizing to make a selection).
#3 2025-11-17 22:30:46
^^Much appreciated!
No .asoundrc is a case, at the start of this endeavour I am writing this to be included in AlsaTune/Vuu-do which will already have an .asoundrc in the system, but like other things I want to also make a generic/portable version that can be used anywhere so that's the next target for functionality.
Window-size: How many cards are in your list? I had envisioned entries for just a couple, can you elaborate? Do I need a scroll function?
#4 2025-11-17 23:40:20
g4sra
Window-size: 11 Lines (four of those are for the GPU alone)
So for a Twin GPU system that could be eight just to start with.
I suppose a scrollbar would cover all bases, don't want to push you to loose the KISS aspect though.
#5 2025-11-18 01:04:54
Ummm, GPU? Ya lost me there somewhere...
#6 2025-11-18 13:06:23
g4sra
Ummm, GPU?
Outputs are capable of carrying digital sound as well as video, so consequently show up in ALSA as individual sink devices.
ls -ld /proc/asound/card1/pcm*
dr-xr-xr-x 4 root root 0 Nov 18 13:07 /proc/asound/card1/pcm3p
dr-xr-xr-x 4 root root 0 Nov 18 13:07 /proc/asound/card1/pcm7p
dr-xr-xr-x 4 root root 0 Nov 18 13:07 /proc/asound/card1/pcm8p
dr-xr-xr-x 4 root root 0 Nov 18 13:07 /proc/asound/card1/pcm9p
#7 2025-11-18 22:20:08
Ahh I gotcha, and that's the kind of thing I need to know to proceed, problem is I don't have a machine around here to test, I get one line on my single-card lappy, two on the library machine...without having a complex machine with multiple outputs around to test on it's gonna make it really hard for me to extend this script. I kinda need to see what things are doing, my methods involve a lot of trial-and-error.
Basic philosophy/use-case is for Vuu-do as it already has a working alsa system, and is meant for simple everyday garden-variety use, just a quick switch for those machines that have an analog and an HDMI output as most of the time the dual-setups default to HDMI as card 0.
At least at this stage...baby steps...but i'd like to pursue it and figure out all the edge-cases and sub-devices and such so I can package it with AT for general use at some point.
#8 2025-11-18 22:45:55
g4sra
With the work you put in for the benefit of others I judge that you are entitled to use the computer science term for that, stepwise refinement smile
I don't mind throwing it at my workstation on occasion and reporting back, I guarantee it is an edge case, my /etc/asound.conf contains 724 lines.
#9 2025-11-20 18:02:43
Hah, I love it...yep...Vuu-do Linux, handcrafted using stepwise refinement and multi-solutional iterations (hit-or-miss). lol
Thanks for the help, I really appreciate it and at some point i'll take you up on the offer to test the next version.
724 lines in asound.conf? Holy crap, that's epic! Yeah I can see where my little script probably wouldn't be good for that system, but it's a dang fine one for testing the limits of it for sure.
#10 2025-11-21 22:50:19
Yeah...so it seems there's no scroll function or auto-sizing for the yad list dialog, at least not in the old versions being used in the repo. For the moment I added a little height. arrgh.
I added an error check to look for ~/.asoundrc right at the start and exit if there isn't one. But now i'm thinking in the error message to also add the ability to copy a simple .asoundrc (to be shipped with the mxeq/AT package) to the users home if there isn't one, and then continuing (or hit cancel to back out of course).
I'll be modding AT a fair bit to add a button for the card-switcher and some other functions including a button to test sound, using aplay to play a .wav file I made, just 3 seconds of a 500hz note, the idea being you can test whatever changes you made with the card-switcher right there in the gui after doing it, without having to cycle audio/video apps on and off.
#11 2025-11-25 17:05:06
After several days of work I have a new version of AlsaTune packaged as of last night, working great for me, but as usual when I wake up the next morning there's always some little detail buzzing in my head, something that could be done better....
So I did some work on this card-switcher script as I mentioned above, enlarged the list window some, and added a check at the start of the script to check for ~/.asoundrc, and if absent it offers to install the generic one included with the package, or you can hit cancel to abort.
The script works great and fast for me and should for the vast majority of simple laptops and desktops. But going forward I want to improve detection and expand a bit, first thing I want to do is deal with sub-devices, that pesky second number, currently this script only swaps the card number.
And thus my dilemma today, should I upload the new AlsaTune as-is so hopefully it can get tested some more, or should I work on the next phase of this script and wait until I have it working before uploading a new AT....*sigh*....
#12 2025-11-25 17:23:12
g4sra
@greenjeans
I have seen someone (fsmithred ?, ralph.ronquist ?) offer someone project space on git.devuan.org.
Your project is quite small (no offence, small is beautiful smile) and therefore would not be a resource gobbler, and I am sure of interest to Devuan users even if unlikely to be qualified for packaging.
Uploading to git.devuan.org. you could concentrate on developing and the interested could follow your progress as (in)frequently as they choose.
Testing and bug reports could also be more forthcoming (at least in theory).
#13 2025-11-25 17:34:12
You're right of course, and I did register an account on Devuan's git a while back, I just haven't messed with it. I have never used git before so I don't know how bad the learning curve is...the thing is I already have multiple learning curves i'm going through and git looks kind of like a pain in the butt, lol.
Packaging locally here using dpkg-deb is fast and uncomplicated. But again you're right that it might get some more testing if I used git.
This is the first year i've branched out to more complex things than simple scripts, so i'm still trying to get a feel for things.
#14 2025-11-25 17:43:24
g4sra
Git is worth it. I have been tweaking the kernel for decades, having git track my changes and re-apply them is a godsend.
I even now use it for full (small) system backups.
#15 2025-11-25 23:33:21
Well I can't help myself, working on a version of this script to extend it to sed device numbers as well as card numbers to .asoundrc. It still won't be suitable for crazy complex things like a 700 line .asoundrc, but should work like a charm for most folks.
Problem is i'm working blind here as I have no machine that has multiple cards with at least one having multiple devices. So I can't fully test.
Also that script I posted above in addition to removing the legacy stuff, can also be swapped to /bin/sh as it's posix compliant, dash is quicker anyway, so that's a win.
#16 2025-11-25 23:51:52
g4sra
@greenjeans will fake devices work for your testing ?
~# modprobe snd-aloop snd-dummy
~# aplay -l
card 3: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
  Subdevices: 2/2
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
card 4: Dummy [Dummy], device 0: Dummy PCM [Dummy PCM]
  Subdevices: 2/2
#17 2025-11-26 01:54:35
Thanks! But what i'm really interested in is how the cards display, i've got the new prototype working but haven't done much testing or done my usual round of error checks yet. But it is working now on both card number and device number. I think that's as far as i'm going to take it for now (baby-steps always), that should work for a huge percentage of users, anything that requires more elaborate measures is beyond the scope of this little utility at least for the time being.
Here's the new script proto, cleaned it up some too and fixed a backup bug (I think):
# soundswitch – Simple utility to change soundcards, part of AlsaTune.
if [ ! -f ~/.asoundrc ]; then
    yad --error --title="Error" --width=400 --center --text-align=center --window-icon=error \
        --text="\nNo config file (.asoundrc) found in user's home.\n\nChoose okay to install a generic version,\nor choose cancel to abort." \
        --button="Okay:0" --button="Cancel:1"
  if [ $? -eq 0 ]; then
    cp /usr/share/mxeq/.asoundrc ~/.asoundrc
  else
    exit 1
  fi
fi
    --column="Choose card/device" --width=550 --height=300 --window-icon=info \
# Extract both card and device number from the selected line
CARD_NUM=$(echo "$CHOICE" | grep -o 'card [0-9]' | cut -d' ' -f2)
DEV_NUM=$(echo "$CHOICE" | grep -o 'device [0-9]' | head -n1 | cut -d' ' -f2)
[ -z "$DEV_NUM" ] && DEV_NUM=0
--text="\nNo card was selected. Exiting..." --no-buttons --timeout=3
  exit 1
fi
cp ~/.asoundrc ~/.asoundrc.bak 2>/dev/null || true
# Replace card/device number(s).
sed -i \
    -e "s/hw:[0-9]*,[0-9]/hw:$CARD_NUM,$DEV_NUM/g" \
    -e "s/plughw:[0-9]*,[0-9]/plughw:$CARD_NUM,$DEV_NUM/g" \
    -e "s/card [0-9]/card $CARD_NUM/g" \
    ~/.asoundrc
yad --title="Sound" --window-icon=info --text-align=center --width=340 --center \
    --text="\nNow using Card $CARD_NUM – Device $DEV_NUM\n\nConfig backed up to ~/.asoundrc.bak" \
    --button=gtk-ok:0
The script as-is isn't what you'd call precision, but there's an elegance to it in brevity of code and taking advantage of simple edits to a config file to completely change behavior.
Philosophy and methodology of use has to be taken into consideration, this little utility does not and should not work for someone with their own custom 500-line .asoundrc, if a user is that far into it then they know how to edit config files. This utility is for the garden-variety user who just wants sound to work and would be put-off by having to manually locate and edit config files that may be complete gibberish to them if they're not a nerd.
