#1 2017-06-26 22:54:28
Simplicio
SLiM - failed to execute login command - bug?
After installing a minimal system using the net install, I wanted to get to a full desktop.
Tried
apt install task-desktop
No errors reported, but after rebooting, if I attempt to log in with a valid non-root username and password, I am not logged in, and I get
Tried installing LXDE
apt-get install LXDE
pressing F1 allows me to cycle between XFCE, Openbox, and LXDE as a window manager, but all give 'failed to execute login command' with valid non-root credentials
if I log in as root, it succeeds, but obviously, that's not a long term solution.
non-root user's home directory has no .xinitrc (neither has root's)
What obvious thing have I missed?
#2 2017-06-27 05:37:18
PeteGozz
Re: SLiM - failed to execute login command - bug?
I had this issue when I removed dbus., logind  and possibly other desktop level helpers.
(thats another story though)
As a guess and test see if reinstalling dbus or logind helps.
apt-get update
apt-get -f install
apt-get install --reinstall  libck-connector0 consolekit dbus -t jessie
also
apt-get install xutils task-lxde-desktop
That may point out any issues with packages from ascii or ceres  sneaking in ???.
Assuming your install is not pure stable / jessie ?
apt-cache show slim
(reveals  dependencies )
apt-cache show task-desktop
## digressions 101 ######################################
meantime
startx
should work for the system default BUT if you dont have any/much X yet this can get a little tricky.
configure a xinitrc so then you have options.
like
xinit openbox -- :2
e.g.
echo "exec openbox-session" >> ~/.xinitrc
(startx is easier and it should use the system confs if they are about.)
(/etc/X11/ ish)
#3 2017-06-27 07:25:35
Simplicio
Thank-you PeteGozz - I shall try your suggestions 'when I get the time', which might not be for a while. I very much appreciate your reply.
#4 2017-06-28 03:36:56
PeteGozz
Slim is an excellent Display Manager
However your not alone in it either refusing to startup or reporting "failed login" (or similar).
short version:
If you install lightdm
and IT works... then we can all go and fix slim
(cause it rocks ! doesn't support remote logins by default)
I suspect that this may be because:
1/  some part of the lower end X environment is not installed (as you move from a minimal system to a full Desktop environment)
or
2/ It needs some Desktop level part of the Auth chain that gets left behind or breaks subtly.
I notice (from the slim source code) that it is built with _either_ pam modules as a front end to auth OR logind stuff.
That may not be flexible enough for many users ... or it could just be a bad guess.
And it does little to solve your problem.
try lightdm instead.
Apparently  its default is "ugly" but effective smile
#5 2017-06-28 06:33:12
Simplicio
Ugly but effective sounds like a realistic description of me. <grin>
#6 2017-07-08 05:16:10
pepa65
On my system with the same problem, I was then trying to start with startx, and it appeared the non-root users couldn't write a keyboard file to /tmp because the permissions were too restrictive. Fixed by:
sudo chmod a+w /tmp
#7 2017-07-08 05:31:46
PeteGozz
Thanks for that.
It not something I would have thought of.
#8 2019-04-25 19:00:13
vasilis74
Thanks @pepa65 !
I had switched to another /tmp partition, but I did it using a live-usb, editing the /etc/fstab file of my system partition. Then I had the "failed to execute login command" problem... Now, after
chmod a+w /tmp
all users login normally.
So, are these the default permissions for /tmp?
drwxrwxrwx   9 root   root  4096 Apr 25 21:46 tmp
#9 2019-04-25 19:29:30
pepa65
The most common default for /tmp is drwxrwxrwt
(The sticky bit is set for others, so people from outside the user/group can't delete other people's files from /tmp, see:
https://serverfault.com/questions/10353 … is-it-used)
#10 2019-04-25 21:48:19
vasilis74
Is it possible that before I manually switched the /tmp partition, its permissions had the t sticky bit? Does t better exist?
I am not at all an expert, just using Linux and modifying my systems to my needs.
#11 2019-04-26 06:09:44
pepa65
If you your permissions are now drwxrwxrwx you can set the sticky bit by sudo chmod o+t /tmp, I think it is better.
