#1 2025-11-08 20:05:16
bai4Iej2need
[SOLVED] dwww Install
Hi
devuan daedalus
Yesterday i installed dwww. Today I looked, if indexes have been built, but have not.
I run /etc/cron.daily/dwww, it quit immediately.
I run /etc/cron.weekly/dwww,
/etc/cron.weekly (git)-[master] # sh -x -v dwww
It asked if swish++ was installed and quit. Of course swish++  was not installed, because it was a recommendation only.
Now I installed swish++, now it builds the index.
Debian Documentation is flawed and dependencies are also flawed both on the website and in the installation.
# $Id: dwww.cron.weekly,v 1.3 2007-12-16 09:56:31 robert Exp $
# This script creates an index of Debian documentation registered
# with doc-base. See dwww-index++(8) man page for details.
# check if swish++ is installed
#test -x /usr/bin/index++ || exit 0
# check if dwww is still installed
test -x /usr/sbin/dwww-index++ || exit 0
+ test -x /usr/sbin/dwww-index++
set -e
+ set -e
# See ionice(1)
[ -x /usr/bin/ionice ] &&  IONICE="/usr/bin/ionice -c3 -t" || IONICE=
+ [ -x /usr/bin/ionice ]
+ IONICE=/usr/bin/ionice -c3 -t
$IONICE dwww-index++ > /dev/null
+ /usr/bin/ionice -c3 -t dwww-index++
exit 0
+ exit 0
sh -x -v dwww  27,13s user 4,01s system 1% cpu 34:07,45 total
However : search in webbrowser no results
Some links work, most not.
broken by design :
#2 2025-11-11 09:09:09
stultumanto
Re: [SOLVED] dwww Install
I recall having similar issues with this system a few years ago; specifically, search would not work. Unfortunately, I wasn't able to find a solution. There is a README file at the source repository which says you need to enable CGI in your local web server, so maybe that is worth a try.
#3 2025-11-11 13:07:39
bai4Iej2need
Yes that was the solution.
It is not enough to install the package(s), debian wants you to do this
a2enmod cgi
by hand, also that it could as well be in a post install script.
as programmed, swish++ should be a package requirement, not a recommendation.
almost solved. Bug or feature ?
broken by design :
