Due to political nonsense with Debian that I've had it up to here with, I'm making the switch from basing my distro, F3OS, a web-filtered famy-friendly distro, on Debian to Devuan. I've got the main edition, with Xfce, uploaded and ready to go. But I'm hung up BAD on an even lighter version I'm trying to create that uses IceWM.
The problem is -- and this, BTW, is how it came from the Devuan repositories (no offense, y'all) -- the IceWM preferences file does have the commands one needs for the reboot, shut down, and suspend logout menu entries -- FOR PEOPLE USING SYSTEMD.
That, of course, ain't gonna do jack for us on Devuan.
Since Google ain't much help on this one, does anyone have any idea what the proper commands are for those of us in sysvinit-land that allow one to do all of the above without having to have administrative privileges in order to do so, for use in a menu?
Thanx in advance,
Fred in West Plains, MO
Depends... Power management tasks have always inherently required superuser privileges, so you'll need some mechanism to grant them.
Are you using elogind? If you are, loginctl takes much the same arguments as with systemd and the default config should allow this for any "active" login session.
Are you using upower + policykit + dbus? If so, you can call for power-management actions over dbus
Alternatively, you might add a policykit policy to allow an active user to call shutdown / pm-suspend & co. directly.
Otherwise, I guess there's always groups and sudo...
Of course it does, shipping untested default configs still full of debian and systemd specific nonsense is apparently SOP.
Look around in the "Devuan Deriviates" section. Maybe there is a deriviate using IceWM already.
searched and picked the first one that may/might fit the usage(no personal experience)
https://linuxiac.com/antix-23-systemd-free-linux-distro-released-based-on-debian-12/
you can always give https://github.com/eylles/systemact a try, it is a "backend" for power menus, (a wrapper for systemctl and loginctl, anyone that wants consolekit support will have to help providing the equivalent commands) that uses yad to provide a confirmation and timeout dialog for every action except lock, it does the heavy lifting and is configurable to support custom logout and lock commands
all needed for icewm would be to make a local copy of the included power menu entry and replace the systemd commands with the corresponding systemact command.
Well, I tried Dan's solution from a MiyoLinux IceWM respin he did back in 2020, including his logout menu. I do, of course, have the logout command in the preferences menu set to point to that script, and I can run it from the terminal just fine. BUT -- when I click "Logout" in the menu, all it does is just dump me back to the login screen without displaying the script. What else could I be missing?
@fredbird67 First off, I recommend you use openrc + sysvinit rather than just pure sysvinit.
This will be much easier to handle. I have experience with this.
reboot and shutdown however are fairly easy for me.
if you know how to set up doas, you can shutdown by using:
doas poweroff
doas reboot
as for suspend, I am not sure how you would do that in devuan, without hardware keys. So... yeah lol, I draw a blank there.
If you set up doas properly though, you can just type those two commands in and it goes off immediately without requiring a password.
EDIT: If you want an easier way to shutdown though, qshutdown also works flawlessly.by hitting now on the menu and you will powerdown.
If you wish to be humbled, try to exalt yourself long term If you wish to be exalted, try to humble yourself long term
In all honesty, I'm very tempted to just replace IceWM with Openbox over this one...this one's REALLY ticking me off...gonna see if I can get Openbox to do my bidding here...
Choice of init/rc makes very little difference to shutdown/reboot invocation, and none at all to suspend (unless you have some init scripts wired up to suspend/resume hooks ofc).
Suspend / hibernation has nothing to do with "hardware keys", beside the latter often being assigned to trigger such through ACPI button events.
Actually suspending the system is kernel functionality (usually with firmware help for bootstrapping a suspended system), with optional high-level interfaces (pm-utils etc.).
Those can be called however you like, be it a dedicated (i.e. pre-assigned) "hardware" key, remapping a "hardware" key with acpid, a custom key combination in X / whatever DE you use (I like meta+s), or a script / menu / whatever.
You'd set those up the same way as you ever would when writing to sysfs or running any other priveliged command. Sudo / doas / groups / suid / polkit / logind are all a matter of taste for giving normal users permission.
In general, I'd suggest [e]logind as being the most convenient / compatible. I don't see any real reason for not wanting a login/seat manager of some kind on a primarily desktop/GUI setup, and it's also the easiest way to get X running as not-root (i.e. providing dynamic permissions for the nodes in /dev/ X needs)...
Unless of course you're going for knee-jerk "but it comes from systemd, no way" idological nonsense or hair-shirt level "minimalisim", in which case figuring out how you want to do seat management and permissions is up to you.
again, the repo i posted is the script i use on my machine, it works nicely for sysvinit + elogind.
Got curious about IceWM and installed it. As fredbird67 posted, shutdown and reboot didn't work. In /usr/share/icewm/README:
The directory /etc/X11/icewm used to contain copies of default configuration files shipped with the icewm package. The original files were and are located in /usr/share/icewm/ directory. This was considered service to the users but it has also led to confusion and made package handling more complicated.
Therefore, the default configuration files are now only located in
/usr/share/icewm/ directory. To customize something for all system users, the system administrator shall copy the particular file to /etc/X11/icewm when needed, and icewm will automatically make use of that copy. Regular users can do the same, installing their version into ~/.icewm/.
As root, I copied the menu and preferences files from /usr/share/icewm to /etc/X11/icewm and edited these two lines in preferences:
# Command to reboot the system.
From
# RebootCommand="test -e /run/systemd/system && systemctl reboot || sudo -n /sbin/reboot"
To
RebootCommand="sudo shutdown -r now"
and
# Command to shutdown the system.
From
# ShutdownCommand="test -e /run/systemd/system && systemctl poweroff || sudo -n /sbin/poweroff"
To
ShutdownCommand="sudo shutdown -h now"NOPASSWORD lines for reboot and shutdown were already in /etc/sudoers so those two cmds in IceWM's menu worked. Same results had ~/.icewm been created with the edited preferences file. My system isn't set up for hibernate but when the line for it in preferences is edited, it should work.
Have you tried antiX? This is a Debian based very lightweight distro that's extremely fast. It has a bunch of WM's including ICEWM and fluxbox.
You can shutdown or reboot with ease. It's got a very well developed version of ICE.
It's still based on Bookworm but it has an outstanding GUI for package management - far better than synaptic it's the same one used by MX Linux.
I was speaking in general probably. I don't know how to do any services with regular sysvinit. So there's that
Does this work without root permissions? Also I wonder to myself if elogind has root permissions built in. Not saying one way or the other though. Because I have no clue.
If so, curious.. But doas is still easier than sudo in my experience. Can't say anything about elogind tho
the doas method isn't hard though and is easier than the sudo one if anyone hasn't used sudo's method which I never have due to there being so much clutter in it.
I couldn't figure out how to do stuff the way doas does in sudo
But yeah, etlogind probably is easier, although I have never used that method.
I finally got it to reboot and shut down, y'all! ![]()
I finally did it by installing elogind. Doing further research, I found that there's also something else I had to do -- run the following command after installing the base Devuan CD:
sudo update-rc.d elogind defaultsI then changed the commands in the IceWM preferences file for rebooting and shutting down to loginctl reboot, loginctl suspend, and loginctl poweroff, which still didn't work. I then checked later, and found that I forgot to uncomment them. LOL
But once I discovered that oversight on my part about the uncommenting, I tried them again, AND THEY WORKED!!!
Thanx, y'all!
Now, to FINALLY get around to customizing it to my specifications and make the public announcement of the new release later this week. I'm PUMPED! ![]()
Logind manages resources for interactive logins/physical "seats", and replaces the likes of consolekit for managing access to devices and executing privileged tasks on behalf of the user.
So yes, you can ask logind to do things like shut down the machine without sudo/being root - so long as logind knows you are logged in to a physical session ("seat"). You can do the same over e.g. ssh, but in that case it will ask you to authenticate.
@steve_v That is interesting... good to know.
sudo isn't always easy, but this particular task isn't too difficult. You can give all members of a particular group privileges to run specific commands without a password. Then, you add your regular user account to that group. Generally, people use the existing sudo group for this purpose, although you can create a special group if you want, such as a shutdown group. For example, add this line to your /etc/sudoers file (remember to use visudo to edit!)
%sudo ALL=NOPASSWD: /sbin/shutdown,/sbin/poweroff,/sbin/rebootThen add yourself to the sudo group:
usermod -aG sudo your_usernameNow you can reboot without a password prompt:
sudo rebootThis is my preferred method, as a member of the nonsensical hair-shirt brigade! (I don't even use a display manager, just good old xinit.)
@stultumanto No idea why, but that was easier to do in doas for me.
I think the syntax was just trickier for me is all. doas syntax is much simpler is all.
Honestly, my use of sudo is 100% inertia at this point. The fact that doas comes from OpenBSD is all the endorsement I need. I'll probably check it out if I ever get a free moment!
