#1 2025-10-31 17:24:14
Duke Nukem
[SOLVED] Where is Veracrypt?
Can't find Veracrypt (or Truecrypt which preceded it). I'm sure it was in the repositories not long ago, at least when I was using Peppermint OS which was based on Daedalus (I understood). I'm running Excalibur now.
I did find something called tcplay which claims to do veracrypt's job, but it was implausibly small in size and after installing, it seems to have vanished into oblivion - not in the menus and not found by a file search or by command line.
#2 2025-10-31 18:03:22
Re: [SOLVED] Where is Veracrypt?
No, neither of them ever were in the Debian/Devuan repos.
Veracrypt to be obtained from: https://veracrypt.io/en/Home.html
You may find a similar package in the repo: zulucrypt.
#3 2025-10-31 20:00:10
Duke Nukem wrote:
... not in the menus and not found by a file search or by command line.
You may want to run a fine tooth comb through all your logs, just in case.
There has to be / should be some indication as to what transpired when you installed it.
Should not be an issue if you got it from the Devuan repository,but still.
Have a look here: https://linux.die.net/man/8/tcplay
#4 2025-10-31 23:35:33
check out man cryptsetup
#5 2025-11-01 01:20:58
stultumanto
Are you trying to invoke tcplay as a regular user, but don't have /sbin/ in your path? I just ran apt-file list tcplay, and it says the package installs the executable to /usr/sbin/tcplay.
#6 2025-11-01 11:27:29
Duke Nukem
Thanks for the help.  I uninstalled and re-installed tcplay and it did then turn up in /usr/sbin, which was not in my path. Seems to be working although I've not yet used it in earnest.
I am in the process of a re-installation of Devuan due to a change of motherboard which for some reason has fubarred the previous installation despite not changing anything with the drives. Long story, maybe something to do with UFEI.
A bit OT, wasn't there something about Debian/Devuan re-allocating files in the newest versions to cut out the /usr directory level? eg /usr/bin/ to /bin/
#7 2025-11-01 11:41:31
abower
It's the other way round: 'usrmerge' converts /bin and /sbin into symlinks pointing to the corresponding directories under /usr. It's not new to Excalibur but does become compulsory.
I use cryptsetup for whole disk encryption. It has good Devuan integration. Since Excalibur it can also harness OPAL hardware-based SSD encryption - I use this on low performance machines.
