#1 2025-09-30 12:08:55
kapqa
[SOLVED] Error Sylpheed upon start (G FILENAME ENCODING NOT SET)
Hello ,
i am wanting to use the program emailclient Sylpheed for arm64
on Devuanpi am presented with the following error>
https://imgur.com/ZRDGCnp.png
Is it safe to continue or how could i best clear this error message?
thanks.
#2 2025-09-30 12:39:50
Re: [SOLVED] Error Sylpheed upon start (G FILENAME ENCODING NOT SET)
I think it means that you have to do one of two things - either set the system locale to one that uses UTF-8 or else set the environment variable in that program as explained in the README they mention.
To set the system locale, run dpkg-reconfigure locales as root.
or
To set the locale in the program... (do whatever it says in the README.)
#3 2025-09-30 13:20:11
kapqa
thank, now it functions!
