#1 2025-08-24 23:31:05
HardSun
Old Stable Devuan 5 (daedalus)
Just want to ask when devuan 5 (daedalus) will be considered old stable?
I dont plan to upgrade to the excalibur release for atleast another 12 to 18 months, would this be ok and will devuan 5 old stable still receive security updates?
#2 2025-08-24 23:56:04
g4sra
Re: Old Stable Devuan 5 (daedalus)
Devuan follows Debian, so you need to know the Debian release timetable.
#3 2025-08-25 00:24:44
The current Devuan Daedalus will be moved to oldstable when ready, it may be a while. Even after, it has been my experience with Devuan that updates, especially security updates will continue for a long time to come. I plan on using daedalus for several more years. I used the original Devuan 1 (Jessie) for over 6 years.
#4 2025-08-25 01:47:29
HardSun
@g4sra
I come from debian or I used debian from stretch up until bookworm and then i found devuan. I just had too many issues with systemd and switched over. I was just unsure how set in stone releases are with devuan.
@greenjeans
got it, its a "ready when its ready" type thing, cool bananas with me, id be happy if daedalus was stable for another 2 years.
