Where will we get out 32 bit kernels from?
This works:
https://www.fsfla.org/ikiwiki/selibre/l … sh.en.html
Example:
https://get.refracta.org/files/testing/ … 5_1010.iso
sha256sum:
5ba7eab51ee52a50a7eb5203c01a7ea836551e177ca3b4a96a4f70cb58b000ed refracta_13_nox_libre_i386-20250425_1010.isoIf you need nonfree firmware, you'll need to find a different solution.
Hey that's wonderful thanks, it's for my eee pcs so no need for the firmware or pae, they take max 2GB ram!
Downloading that kernel now and will try it on eee pc later ![]()
Hey, tried out refracta, very nice system, eee pc nearly full with no desktop tho!
Just a question, why is the latest i386 kernel from there 330MB when the last 6.1... kernels were 188MB?
300+ is the size of the amd64 kernels, so are these i386 kernels being compiled with all amd64 bits included but unused or something or have they actually needed to double in size?
Where to find modern secure small i386 kernels???
Probably because mainline kernels include all the new drivers......or it may not have been stripped.
... why is the latest i386 kernel from there 330MB ...
In one word: bloat
eg:
Devuan Chimaera netinstall *.iso: 372.00 MB - UEFI installer: 00.754 MB
Devuan Daedalus netinstall *.iso: 477.80 MB - UEFI installer: 23.00 MB
30X more code has been added to the UEFI partition on the road between Chimaera and Daedalus.
Does anyone really know exactly what all that added code does?
My 2Gb 1000HE runs on Devuan Beowulf with a backported Chimaera kernel:
$ uname -a
Linux eee-dev3 5.10.0-0.deb.10.16-686-pae #1 SMP Debian 5.10.127-2-bpo10+1 (2022-07-28) i686 GNU/Linux
$Given the 2Gb max RAM access, I could probably do without the -pae but it is already there and for the time being I'd rather not muck around with things I don't know enough/much about.
That said, I have recently been wondering about the eventual benefits (?) of upgrading the kernel but have not been able to find sufficient reason to do so.
It has been a long time since I travelled with my 1000HE; these days it stays at home doing coffee roasting duty with no issues.
Only goes on line behind a passive Gbit desktop switch once in a blue moon if I need to test something.
I look forward to reading about how you fared with this.
Yes they all (my asus eee pc fleet) still run fine on every kernel since 3.16, they just all have different esoteric messages on boot.
I mean, is there some way to just include all relevant new security updates to an old kernel without worrying about new features or hardware that the asus eee pc will never know or be able to run?
The poor little 2G surf, I just managed to get lmde 6 onto it with latest kernel and 300 MB free space of the 1.87MIB ssd. No room for newest kernel upgrade. They can run the new kernels, but can't install them!
... run fine on every kernel since 3.16 ...
I expect that it would be the same with my 1000HE which is ca. 2009.
... to just include all relevant new security updates ...
No idea, but I expect that it could be possible.
From what little I understand, it seems that the task would involve compiling a kernel from source but including only what you need for your netbook.
ie: tailored for your target hardware and compiled on it.
There's also the question of who is going to do it and then maintain it.
For starters, is there a large enough user base?
There used to be specific eee kernels / distributions but as the differnet models were mothballed, they lost all traction.
Interesting side note:
Asus does not have the eee series in theri tech support databases.
I have recently been able to get a very important boost for my netbook by enabling zram and generating a /dev/zram0 swap file.
... features or hardware that the asus eee pc will never know ...
The Asus eee series is not alone in this.
Absolutely every discontinued and perfectly working netbook / notebook is in the same situation.
All victims of the decades old WinTel consortium. (see what is going on with Win 11 these days)
Oops! My EEE has a 128G ssd, so I didn't think a lot about disk space. I recently added a 32G sd card so I could run excalibur without losing my daedalus install (or my win XP install which I keep only for nostalgia). The EEE sees it as a usb storage device, so it's bootable.
... added a 32G sd card ...
Fortunately, your eee model can boot from that size card.
Much to my chagrin, my 1000HE's BIOS won't see a USB storage device larger than 8.0Gb, that's (?) the limit for booting from USB.
I asked at Asus tech support but they 'don't know'.
Ventoy solves that problem.
The system, once up and running, can see and access a 64Gb USB3.0 drive without issues and (I presume) higher capacity.
... (or my win XP install which I keep only for nostalgia).
Glad to see I'm not the only one. 8^°
To get a more up to date kernel, maybe copy your kernel config file over & try running it with the modern kernel source code..... (?)
If some good folk would be happy to compile kernels for eee pc I'd be not only happy, my obsessively compelled to try them out on many eee, though I hesitate to say test.
Been enabling zram on a few eee, it seems to help, especially when torturing the fanless ones with cinnamon desktop and browser action. On the 4G / 630mhz single core the name of the game is no fan even in high summer, so ram ceiling isn't important, so the question is, does zram not increase overall cpu and/or ram usage?
If you have a 128gb ssd then I bet you don't have the bios boost partitions, but never fear, I have put them on drop box, you can copy one of them with gparted and easily recreate the other using gnome-disks, make the fat partition 513KB instead of 7.84MiB if you like!
https://www.dropbox.com/scl/fi/koa3hdwa … 6wtxc&dl=0
Link changed to point to actual file >.<
Uh-oh. I upgraded my excalibur minimal-X system and made a new live-iso. It doesn't boot. Drops to initramfs prompt and says it couldn't mount the squashfs. This is with linux-image-6.12.30-gnu. I made another live-iso that includes the 6.12.24-gnu kernel and that boots normally. (Note: both kernels boot normally in the VM I'm using to make the isos.)
mount /run/live/medium/live/filesystem.squashfs: fsconfig() failed: unable to read squashfs_super_block.Here's a screenshot that shows the error message in /boot.log
https://get.refracta.org/files/misc/mou … -00-38.png
Edit: Found an iso I made on May 12 with 6.12.28-gnu that works.
There's a 17 MB bios boot boost partition for eee pc xp too! I should put that online too.
One does wonder about the breadth of testing of new 32 bit kernels, so many million use cases, so fewer eee pc users ;_:
Update: I'm trying more kernels and I asked a question in #gnu-linux-libre (libera.chat)
6.12.30-gnu has the problem.
6.12.28-gnu and 6.12.24-gnu both work.
6.12.30-gnu.nonpae works.
6.14.8-gnu (non-lts) works.
Can you please also ask why 330+MB rather than around 188MB?
Update. If I downgrade to the previous version of mount, the isos boot. (i.e. they can loop-mount filesystem.squashfs)
mount, fdisk libfdisk1 and uuid-runtime were all downgraded from 2.41-5devuan1 to 2.38.1-5+deb12u3devuan1
I filed a bug report against mount - https://bugs.devuan.org/cgi/bugreport.cgi?bug=892
About that size issue...
I poked around a bit. Most of the difference is in /lib/modules and most of that is drivers. libre has more directories and files there than debian and all the .ko files in the debian kernel are xz-compressed. That accounts for around 200mb difference.
linux-libre 6.15.0 with the current version of mount (2.41-5devuan1) is working correctly. Here's an iso in case anyone wants to play with it.
https://get.refracta.org/files/experime … 0_1739.iso
sha256sum
4d19d4a9f1f28eb5548fc3b141f83fece1a9df0640cdb6bbc63a528944b41306 refracta_13_minx_ndb_libre_i386-20250530_1739.isoOnline
Hello, I have used the refracta image (thanx to fsmithred) for a EeePC 1005HA ("Seafile") from 2010 and this works very good. There are some kernel issues concerning eeepc driver, but I cannot recognize a loss of functionalities. I think, that can be fixed, if the libre kernel is patched for the Eee. But for functionality seems this not necessary (but I'm still testing). Now I'm configuring the desktop with LXDE base and xfwm4 WM. The performance is low but stable. Using firefox is something for meditation, but the good keyboard welcomes for writing (libreoffice writer is usable). For me, the libre lts kernel seems the way to use in future 32bit hardware.
I am very glad that my oldest computer in my possession is 64 bit...
This being said, Debian devs really didn't need to change the framework so much that they needed to ditch 32 bit. What they should have done is stop bloating their system with redhat bloat and similar instead.
If you wish to be humbled, try to exalt yourself long term If you wish to be exalted, try to humble yourself long term
