#1 2025-02-02 17:30:02
mclien
[SOLVED] linux-image not updated
I was just doing the routinely apr update  and apt upgrade, but the linux kernel was nit updated:
  linux-image-amd64
I did an apt autoremove, but got the same result with the apt upgrade.
Here is the apt policy:
root@rygel:~# apt policy linux-image-amd64
linux-image-amd64:
  Installed: 6.1.76-1
  Candidate: 6.1.124-1
  Version table:
     6.1.124-1 500
        500 http://deb.devuan.org/merged daedalus-updates/main amd64 Packages
     6.1.123-1 500
        500 http://deb.devuan.org/merged daedalus/main amd64 Packages
     6.1.119-1 500
        500 http://deb.devuan.org/merged daedalus-security/main amd64 Packages
 *** 6.1.76-1 100
        100 /var/lib/dpkg/status
I did not set any apt policies (at least I think so)
#2 2025-02-02 18:56:20
bai4Iej2need
Re: [SOLVED] linux-image not updated
Probably  your linux image 6.1.76 is set on "hold".
dpkg --status linux-image-6.1.76-1
check for third line Status :  MUST NOT contain hold
apt-mark unhold linux-image-6.1.76-1
To unhold all held packages, use this command:
apt-mark unhold $(apt-mark showhold)
Then try a new update
broken by design :
#3 2025-02-02 19:30:55
mclien
OK, that one didn't worked directly, so I did:
~# dpkg --status linux-image-amd64
Package: linux-image-amd64
Status: install ok installed
Priority: optional
Section: kernel
Installed-Size: 13
Maintainer: Debian Kernel Team <debian-kernel@lists.debian.org>
Architecture: amd64
Source: linux-signed-amd64 (6.1.76+1)
Version: 6.1.76-1
Provides: linux-image-generic, linux-latest-modules-6.1.0-18-amd64, virtualbox-guest-modules, wireguard-modules (= 1.0.0)
Depends: linux-image-6.1.0-18-amd64 (= 6.1.76-1)
Description: Linux for 64-bit PCs (meta-package)
 This package depends on the latest Linux kernel and modules for use on PCs
 with AMD64, Intel 64 or VIA Nano processors.
Built-Using: linux (= 6.1.76-1)
which let me check the specific version:
:~# dpkg --status linux-image-6.1.0-18-amd64
Package: linux-image-6.1.0-18-amd64
Priority: optional
Section: kernel
Installed-Size: 398601
Architecture: amd64
Version: 6.1.76-1
Replaces: linux-image-6.1.0-18-amd64-unsigned
Depends: kmod, linux-base (>= 4.3~), initramfs-tools (>= 0.120+deb8u2) | linux-initramfs-tool
Recommends: firmware-linux-free, apparmor
Suggests: linux-doc-6.1, debian-kernel-handbook, grub-pc | grub-efi-amd64 | extlinux
Breaks: fwupdate (<< 12-7), initramfs-tools (<< 0.120+deb8u2), wireless-regdb (<< 2019.06.03-1~)
Conflicts: linux-image-6.1.0-18-amd64-unsigned
Description: Linux 6.1 for 64-bit PCs (signed)
 The Linux kernel 6.1 and modules for use on PCs with AMD64, Intel 64 or
 The kernel image and modules are signed for use with Secure Boot.
So even more questions..
#4 2025-02-02 21:05:29
dzz
Then maybe some answers (after you checked for no held packages) from:
apt update && apt install linux-image-amd64
#5 2025-02-02 22:33:20
Note that the installed linux-image-amd64=6.1.76-1 has its "depends"
which is that exact version of linux-image-6.1.0-18-amd64.
The new version of linux-image-amd64 (the one held back) has its own exact dependency on some other package linux-image-*-amd64 which is not currently installed. Therefore an upgrade, which does not install new packages, will not upgrade linux-image-amd64 (since it would then need to install that new package).
See man apt-get about the upgrade parameter.
You would get it upgraded, and the new package installed, by using
apt-get dist-upgrade
EDIT: seeing you use apt rather than apt-get there is a slight difference, see the upgrade parameter notice in man apt; it's due to the same sort of logic but applied to removing packages.
EDIT 2: it's never too early to start reading "man" pages...
#6 2025-02-03 11:58:20
I normally do just apt upgrade and I get the newer kernels. I tried it now and I aborted the upgrade because I got a warning of grave bugs in rsync.
Then I tried
which was already installed, and that gets me the newer kernel and headers without the rest of the upgrades.
#7 2025-02-10 17:24:48
As an apt user I use the following two commands:
# apt update
# apt full-upgrade -V
and I am getting the full picture every time.
#8 2025-03-12 11:30:47
mclien
Ah, sorry for not answering. Problem was solved with the next kernel update.
