#1 2025-01-22 21:35:51
txnintn
Efivarfs, Efibootmgr, hold the grub
Gearing up to run a diskless install on my new Nas build.
I forgot to mount the ESP partition to /boot/efi.
I booted in to the rescue cd, removed Efibootmgr and reinstalled it, no joy.
Boot has 2 of the following files, all ending with *-6.1.0-10-amd *-6.1.0.30-amd
system.map, config, initrd.img, and vmlinuz.
The efi folder is empty.
I think just need to move some files from /boot to /boot/efi.
Any suggestions?
txnintn
#2 2025-01-23 01:34:04
Re: Efivarfs, Efibootmgr, hold the grub
I think you need to boot the rescue cd, open a shell in the installed system and run grub-install and update-grub. But I've never done an install like yours, so there might be something else to do.
