#1 2024-12-29 04:30:14
mtbvfr
Instructions for installing lightdm on new Devuan 5 installation?
Hi Folks,
I would like to have a more User Friendly Login screen (greeter) so that the User doesn't have to type in their User Name every time they Login as per MX Linux which uses lightdm-gtk-greeter and lightdm-gtk-greeter-settings and lightdm-modified-init.
I found the following page (Item 3).
https://www.baeldung.com/linux/display- … -uninstall
Are those instructions compatible with Devuan 5 - i386?
Does lightdm need to be run as a Service?
Is there anything missing from those instructions?
Thanks!!
#2 2024-12-29 09:42:10
Re: Instructions for installing lightdm on new Devuan 5 installation?
I am a long term user of Lightdm on amd64, but I see no reason why it shouldn't work on i386.
Simple instructions:
# apt install lightdm
# nano /etc/lightdm/lightdm.conf
Edit under Seats, remove the hash before greeter_hide_users
#3 2024-12-29 10:04:44
mtbvfr
Should I also install lightdm-gtk-greeter as suggested on the website I mentioned?
I just noticed that that website mentions configuring the /etc/lightdm/lightdm.conf file but but without any instructions in how to do so - duh!
Why do we want to Hide the Users? Did you mean [SeatDefaults]?
In MX Linux, greeter-hide-users is commented with a # to disable that setting. When the Login screen appears the User Name is already entered.
Thanks!!
#4 2024-12-29 10:29:31
The command I gave installs all required dependencies. I never drilled any deeper. You may look them up with Synaptics if you like.
To the conf file: the default is that user names are hidden. You need to enable that line and set it to false.
BTW: the conf file is confusing. In the beginning there is a lot of comments to all the settings. The relevant line is some way down the file under the [seats] section.
#5 2024-12-30 10:15:51
mtbvfr
rolfie wrote:
The command I gave
I used Synaptic and it marked all the required dependencies for installation too.
During the installation process, I was also prompted with a Dialogue Window to select which Display Manager (DM) was to be active. slim was already selected as it was the current one. So, I selected lightdm which was at the top of the list.
I then edited the lightdm.conf file.
I rebooted the Laptop et voila lightdm was the active DM. smile
Thanks!! again, MTB.
I prefer using Synaptic because it maintains a History of installations which is useful if you need to return to a previous configuration.
#6 2024-12-30 11:07:29
Apt also provides a log, refer to /var/log/apt/history.log.
#7 2024-12-30 18:21:31
Pretty sure that's where Synaptic gets it's history, loads that file when you open it. So it's the same history.
But if you never use the GUI, then yeah.
#8 2024-12-31 09:29:34
also see /var/log/apt/term.log (for the same stuff you see scroll by in the synaptic terminal window)
