#1 2024-10-06 19:06:18
Alverstone
Excalibur, runit's supervision tree inherits tty1, misbehavior
<sysrq>+K on tty1 brings the system down. Happens because runsvdir gets SIGKILLed by the kernel. Happens because runsvdir inherits tty1. I think this is a bug and should be fixed. One solution I am aware of is
exec </dev/null >/dev/null 2>/dev/null
in /etc/runit/2 just before runsvdir. What do you think?
#2 2024-10-06 19:17:45
Alverstone
Re: Excalibur, runit's supervision tree inherits tty1, misbehavior
Another misbehavior here is that tty1 gets cluttered with log messages.
#3 2024-10-21 21:22:47
Lorenzo
Hi!
but this discards all output from runsvdir right? Or are you able to get it in some other way?
anyway, clutter tty1 is a known issue, <sysrq>+K is new to me. And there is also this other issue
https://github.com/void-linux/runit/issues/14
reported at Void.
I would like to address them all, and keep a log or runsvdir if possible..
Could you test the following in stage 2
PIPE=/run/runit/runsvdirpipe
mkfifo "$PIPE"
exec <> "$PIPE"
exec env - PATH=$PATH  runsvdir -P "${SVDIR}" >"$PIPE" 2>"$PIPE"
note that the log arg for runsvdir (the dots) is removed.
and a log of runsvdir could be catched with a simple service like (run file)
NAME="runsvdir-log"
LOG=/run/runit/runsvdir-log
test -d "$LOG" || mkdir "$LOG" && chown -R _runit-log:adm "$LOG"
exec 2>&1
exec < /run/runit/runsvdirpipe
echo "Starting runsvdir-log"
exec chpst -u _runit-log svlogd -tt "$LOG"
I tested quickly and it seems to do the job, please let me know if it works for you
Lorenzo
#4 2024-10-22 15:33:50
Alverstone
Correct.
Yep, I've put /dev/tty12 instead of /dev/null there. <sysrq>+K on tty12 still brings the system down, but I don't care because it doesn't get in the way of my routinely workflow, unlike tty1 which I use heavily. I have some suspicions that part of the output gets lost somehow, though... Need to test that more thoroughly.
I hurry to notify you that I (very personally) find runsvdir's cmdline logging feature useless. Ever since I've put an svlogd on every service that needs it, and >/dev/null 2>&1 on every service that maintains logs on its own (hello mullvad-daemon), my ps -ef | grep runsvdir is
runsvdir -P /etc/service log: ...........................................................................................................................................................................................................................................................................................................................................................................................................
and my tty12 console output is as good as non-existent.
Regarding your FIFO approach, I mostly agree with it, but will still give you some input that popped up in my head.
First, in case of a big amount of services, will the default 16 pages be enough to keep all the logs in the FIFO before the svlogd starts? I think it should, but if you settle on this solution, maybe you want to keep your hand on the pulse for possible bug reports. Bottom line, you can start svlogd prior to runsvdir and then restart it under runsv.
Second, consistency. Stage 1 and sysvinit scripts log to tty1. Are runsvdir logs important enough to be concerned about, or is nobody interested in seeing them anyway? sysvinit logs are very important as they notify you about possible errors during startup of critical parts, I presume many people rely on them and I am no exception. On the other hand, I (very personally) do not find runsvdir logs as useful. As long as I get a getty I will be fine. I can imagine a few use cases to it. One would be not using svlogd for getty, this way if getty fails, you immediately know why. Is this useful? No, because since you can't log in you would need a separate boot media anyway, as such you could as well check the log. On the other hand, some critical, not very verbose services, could still make use of it. Want to check errors/warning? Switch to the tty and read the text on your screen. Easy, no hassle, no logging in as root etc etc.
Lastly, why /run/runit/runsvdir-log? This beats the purpose. I suggest this is changed to /var/log/runit instead.
I humbly suggest the following modifications.
SVNAME=runsvdir-log
DEF=/etc/default/runsvdir-log
is_number () {
    case "$1" in
        *[!0-9]*|"") return 1;;
        *) return 0;;
    esac
if [ -L "$SVDIR/.$SVNAME" ]; then
    mv "$SVDIR/.$SVNAME" "$SVDIR/$SVNAME"
fi
[ -f "$DEF" ] && . "$DEF"
if is_number "$LOG_TTY" && [ -c /dev/tty$LOG_TTY ]; then
    echo "runsvdir log goes to /dev/tty$LOG_TTY"
    PIPE=/dev/tty$LOG_TTY
    [ -L "$SVDIR/$SVNAME" ] && mv "$SVDIR/$SVNAME" "$SVDIR/.$SVNAME"
elif ! [ -L "$SVDIR/$SVNAME" ]; then
    PIPE=/dev/console # default
elif ! mkfifo "$PIPE"; then
    echo "Failed to create runsvdir pipe for logging: $PIPE"
    echo "runsvdir will run with logging disabled"
    PIPE=/dev/null
fi
# no blocking for FIFO, please, so <> is mandatory
exec <> "$PIPE"
# must redirect twice for FIFO
exec env - PATH="$PATH"  runsvdir -P "${SVDIR}" >"$PIPE" 2>"$PIPE"
and
SVNAME="runsvdir-log"
LOG=/var/log/runit/"$SVNAME"
if ! mkdir -p "$LOG"; then
    # mkdir output error already, this is to help making sense of it
    echo "$SVNAME: $LOG: mkdir failed" >&2
    sv d .
fi
chmod 750 "$LOG"
exec 2>&1
echo "Starting $SVNAME"
I find this quite involved to be honest. I am not sure how good exactly the idea is. Also, if svlogd fails here, you'll never know why because of the loop, it might get somebody confused. I honestly fail to see a flawless solution here. I suspect the scripts above are flexible enough to let people do whatever they want. Put LOG_TTY=1 in the /etc/default/runsvdir-log and you get the default behavior.
Also, maybe somehow add an option to the runsvdir-log service to duplicate the log to a tty. I'm afraid my head is not clear enough now to suggest anything more sensible.
Also, the scripts above work, I've just tested them.
#5 2024-10-22 15:40:13
Alverstone
Also, here
maybe use /dev/console instead of /dev/null, it would be more sensible.
#6 2024-10-23 15:10:59
Alverstone
Lorenzo,
I gave it more thought and here is what I have. Append this to the current default /etc/runit/2:
LOGSVNAME=runsvdir-log
[ -L "$SVDIR/.$LOGSVNAME" ] && mv "$SVDIR/.$LOGSVNAME" "$SVDIR/$LOGSVNAME"
LOGFIFO=/run/runit/runsvdirpipe
LOG="$LOGFIFO"
if ! mkfifo "$LOGFIFO"; then
    # mkfifo already output error
    echo "runsvdir will log to /dev/console" >&2
    LOG=/dev/console
    # just in case
    rm -f "$LOGFIFO"
fi
# Use <> for stdin, otherwise FIFO blocks
exec <>"$LOG" >"$LOG" 2>"$LOG"
The logger service must be called runsvdir-log, the run file is
# do not use echo to report error
# if this service is needed and logs go to FIFO, all error
# messages will get lost in the FIFO anyway
SVDIR="$(dirname "$(readlink -f .)")"
SVNAME="runsvdir-log" # must be runsvdir-log, MUST
LOGDIR=/var/log/runit/"$SVNAME"
LOGDUP=no
is_number () {
    case "$1" in
        *) return 0;;
    esac
is_yes () {
    case "$1" in
        y|ye|yes) return 0;;
        *) return 1;;
    esac
msg_start () {
[ -f ./conf ] && . ./conf
if ! [ -p "$LOGFIFO" ]; then
    exit
fi
if is_number "$LOGTTY" && [ -c /dev/tty"$LOGTTY" ]; then
    LOGTTY=/dev/tty"$LOGTTY"
else
    LOGTTY=""
fi
if ! is_yes "$LOGDUP" && [ -n "$LOGTTY" ]; then
    msg_start
    exec cat < "$LOGFIFO" > "$LOGTTY" 2> "$LOGTTY"
fi
if ! mkdir -p "$LOGDIR"; then
    sv d . # down instead of 'mv' as a kind of error reporting
fi
chown -R _runit-log:adm "$LOGDIR"
chmod 750 "$LOGDIR"
msg_start
if is_yes "$LOGDUP" && [ -n "$LOGTTY" ]; then
    DUPPIPE=/run/runit/duppipe
    rm -f "$DUPPIPE"
    if ! mkfifo "$DUPPIPE"; then
        # at least do something
        rm -f "$DUPPIPE" # just in case
        exec chpst -u _runit-log svlogd -tt "$LOGDIR" < "$LOGFIFO"
    fi
    chpst -u _runit-log svlogd -tt "$LOGDIR" < "$DUPPIPE" &
    # this could deadlock... still it would at least be an indication of an error
    # unlike writing into a FIFO nobody reads, so don't use <> on $DUPPIPE
    exec 8>"$DUPPIPE"
    exec 9<"$LOGFIFO"
    # this way after exit svlogd will receive EOF and exit
    rm -f "$DUPPIPE"
    while read -r logline <&9; do
        echo "$logline" >&8
        echo "$logline" > "$LOGTTY"
    done
else
fi
This
  1. Keeps /etc/runit/2 as small as possible.
  2. Prevents https://github.com/void-linux/runit/issues/14 because cmdline logging feature is disabled.
  3. Prevents <sysrq>+K from bringing system down. It probably kills the logger when it's cat, but that is not critical.
What do you think?
#7 2024-10-23 15:16:23
Alverstone
Consequently, /etc/default/runsvdir-log sets up two variables.
  • LOGTTY: VT number to which log is written.
  • LOGDUP: If set to yes (or ye or y) and LOGTTY is defined, write log to svlogd and duplicate it to VT number $LOGTTY.
If LOGTTY is undefined, or VT with such number does not exist, log to svlogd. You could easily add support for logging/duplicating to /dev/console, if you think this solution is any good at all.
#8 2024-10-25 15:33:22
Lorenzo
Hi Alverstone,
I redirected runsvdir output to /dev/tty10 on my system and  tested  <sysrq>+K on tty1 and it brings down the system;
tested again, and it's actually the
exec <>
that does the trick and shields runsvdir from <sysrq>+K
I should have been more precise, apologise if this wasted your time in search of a solution with a proper log:
what I mean is that it's preferable to not discard completely the runsvdir output by default; it doesn't have to be necessary a proper log file.
since output to tty and exec <> does the trick I think I prefer that to proper fifo.
Issue with the fifo is what happens if the buffer is full and there is nothing reading on the other side, I'm not sure if that can affect runsvdir in a bad way, that would be a problem.
What I fear (more than the race between lines written and runsvdir-log startup) is that a user can disable the runsvdir-log service because he doesn't care and then, due to some service malfunction later, the buffer slowly fills up.
Runsvdir output 1 line per second for each non functional service (example run not executable or not found); how many line it takes before the fifo buffer is full?
On the other hand is hard to predict if a ttyN is available in a system; only thing that is granted to be there is /dev/console (reason why runit outputs there, I think) but /dev/console is connected with tty1, so we are at the starting point..
I agree with the logic you proposed for stage 2 but I prefer something more simple; your proposed code could be fine if I roll runit specific bootscripts but for now I prefer to keep stage 2 more simple. I'm thinking of an hardcoded list of  /dev/* with a fallback on /dev/console;
I think standard system (desktop, laptop, server) have plenty of tty; less sure about embedded hardware (raspberry, arduino or even more essential hardware); there is also the container case to cover.
Something like (recycling you code, simplified)
for out in tty12 ttyS1 tty1 console; do
  if [ -c /dev/"$out" ] ; then
     PIPE="/dev/$out"; break
  fi
done
exec <>"$PIPE" >"$PIPE" 2>"$PIPE"
your code is certainly more configurable from user point of view,
but unfortunately I fear is also more fragile if the user is not aware of the fifo.
let me know if you  see shortcomings or you have more thoughts on this; I intend to
add a fix for this in the next runit upload to unstable.
Thanks for your ideas!
Lorenzo
#9 2024-10-26 14:06:06
Alverstone
Hi Lorenzo,
Weird. If you redirected to /dev/tty10 then sysrq only brings down the system when invoked on the tty in question. This is the way my system behaves. The kernel's 6.6.56, pristine. Ehh it's a bit bothersome to reboot several times while writing a post roll, but...
exec env - PATH="$PATH" runsvdir -P "${SVDIR}" >/dev/tty12 2>/dev/tty12
sysrq brings the system down both on tt1 and tty12. I wish I remembered which kernel function does it to have a look at it, but as far as trial, error and memory go kernel checks what processes "sit" on the current tty (perhaps just have it open, I don't remember), locks them (to prevent TOU bugs), and kills recursively down to the last child. So yes, it is imperative that not only stdout and stderr are redirected, but stdin as well.
As for <>, I do not observe the said behavior.
exec env - PATH="$PATH" runsvdir -P "${SVDIR}" </dev/tty12 >/dev/tty12 2>/dev/tty12
prevents sysrq from bringing the system down on tty1 and moves the "bug" (quotes because not sure if it's really a bug) to tty12. On my system.
So much for enthusiasm!
Please either double check or clarify.
exec env - PATH="$PATH" runsvdir -P "${SVDIR}" <>/dev/tty12 >/dev/tty12 2>/dev/tty12
<sysrq>+K on tty12 is followed by a shutdown all right.
This isn't hard to check.
mkfifo test
exec 4<>test
head -c 65536 < /dev/urandom > test
echo 1 > test
So unless runsvdir specifically avoids blocking on writes (poll, O_NONBLOCK, whatever), it's gonna block. I more or less knew this, but didn't pay much attention. I guess I understand your concerns here.
I'm not sure I fully understand what you mean here. Elaborate, please?
Do you mean to try and guess the most likely unused tty and put logs there?
I dunno. It looks like for stdout and stderr runit uses buffer_unixwrite(), which is just write(). Furthermore, buffer_1 and buffer_2 are mainly used with buffer_puts() and the return status isn't really checked at the first glance. This is very thin ice, but theoretically, if we could open the FIFO in non-blocking mode, it could work. I can't say I like it.
The core of the problem here is that we attach to a VT. Do openrc guys have this problem? I dunno how it works, but looks like they're using startup scripts for their services so they probably don't have any critical processes attached to any VTs.
Listen, since runit is an almost trivial (in terms of UX at least) init system, can we really hope to avoid tinkering completely? What do you think about leaving the default behavior alone and instead leaving a BIG and FAT piece of documentation somewhere everybody is very likely to look and explain the situation to people? We could then make a stage 2 logger around FIFO and just tell them to enable it manually or whatever. Maybe even put something at /etc/default, though I don't know all the pitfalls of packaging. Better than /etc/default, we could just have a conf file. It feels like backing off, but it doesn't look like we can cope without some black magic.
Thank you for reaching out.
#10 2024-11-09 16:49:15
abower
Hi guys, I spotted the pending change at https://salsa.debian.org/debian/runit/- … b633b819d5 which directed me to the discussion here.
I understand the changes fix a serious problem but do we now have no way of discovering failures on a headless system?
readproctitle was far from ideal but at least it was _possible_ to diagnose issues after the fact. Really we need a proper log as a fallback/catch-all for services that don't have their own logger because they don't have any output or whose logger script is itself faulty. I'm not sure if you covered this in the above discussion, my apologies for not following it all!
Thanks!
#11 2024-11-10 19:02:34
Alverstone
abower,
You should wait until Lorenzo replies, since he's the competent developer (while I'm literally nobody), but I have several suggestions.
One is reading /dev/vcs*. I don't know about embedded but otherwise you most likely have tty12 available, and the runsvdir will log there, so grep $error /dev/vcs12 will do it. Though virtual console memory's size may be unreliable?
Another way is getting the 'log: ...........................................................................................................................................................................................................................................................................................................................................................................................................' command line parameter back in place.
Another way, you could add logging and then grep the log. I left an example script above. The /etc/runit/2 is fine, but the logger service itself had a few bugs, right now I use
#SVDIR="$(dirname "$(pwd)")"
SVDIR=/etc/service
LOGDUP=no
is_number () {
    case "$1" in
        *) return 0;;
    esac
is_yes () {
    case "$1" in
        *) return 1;;
    esac
msg_start () {
    exit
fi
else
    LOGTTY=""
fi
    msg_start
fi
fi
chmod 750 "$LOGDIR"
msg_start
    rm -f "$DUPPIPE"
    fi
    exec 8>"$DUPPIPE"
    exec 9<"$LOGFIFO"
    rm -f "$DUPPIPE"
        echo "$logline" >&8
        echo "$logline" >> "$LOGTTY"
    done
else
fi
You can greatly simplify it by reducing the whole thing to
which I think will be the best way to approach it, since this script isn't really... polished? For example, I still use /etc/default, though I should not, accordingly to packaging logic (Lorenzo wrote something about it above).
#12 2024-11-10 19:11:40
Alverstone
Lorenzo,
As a side note, you've already rolled a lot of Devuan (and Debian) specific configuration for runit (at least I conclude it by comparing to Void, not to upstream runit implementation), I don't think it will hurt to add a configuration option for the runsvdir's command line log. It would be by far the most clean solution to abower's issue and the issue doesn't seem like one you can just ignore (some people might actually rely on readproctitle in their headless systems, probably).
Also, beware of /dev/ttyS1. It is a serial port. On my laptop accessing it yields an I/O error, and I've never heard that absence of tty12 is a sure indicator of ttyS1 being functional, correct me if I'm wrong. Maybe it should be given the least priority? Or at least perform some error checking. Another thing I want to mention is that writing to /dev/ttyS0 on my laptop does not yield any errors, but I don't have any serial ports, so the output gets lost.
Also, there's a nasty gotcha with the space after "log:", so this could be a workaround.
if [ -f /etc/runit/runsvdir.readproctitle.log ]; then
    CMDLINELOG='...........................................................................................................................................................................................................................................................................................................................................................................................................'
fi
exec env - PATH=$PATH  runsvdir -P "${SVDIR}" ${CMDLINELOG:+"log: $CMDLINELOG"}
#13 2024-11-10 20:27:46
Alverstone
By the way, I found it. drivers/tty/tty_io.c, function void __do_SAK(struct tty_struct *tty).
#14 2024-11-17 21:31:42
Alverstone
So I stopped the logger, did yes hi > runsvdirpipe and the result is
  1. sv d and sv exit work
  2. sv u and sv start work, but only if runsv is already running on the given directory, otherwise block. sv u doesn't block, but doesn't do anything either.
I'm not suggesting anything, but this below works.
diff --git a/buffer.h b/buffer.h
index 8f2e572..8f998fd 100644
--- a/buffer.h
+++ b/buffer.h
@@ -51,6 +51,7 @@ extern int buffer_copy(buffer *,buffer *);
 extern int buffer_unixread(int,char *,unsigned int);
 extern int buffer_unixwrite(int,const char *,unsigned int);
+extern int buffer_unixwrite_nonblock(int,const char *,unsigned int);
 extern buffer *buffer_0;
 extern buffer *buffer_0small;
diff --git a/buffer_1.c b/buffer_1.c
index f4bac3d..1fe5ed1 100644
--- a/buffer_1.c
+++ b/buffer_1.c
@@ -3,5 +3,5 @@
 #include "buffer.h"
 char buffer_1_space[BUFFER_OUTSIZE];
-static buffer it = BUFFER_INIT(buffer_unixwrite,1,buffer_1_space,sizeof buffer_1_space);
+static buffer it = BUFFER_INIT(buffer_unixwrite_nonblock,1,buffer_1_space,sizeof buffer_1_space);
 buffer *buffer_1 = &it;
diff --git a/buffer_2.c b/buffer_2.c
index f255a92..d8a9c6d 100644
--- a/buffer_2.c
+++ b/buffer_2.c
@@ -3,5 +3,5 @@
 #include "buffer.h"
 char buffer_2_space[256];
-static buffer it = BUFFER_INIT(buffer_unixwrite,2,buffer_2_space,sizeof buffer_2_space);
+static buffer it = BUFFER_INIT(buffer_unixwrite_nonblock,2,buffer_2_space,sizeof buffer_2_space);
 buffer *buffer_2 = &it;
diff --git a/buffer_write.c b/buffer_write.c
index 4ba13ef..10fe8a0 100644
--- a/buffer_write.c
+++ b/buffer_write.c
@@ -1,5 +1,6 @@
 /* Public domain. */
+#include <errno.h>
 #include <unistd.h>
 #include "buffer.h"
@@ -7,3 +8,14 @@ int buffer_unixwrite(int fd,const char *buf,unsigned int len)
   return write(fd,buf,len);
+int buffer_unixwrite_nonblock(int fd, const char *buf, unsigned int len)
+  ssize_t w = write(fd, buf, len);
+  if (w < 0 && (errno == EWOULDBLOCK || errno == EAGAIN)) {
+    // pretend success
+    return len;
+  } else {
+    return w;
diff --git a/runsvdir.c b/runsvdir.c
index de430f2..99d3ce4 100644
--- a/runsvdir.c
+++ b/runsvdir.c
@@ -1,7 +1,8 @@
-#include <sys/types.h>
+#include <fcntl.h>
+#include <signal.h>
 #include <sys/stat.h>
+#include <sys/types.h>
 #include <unistd.h>
-#include <signal.h>
 #include "direntry.h"
 #include "strerr.h"
 #include "error.h"
@@ -212,6 +213,18 @@ int main(int argc, char **argv) {
     if (! argv || ! *argv) usage();
+  for (int i = 1; i <= 2; i++) {
+    struct stat sb;
+    int flags;
+    if (fstat(i, &sb) < 0) {
+      continue;
+    if (S_ISFIFO(sb.st_mode) && (flags = fcntl(i, F_GETFL)) >= 0) {
+      flags |= O_NONBLOCK;
+      fcntl(i, F_SETFL, flags);
   sig_catch(sig_term, s_term);
   sig_catch(sig_hangup, s_hangup);
   sig_catch(sig_alarm, s_alarm);
Applied on top of all other patches though.
#15 2024-11-17 22:00:30
abower
Thanks for the logging tips, Alverstone! I haven't had cause to use yet but useful to have in mind.
I think you are probably right about the serial port. Unexpected use of the serial port is a classic cause of unexplained problems, like debug being interleaved into operational communications and slow/blocked processing!
Perhaps some other test should be used as a proxy to determine whether the serial port is suitable, e.g. a kernel command line value or the enablement of serial logging from some other component.
