#1 2017-06-07 15:00:33
Morgennebel
[SOLVED] Installation on Latte Panda 4G/64GB Intel Cherry Trail Z8300
Dear,
I am trying to install Devuan on my new Latte Panda 4GB RAM/64 GB storage using an 64bit x86 Intel Atom X5 CPU and UEFI BIOS - see http://www.lattepanda.com/product-details/?pid=3 for full tech specs.
Using Rufus I have copied:
  • devuan_jessie_1.0.0_amd64_uefi_desktop_live.iso
  • devuan_jessie_1.0.0_amd64_DVD.iso
  • devuan_jessie_1.0.0_amd64_NETINST.iso
to an USB-disk and booted. The installer starts each time, I can select language, keyboard and timezone - but it fails in all three scenarios looking for the USB disk and drops me into a busybox shell.
The NETINST installer complained about a missing ehci-orion module.
Kindly ask for help in getting devuan installed.
Thanks, -MN
#2 2017-06-07 21:07:27
nick
Re: [SOLVED] Installation on Latte Panda 4G/64GB Intel Cherry Trail Z8300
Sounds like a "unknown" USB 3 port. Does your PC still have a USB 2 port with which you can try to install?
#3 2017-06-08 06:27:13
Morgennebel
Thank you, Nick,
installation succeeded with devuan_jessie_1.0.0_amd64_DVD.iso from USB2.0 port without any issues. UEFI and grub were setup correctly.
Thanks again for the hint,
Ciao, -MN
