#1 2024-08-28 17:10:41
klein
gnuinos-5 gsshaskpass missing
good day
My back ground is arch/arco and deian crunchbang++ 11/12. that may make me dangerious!!
I'm tring to get away from systemd, crunchbang++12 doesn't run as smouth as 11 did installed on the same computer.
i have installed:
gnuinos-5.0.0-daedalus_2024.06.01-ob-runit_amd64.iso
among others
gnuinos seems to be missing a file:
gsshaskpass
looked in the dir:
/usr/bin/gsshaskpass ls -la
bash: /usr/bin/gsshaskpass: No such file or directory
looked for the package with apt:
apt show gsshaskpass
N: Unable to locate package gsshaskpass
E: No packages found
but it is clearly been programed in:
~/.config/openbox/menu.xml
<?xml version="1.0" encoding="utf-8"?>
<openbox_menu xmlns="http://openbox.org/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://openbox.org/                 file:///usr/share/openbox/menu.xsd">
	<menu id="root-menu" label="Openbox 3">
		<separator label="  = ROOT = " icon="/usr/share/icons/Adwaita/16x16/status/dialog-warning.png"/>
		    <item label="Sakura" icon="/usr/share/icons/gnome/16x16/apps/utilities-terminal.png">
				<action name="Execute">
					<execute>sh -c "SUDO_ASKPASS=/usr/bin/gsshaskpass sudo -A sakura"</execute>
				</action>
			</item>
		    <item label="SpaceFM" icon="/usr/share/icons/gnome/16x16/apps/system-file-manager.png">
					<execute>sh -c "SUDO_ASKPASS=/usr/bin/gsshaskpass sudo -A spacefm"</execute>
				</action>
			</item>
		    <item label="Synaptic" icon="/usr/share/pixmaps/synaptic.png">
					<execute>sh -c "SUDO_ASKPASS=/usr/bin/gsshaskpass sudo -A synaptic"</execute>
				</action>
			</item>
		    <item label="Gparted" icon="/usr/share/icons/hicolor/16x16/apps/gparted.png">
					<execute>sh -c "SUDO_ASKPASS=/usr/bin/gsshaskpass sudo -A gparted"</execute>
				</action>
			</item>
	</menu>
</openbox_menu>
is there any way to fix this ?
#2 2024-08-28 22:08:54
Re: gnuinos-5 gsshaskpass missing
Welcome to Dev1.
klein wrote:
... is there any way to fix this ?
Hmm ...
Have you asked at gnuinos about this?
The Devuan Daedalus (stable) repository has a similar package. ie: similar in name and most probably in function.
~$ apt list | grep -i sshaskpass
ksshaskpass/stable 4:5.27.5-2 amd64    # 'k' instead of 'g'
ksshaskpass/stable 4:5.27.5-2 i386     # 'k' instead of 'g'
See here.
pkginfo.devuan.org wrote:
Description-en:
interactively prompt users for a passphrase for ssh-add
A front-end for ssh-add which stores the password
of the ssh-key in KWallet.
But gsshaskpass (as you have found) is not in the Devuan repositories.
Notwithstanding, it can be found here.
It was the only hit I got by looking it up with the Google engine.
Read.me -> Gsshaskpass wrote:
Gsshaskpass
gsshaskpass is a gui dialog for ssh-agent.
To use it set SSH_ASKPASS to the gsshaskpass bin.
export SSH_ASKPASS=~/bin/gsshaskpass
Dependencies
gtk v3.10 or greater.
Does not appear to be a *.deb package, it has to be built from source.
There's one important note at the gnuinos web page which you should be taking into account:
gnuinos.org wrote:
As in the devuan scenario, gnuinos package repositories are exclusive as well, that is to say they
shouldn't be mixed with other apt-based repositories, including Devuan, Debian, Ubuntu and the like.
It would seem that gsshaskpass does more or less the same thing ksshaskpass does but I cannot speculate further.
I'd say the people at gnuinos may have the answer to your question.
#3 2024-08-28 22:25:41
klein
hi altoid
i came up with pretty much the same as you.
how would i get up with gnuinos people, i don't see an email on that sight or any other forum but this one.
#4 2024-08-28 22:46:10
klein
https://dev1galaxy.org/profile.php?id=619
    http://www.gnuinos.org
Email
    aitor_czr@gnuinos.org
think this is him
#5 2024-08-28 23:05:03
klein wrote:
think this is him
Apparently so.
From what I can see his last post was on 2024-07-06, over a month ago.
Drop him an email, he'll show up eventually.
Maybe he's on vacation. (?)
#6 2024-08-28 23:22:05
klein
i just did Altoid thanks
