#1 2024-07-07 17:17:49
mclien
Thunderbird receives more mail, then I end up in my inbox?
after the recent Thunderbird update (not 100% sure if that is the source of the problem) I have some strange behavior tẃith a pop mail account.
I have that account set to only receive messages on demand. Since the update whenever I use the "get messages" button, I see the footer stating something like "receiving x messages of 39" and when it finishes, I end up with significant less messages in my inbox.
I do have 2 filters, which sort messages into 2 sub-folders, but no messages end up there either.
#2 2024-07-09 21:25:33
mknoop
Re: Thunderbird receives more mail, then I end up in my inbox?
Since no one else is commenting, I will just say that I have been getting a similar behavior.  I do not know if it predates the last upgrade
When Thunderbird runs a get message command I sometimes get a message in the status bar at the bottom about messages received, but there are no messages in my inbox or junk folder.  I even tried using the server's web site email access to check if there were messages in the spam folder there, but there are no new ones.
I do not seem to be missing any messages, it is just weird.
#3 2024-07-10 14:31:43
mclien
I did the following: Look up the inbox on the server (webmail interface).
2 new messages.
Then I did run the "get messages" on my clients thunderbird.
Status bar is showing some strange number of messages (20+)
New messages actually in inbox:2
#4 2024-07-11 13:23:36
haven't used thunderbird for years but seem to recall having to do a "complete uninstall" and then reinstall to cure some misbehavior that i cannot exactly remember. also of note, only ever used POP3 and never IMAP.
#5 2024-07-12 06:32:36
mclien
I'm running 8 Mail accounts in the thunderbird and therefore reluctant to uninstall it completely.
As an addition sometimes I "receive" a bunch of mails with none in my inbox at all.
#6 2024-07-12 07:37:16
yohno
Why not try another one like betterbird or epyrus?! I'd recommend epyrus since it is easier to switch by copying Mail sub-directory from thunderbird's stuff.
#7 2024-07-12 08:26:37
re: @yohno's suggestions of betterbird and/or epyrus
out of curiosity i did a bit of poking around and wanted to share for present/future forum/thread visitors
betterbird's current homepage has several interesting comments regarding thunderbird's broken(ness)
ttps://www.betterbird.eu/
enjoyed this circa 2023 thread and epyrus creator athenian200's apparent easy-going/friendly demeanor
ttps://forum.palemoon.org/viewtopic.php?t=30476
#8 2024-07-13 20:14:42
s1mple
I once had a Yahoo Mail account that I accessed with POP3. It showed it had several thousand e-mails instead of the correct number. That might be what is happening. The IMAP/SMTP server reporting a wrong number. I don't know Thunderbird, but it might have a Network Log window like Claws Mail, where you can see the plaintext communication with the server.
