#1 2024-07-07 11:26:29
Micronaut
hddtemp not available in Daedalus
After upgrading a system from Devuan 4 to 5, everything important seems to work, but there is one strange quirk. The hddtemp package is present in the repositories. I can find it with search. But it's not installable. When I try it says "no candidate version found". What does that mean? Anything in the repositories is supposed to be working, not a 'candidate'.
#2 2024-07-07 12:12:19
Re: hddtemp not available in Daedalus
What do you get from:
apt-cache policy hddtemp
#3 2024-07-07 12:46:00
hddtemp has been removed as depracated. Its a pitty, but also a fact.
#4 2024-07-07 13:25:30
Micronaut
hddtemp:
  Installed: (none)
  Candidate: (none)
  Version table:
     0.3-beta15-54 -1
        100 /var/lib/dpkg/status
Why would they remove it? Was it causing some sort of problem? That's really annoying since Gkrellm needs it to read HD temp. Is there a replacement? How difficult would it be to get Gkrellm to use the standard Smartmon interface?
#5 2024-07-07 14:16:22
AFAIK because there is no more maintainer for quite a while.
And no direct replacement.
#6 2024-07-07 16:27:42
If you're lucky, the hard drive reports temperature in degrees centigrade.
smartctl -a /dev/sda | awk '/Temperature/ { print $10 }'
#7 2024-07-07 18:00:44
I'll add my bit.
fsmithred wrote:
What do you get ...
~$ apt-cache policy hddtemp
hddtemp:
  Installed: 0.3-beta15-54
  Candidate: 0.3-beta15-54
  Version table:
 *** 0.3-beta15-54 100
Just to round it out:
~$ uname -a
Linux devuan 6.1.0-22-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.94-1 (2024-06-21) x86_64 GNU/Linux
~$ apt list | grep installed | grep hddtemp
hddtemp/now 0.3-beta15-54 amd64 [installed,local]
fsmithred wrote:
If you're lucky ...
Yep ...
~$ hddtemp /dev/sdc
/dev/sdc: HITACHI HUS153030VLS300: 36 C
Edit:
hddtemp is what provides conky the data for its screen printout in my desktop.
eg:
SATA0: +${execi 60  hddtemp /dev/disk/by-uuid/xxxxxxx-exxb-xcxx-xcxx-xaxcxbafexdx | cut -c 81-86}
#8 2024-07-07 19:32:42
hddtemp=0.3-beta15-54 is the Chimaera version. When you upgrade you may keep it.
#9 2024-07-07 19:44:50
alexkemp
Ah bum (the following is under Daedalus, also with the 6.1.0-22-amd64 kernel:
hddtemp:
  Installed: (none)
  Candidate: (none)
  Version table:
     0.3-beta15-54 -1
$ sudo apt install hddtemp
[sudo] password for alexk:
Package hddtemp is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'hddtemp' has no installation candidate
#10 2024-07-07 21:13:41
rolfie wrote:
... 0.3-beta15-54 is the Chimaera version. When you upgrade ...
I see ...
I had it in Beowulf and upgraded sequencially (ie: via Chimaera) to Daedalus.
@Micronaut
You could try downloading the *deb package from the Chimaera repository and then install it with the Gdebi package installer, apt or dpkg.
See here for the hows and whys.
#11 2024-07-08 01:56:03
soren
Might be a bit of difference with nvme and sata disks. I put a colon next to "Temperature" to get just the main temp, as my nvme drive lists warning and critical temps as well. But yeah this works well, same sort of readout you can get from hddtemp.
sudo smartctl -a /dev/nvme0n1 | awk '/Temperature:/ { print $0 }'
