#1 2024-05-03 09:51:20
sonichy
[SOLVED] Add disk can not boot
#2 2024-05-03 10:50:49
Re: [SOLVED] Add disk can not boot
/dev/sda4 does not exist
First thing to try - Go into bios and change the boot order of the hard disks. That might work.
Maybe a better solution is to unplug the new disk, reboot and edit /etc/fstab to use UUID instead of device names.
#3 2024-05-06 01:26:48
sonichy
/boot/grub/grub.cfg
linux /vmlinuz root=/dev/sda4
Change to:
linux /vmlinuz root=UUID=*
#4 2024-05-06 11:17:46
Check /etc/default/grub to make sure that UUID is not disabled for update-grub. The line should be commented like this:
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
