#1 2024-04-09 09:36:22
devur
grub boot keyboard
hola is there a way to get an onscreen keyboard on the grub boot screen, my keyboard is very slow and logins fail all the time
#2 2024-04-18 17:44:17
Re: grub boot keyboard
what is the model and version of your lenovo laptop?
have you successfully used _any_ other *nix operating system?
which version(s) of Devuan have you tried?
some semi-random webpages that may give some additional thoughts:
ttps://www.forum.mxlinux.org/viewtopic.php?t=70905
ttps://superuser.com/questions/1615364/selecting-entries-in-boot-manager-without-using-keyboard
ttps://unix.stackexchange.com/questions/724678/why-does-grub-fail-to-auto-boot-when-no-keyboard-is-connected
ttps://unix.stackexchange.com/questions/20588/how-to-make-bt-keyboard-available-at-login-and-os-selection-screens
#3 2024-04-20 18:08:55
devur
after looking at the link references in the above comments it does not seem that there is a solution with an on-screen keyboard for grub.  it's not like I can't log in, the fixed keyboard on the labtop is ok for the task, it's different with the external keyboard which isn't precise and fast enough
I think i will conciders this for solved.
