#1 2024-03-29 21:35:48
recklessswing
Windows 10 doesn't get recognized on UEFI bios automatically
I tried os-prober and all. Nothing works. I would write my manual grub entry for windows 10, but I forgot how. I did it before. But why it doesn't work automatically though? On debian it worked?
#2 2024-03-29 23:20:58
manyroads
Re: Windows 10 doesn't get recognized on UEFI bios automatically
Not knowing what your environment is or what you are running or if there are any errors, it is hard to guess.  A simple fix that works in most situations is to run the following command in terminal:
sudo update-grub
You may need to install update-grub
Pax vobiscum,
Mark Rabideau - ManyRoads
i3wm, bspwm, dkwm, dwm, hlwm, sway, openbox on Sid/ ceres ~ Linux #449130
#3 2024-03-30 15:29:46
bai4Iej2need
cat /etc/default/grub
# check for other OS https://www.omgubuntu.co.uk/2021/12/grub-doesnt-detect-windows-linux-distros-fix
GRUB_DISABLE_OS_PROBER=false
must set to false
broken by design :
#4 2024-04-13 23:21:48
recklessswing
I tried all those, it doesn't do it. I had to manually write a grub entry.
