Pages: 1
this is not about devuan builds, but I wondered, x86 has a bios underneath the installed operating system, what does ARM have underneath the installed operating system?
I have been wondering if it has something like a bios where you can disable certain features.
Like for example, I don't like bluetooth because its a massive waste of electricity and its supposedly bad for the environment.
Anyone know?
If you wish to be humbled, try to exalt yourself long term If you wish to be exalted, try to humble yourself long term
Favourite operating systems: Hyperbola Devuan OpenBSD
this is a few years old but still very thought-provoking:
ttps://hackaday.com/2020/08/12/degrees-of-freedom-booting-arm-processors/
enjoy
@stargate-sg1-cheyenne-mtn
Hmm... not so simple then
you might enjoy this presentation:
Nezha RISC-V Linux SBC running debian - via - ExplainingComputers
ttps://www.youtube.com/watch?v=613yEF6SrNo
https://developer.arm.com/documentation … ting-Linux
When the kernel is present in memory, the sequence on an ARM processor based system is similar to what might happen on a desktop computer. However, the bootloading process can be very different, as ARM processor based phones or more deeply embedded devices can lack a hard drive or PC-like BIOS.
Typically, what happens when you power the system on is that hardware specific boot code runs from flash or ROM. This code initializes the system, including any necessary hardware peripheral code and then launches the bootloader (for example U-Boot). This initializes main memory and copies the compressed Linux kernel image into main memory (from a flash device, memory on a board, MMC, host PC or elsewhere). The bootloader passes certain initialization parameters to the kernel. The Linux kernel then decompresses itself and initializes its data structures and running user processes, before starting the command shell environment. Let's take a more detailed look at each of those processes.
Maybe you could adjust your bootloader settings to achieve whatever goal you're looking for?
Also a good thread: https://www.reddit.com/r/arm/comments/9 … nd_a_bios/
You might also enjoy this book: https://www.wiley.com/en-us/Blue+Fox%3A … 1119745303
@siva I guess I could do that, not sure how, but its worth a try.
Pages: 1
