#1 2023-12-12 10:05:12
holala
Updating kernel (Raspberry pi 2)
Hello. I want to use wireguard with my raspberry pi.
Installing the wireguard package requires another kernel - 6.1.0-14-rt-armmp.
I installed it and removed the current 6.1.64 kernel. However
uname -r
stil returns 6.1.64.
After some research I found that the actual booted kernel is the one in
/boot/broadcom/kernel7.img
. I believe that apt doesn't generate this specific img file (it generates the initramfs files though...).
I wonder how to generate the kernel7.img file without building custom kernel myself? Probably from the initrd.gz file? Or just putting vmlinuz-6.1.0-14-rt-armmp as kernel7.img ?
Otherwise I find these instructions proper for the task: https://www.raspberrypi.com/documentati … ernel.html
#2 2024-03-28 18:23:57
EnglishMohican
Re: Updating kernel (Raspberry pi 2)
I am not convinced that adopting the .armmp kernel is your best course.
Please see https://dev1galaxy.org/viewtopic.php?id=5255 where I  posed a similar question. I will let you read that thread and judge whether your situation is the same.
Wireguard works well with both the .armmp kernel and the kernel optimised for RPi.
I concluded it was better to stick with the optimised kernel but it may be horses for courses!
