#1 2023-11-17 06:10:54
Danielsan
Dropbear-initramfs: criptroot-unlock: another workaround
Dear Devuanized
based on a friend of mine, that happens to be also an OpenBSD dev, I got a tip to make the script criptroot-unlock working!
As others already spotted out, the issue is in this block:
Original block
if [ ! -f "$TABFILE" ] || [ "$TABFILE" -ot "/proc/1" ]; then
	# Too early, init-top/cryptroot hasn't finished yet
	echo "Try again later" >&2
	exit 1
fi
My friend took a look briefly and suggested me to remove this section: || [ "$TABFILE" -ot "/proc/1" ]
And it actually worked! With the options -p 222 -c cryptroot-unlock in /etc/dropbear/initramfs/dropbear.conf, when you connect through SSH it will ask directly the passphrase:
Modified block
if [ ! -f "$TABFILE" ] ; then
	exit 1
fi
The script is located in:
/usr/share/cryptsetup/initramfs/bin/cryptroot-unlock
#2 2024-01-07 10:20:59
tux2bsd
Re: Dropbear-initramfs: criptroot-unlock: another workaround
https://dev1galaxy.org/viewtopic.php?pid=46093#p46093
