#1 2023-11-12 22:26:27
oui
[solved] more columns in PCmanFM, Thunar, oder Nemo detailled lists.
For ex. the column «owner»
how to reinsert it?
#2 2023-11-20 09:39:00
Defender
Re: [solved] more columns in PCmanFM, Thunar, oder Nemo detailled lists.
In Thunar you right click on one of the column headings and it gives you an option to Configure Columns.  Owner is at the bottom of the list.  Make sure it is checked.
#3 2023-11-22 18:28:09
oui
thank you very much!
