#1 2023-10-06 08:50:46
Gnumeric Logic problem
I've got to evaluate the strings of weekdays in Gnumeric- Mon, Tue, Wed, Thurs.... - and IF it is Sat OR Sun the result should be "0" or else it should be "1".
This far is OK; =if(B279<>"Sat";"1";"0") it prints "0" for true and "1" for false .
But this does not work: =ifs(B280<>"Sun";"0";B280<>"Sat";"0";B280<>"Mon";"1") it prints "0" every time. (Note IFS function)
It's a work schedule and it's keeping track of my days worked, hours, salary and stuff for each month. The week days are listed in a column.
Sorry to bother you all with this, but googling gives Excel and VBA hits that don't tell me much. Gnumeric man pages just gives me bare basics.
PS I'm not a student!!!!!
#2 2023-10-06 12:40:48
boughtonp
Re: Gnumeric Logic problem
So why are you not doing exactly what you said?
i.e. Using OR and testing that the cell is Sat or that the cell is Sun, rather than over-complicating things with inequality!?
Except you probably don't even need to do this manually...
There are already functions to work with WORKDAYs, or to tell you the NET WORKDAYS - i.e. the number of workdays in a range, remembering that a range can have a length of one, if that is actually necessary.
3.1415P265E589T932E846R64338
#3 2023-10-25 12:29:06
Finally my two brain cells got it! Thank you!
=if(or(B281="Sat";B281="Sun");"0";"1")
(Sry for the very late answer)
