I own a usb infnoise TRNG device and had the idea of using it with devuan. I was surprised to see there is a package for it (infnoise_0.3.3%2bdfsg-1_amd64.deb) for my architecture in daedalus.
Fortunately I tried to use it before on a chimera installed box and had to intstall the software manually.
The maintainer for this package is stated as skitt@debian.org.
But I dare to doubt that he placed that (on first sight very nice) sysV startup file /etc/init.d /infnoise there .
From my point of view that init.d file badly needs a.
--- infnoise 2023-10-03 18:18:39.908014899 +0000
+++ infnoise.orig 2023-10-04 07:48:39.115944604 +0000
@@ -23,11 +23,6 @@
set -e
-if [ -e /etc/infnoise.conf ]; then
- . /etc/infnoise.conf
-fi
case "$1" in
status)
status_of_proc $DAEMON $NAMEto source the /etc/infnoise.conf file for sourcing the environment variables that the binary needs for proper working.
Imho
INFNOISE_SERIAL=DO0032ZAwith the correct serial number of the device should be set for the infnoise binary to work properly.
(The TRNG device user can read that number from the labels printed on that device or read it with infnoise --list-devices. )
Another issue that puzzled me - was the content of the file /lib/udev/rules.d/60-infnoise.rules .
The second line
ACTION=="add", SUBSYSTEM=="usb", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6015" ,TAG+="systemd", ENV{SYSTEMD_WANTS}="infnoise.service"does what I would have expected it to do in Devuan - nothing.
I changed it for
ACTION=="add", SUBSYSTEM=="usb", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6015", OPTIONS:="nowatch", RUN+="/etc/init.d/infnoise start"and it starts the infnoise binary as it is supposed to do - when inserting the TRNG usb device.
(As a side effect this hack temporarily generates a "[infnoise] <defunct>" init.d process - which (to me mysteriously) gets killed after some time.)
Imho there is legacy files contained in that package too.
I have no clue what the file /lib/systemd/system/infnoise.service is good for - in that package.
Also to help inexperienced users to run that device there should be a mentioning of adding the serial number to /etc/infnoise.conf in the man pages.
Jan
