#1 2023-09-24 12:34:46
mirrortokyo
[SOLVED] Konsole 4:23.08.1-1 in unstable
In Konsole 4:23.08.1-1 I lost the menubar and tabs moved from bottom to top of screen.
Thanks to the Debian maintainer I was given the instructions:
Use Control-Shift-M to toggle display of the menubar;
and under settings / configure konsole / tab bar/splitters tab position can be selected to be below terminal area.
