#1 2023-04-14 16:55:50
SpongeBOB
[SOLVED] How to Install the latest version of Python ?
Hi everyone,
How can I install the latest version of python (3.11.3 at this date) on Chimaera 4.0 ?
Thanks.
#2 2023-04-14 16:58:35
SpongeBOB
Re: [SOLVED] How to Install the latest version of Python ?
I've found this --> https://aruljohn.com/blog/install-pytho … on--source
is this ok for Devuan too ?
BTW I changed
sudo make altinstall
by
sudo make install
#3 2023-04-15 02:51:57
rbit
That page looks okay, but it is for python 3.11.1, not 3.11.3.  The 3.11.3 source can be downloaded here https://www.python.org/ftp/python/3.11. … 3.11.3.tgz.  The build/install process should work the same in devuan as in debian.
If you want a slightly smaller download, the xz-compressed source can be downloaded here https://www.python.org/ftp/python/3.11. … 1.3.tar.xz.
Here, just change the first section of that blog page to this:
cd /tmp/
wget https://www.python.org/ftp/python/3.11.3/Python-3.11.3.tar.xz
tar -xvf Python-3.11.3.tar.xz
cd Python-3.11.3/
I believe all the rest should be the same.
#4 2023-04-15 06:16:45
SpongeBOB
Thank you @rbit,
btw for future reader, after the upgraded
python -V
was still giving my previous version, but just relaunching the terminal was giving the one just installed.
Cheers.
