#1 2023-04-10 19:08:37
mclien
[solved] thinkcentre radeon r2 only 480x640 resolution
I used the Devuan live version (chomera) on that machine, bios states it is:
AMD E2-9000e Radeon r2.
The settings-display tool let me change nothing, firmware-amd-graphics is installed.
EDIT: bad DP to DVI adapter.
#2 2023-04-11 10:18:57
PedroReina
Re: [solved] thinkcentre radeon r2 only 480x640 resolution
Could we see the output of xrandr?
