#1 2017-04-22 20:24:35
millpond
Updates
On my 32 bit system I found to dismay that the system was downloading updates and filling up the cache directory.
I have auto-updates turned OFF here:
/etc/apt/apt.conf.d/10periodic.
has:
APT::Periodic::Unattended-Upgrade "0";
Is there a way to prevent this totally?
I do not want *anything* updating or downloading without my express permission.
#2 2017-04-23 02:09:29
Richard
Re: Updates
Check out fsmithred's post, https://dev1galaxy.org/viewtopic.php?id=32
to see if it is relevant to your problem.
#3 2017-04-23 04:15:52
nathg
Re: Updates
Uninstall ' unattended-upgrades' if installed. Another way try with  " #  APT::Periodic::Unattended-Upgrade "0"; "
#4 2017-04-23 12:55:49
FOSSuser
Re: Updates
millpond wrote:
........I do not want *anything* updating or downloading without my express permission.
That _should_ be the default on all systems.
#5 2017-04-23 14:21:53
rufwoof
Re: Updates
I downloaded yesterday and Unattended updates isn't installed (by default)
