#1 2023-01-21 23:31:17
dcolburn
Web server - a setting off somewhere ...
I'm not getting nginx errors and I can ping 127.0.0.1 and 192.168.50.3 from the server.
I can ping 192.168.50.3 from another computer on the same network.
I cannot ping 192.168.50.4 (for which I have a prior note that it may be the nginx internal ip)
I also can't access realupnow.com
Looking at the following is there anything obvious which I have incorrectly configured, please?
This is nginx.conf
user www-data;
error_log logs/error.log notice;
worker_processes auto;
pid /run/nginx.pid;
load_module modules/ndk_http_module.so;
load_module modules/ngx_http_lua_module.so;
# include conf.d/http;
# include conf.d/stream;
# include conf.d/exchange-enhanced;
events {
	worker_connections 768;
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	types_hash_max_size 2048;
	# server_tokens off;
	# server_names_hash_bucket_size 64;
	# server_name_in_redirect off;
	include /etc/nginx/mime.types;
	default_type application/octet-stream;
	# SSL Settings
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
	ssl_prefer_server_ciphers on;
	# Logging Settings
	access_log /var/log/nginx/access.log;
	error_log /var/log/nginx/error.log;
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
	# gzip_comp_level 6;
	# gzip_buffers 16 8k;
	# gzip_http_version 1.1;
	# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
	# Virtual Host Configs
	include /etc/nginx/conf.d/*.conf;
	include /etc/nginx/sites-enabled/*;
#mail {
#	# See sample authentication script at:
#	# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#	# auth_http localhost/auth.php;
#	# pop3_capabilities "TOP" "USER";
#	# imap_capabilities "IMAP4rev1" "UIDPLUS";
#	server {
#		listen     localhost:110;
#		protocol   pop3;
#		proxy      on;
#	server {
#		listen     localhost:143;
#		protocol   imap;
#		proxy      on;
EDIT: realupnow.com in sites-available updated with corrections ...
This is realupnow.com  in /etc/nginx/sites-available and symlinked to sites-enabled
# Virtual Host configuration for realupnow.com
# Be sure to symlink this to ~/sites-enabled/ to enable it.
# sudo ln -s /etc/nginx/sites-available/realupnow.com /etc/nginx/sites-enabled/realupnow.com
server {
    listen 80;
#    root /var/www/realupnow.com;
    root /var/www/html;
    index index.php index.html index.htm index.nginx-debian.html;
    server_name realupnow.com www.realupnow.com;
#    root /var/www/html/domain.com/public_html;
    listen 443 ssl;
	location / {
		try_files $uri $uri/ =404;
	# pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
	location ~ \.php$ {
		include snippets/fastcgi-php.conf;
		fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
    # RSA certificate
    ssl_certificate /etc/letsencrypt/live/realupnow.com/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/realupnow.com/privkey.pem;
    ssl_dhparam /etc/ssl/certs/dhparam.pem;
	include /etc/letsencrypt/options-ssl-nginx.conf;
    # Redirect non-https traffic to https
    if ($scheme != "https") {
        return 301 https://$host$request_uri;
This is etc/hosts
127.0.0.1	localhost
127.0.1.1	devuan1.realupnow.com	devuan1
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
/var/www/html contains two files index.nginx-debian.html and info.php
#2 2023-01-22 22:54:44
dcolburn
Re: Web server - a setting off somewhere ...
Anything in either of these flag a problem?
root@devuan1:/etc/nginx# sudo netstat -plutn | grep nginx
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      4991/nginx: master
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      4991/nginx: master
nftables.conf
# !/usr/sbin/nft -f
flush ruleset
# table inet filter {
#	chain input {
#		type filter hook input priority 0;
#	chain forward {
#		type filter hook forward priority 0;
#	chain output {
#		type filter hook output priority 0;
table inet firewall {
	chain_inbound ipv4 {
	icmp type echo-request limit rate 5/second accept
    chain inbound {
        type filter hook input priority filter; policy drop;
        ct state established,related accept
        ct state invalid drop
        iif "lo" counter packets accept
        ip protocol icmp accept
        ip6 nexthdr ipv6-icmp accept
        ip protocol igmp accept
#        iif "lo" counter packets 0 bytes 0 accept
#        ip protocol icmp limit rate 4/second accept
#        ip6 nexthdr ipv6-icmp limit rate 4/second accept
#        ip protocol igmp limit rate 4/second accept
        tcp dport { 22, 80, 443 accept
        log
    chain FORWARD {
        type filter hook forward priority filter; policy drop;
    chain OUTBOUND {
       type filter hook output priority filter; policy drop;
       # Allow traffic from established and related packets, drop invalid
            ct state vmap { established : accept, related : accept, invalid : drop }
       # Allow loopback
            oif "lo" accept
       # Accepted ports out (DNS / DHCP / TIME / WEB for package updates / SMTP)
            ct state new tcp dport {22, 80, 443} accept
            log prefix "DROP_output: " limit rate 3/second
#3 2023-01-23 01:22:52
dcolburn
Does the absence of a url in this output mean something isn't working?
Any suggestions as to where to look?
[Context: Devuan nginx php-fpm nftables]
root@devuan1:/etc# netstat -l
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:http            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN
tcp        0      0 localhost:ipp           0.0.0.0:*               LISTEN
tcp        0      0 localhost:smtp          0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:https           0.0.0.0:*               LISTEN
tcp        0      0 localhost:4101          0.0.0.0:*               LISTEN
tcp6       0      0 [::]:ssh                [::]:*                  LISTEN
tcp6       0      0 localhost:ipp           [::]:*                  LISTEN
tcp6       0      0 localhost:smtp          [::]:*                  LISTEN
tcp6       0      0 localhost:4101          [::]:*                  LISTEN
tcp6       0      0 [::]:sane-port          [::]:*                  LISTEN
udp        0      0 0.0.0.0:631             0.0.0.0:*
udp        0      0 0.0.0.0:mdns            0.0.0.0:*
udp        0      0 0.0.0.0:42163           0.0.0.0:*
udp6       0      0 [::]:mdns               [::]:*
udp6       0      0 [::]:52198              [::]:*
raw6       0      0 [::]:ipv6-icmp          [::]:*                  7
#4 2023-01-23 07:22:13
xinomilo
Unknown
looks like network issue. http/https ports are filtered, not accessible from outside.
could be router/ISP or firewall issue. ping seems to work ok, but ports 22,80,443,631 look filtered.
so, resolve network issues first... then look at web server for possible issues... (might be fine just as is).
#5 2023-01-23 15:01:51
dcolburn
OK. I have internal working - when I run realupnow.com I get https://realupnow.com and the default nginx welcome page displays.
If I try to force realupnow.com/index.html or info.php I get 404 Not Found
If I try from a different computer, on the same network, I get ...
Unable to connect
An error occurred during a connection to www.realupnow.com
I'll have a look at the router - I haven't changed anything on it since this was working a few weeks ago ...
#6 2023-01-23 17:16:41
Having a quick look from outside:
$ host www.realupnow.com
www.realupnow.com has address 66.172.90.106
$ ping www.realupnow.com
PING www.realupnow.com (66.172.90.106) 56(84) bytes of data.
64 bytes from 66.172.90.106: icmp_seq=1 ttl=47 time=110 ms
64 bytes from 66.172.90.106: icmp_seq=2 ttl=47 time=109 ms
$ sudo traceroute -T www.realupnow.com
traceroute to www.realupnow.com (66.172.90.106), 30 hops max, 60 byte packets
<snip>
13  168.182.127.17 (168.182.127.17)  114.734 ms  118.489 ms  116.881 ms
14  168.182.127.1 (168.182.127.1)  110.179 ms  110.515 ms  113.517 ms
15  168.182.127.98 (168.182.127.98)  118.143 ms  116.080 ms  117.728 ms
16  66.172.90.106 (66.172.90.106)  115.229 ms  109.814 ms  111.151 ms
17  66.172.90.106 (66.172.90.106)  3117.564 ms !H  3111.648 ms !H  3109.469 ms !H
But I can't tell what 66.172.90.106 is. Could that be your router's external IP address? Or the server's external IP address?
NB. traceroute -T uses a SYN packet as it's probe, to port 80 by default.
#7 2023-01-23 17:44:38
dcolburn
I can SSH in.
Might I have a nftables problem?
I think this is supposed to show nf_tables_inet, nf_tables_ipv6, nf_tables_ipv4, nf_netlink, nf_chain ...
root@devuan1:~# lsmod | grep nf_tables
nf_tables             253952  0
libcrc32c              16384  1 nf_tables
nfnetlink              20480  1 nf_tables
root@devuan1:~#
#8 2023-01-23 20:56:48
dcolburn
That's my WAN IP/static IP address.
EDIT 1:
So, Traceroute gets to the WAN IP, and using SSH I can log into the server 192.168.50.3.
What, specifically (I'm hoping someone has a checklist for troubleshooting), would prevent connecting via html?
EDIT 2:
I can see /var/www/html/index.html via a browser on the server http://www.realupnow.com but not my laptop, on the same network.
EDIT 3:
Looking at the Answer halfway down this page https://unix.stackexchange.com/question … -nat-table might installing and using conntrack to reset things be advised (since I'm using nftables and I've copied over some things from my prior working setup)?
#9 2023-01-26 03:50:01
rbit
A few questions, to help figure out where the problem lies...
The local-network address of the webserver is 192.168.50.3 ?
If so, can another computer on the network successfully open the site http://192.168.50.3/?  It does appear that your web-server is listening for connections, but if this step isn't working then you may have a firewall that is blocking the connection.  So... do you have a software firewall (such as ufw) installed?  You may need to configure it to allow incoming traffic on ports 80 and 443.
Also, are you behind a NAT/router?  If so, you'll probably need to set up port forwarding for TCP ports 80 and 443, if you haven't done so already.  This would make your webserver accessible to the outside internet (http://www.realupnow.com).  The process to do this varies, but it should be found somewhere on your router's admin page.
