#1 2022-12-16 18:03:52
[SOLVED] Five-or-more pinning to older version
Daedalus with Cinnamon DE.
The counting of results of the game five-or-more is broken since Chimaera, and hasn't been fixed in Daedalus. I removed the package from the installation, downloaded the older version five-or-more_3.30.0-2_amd64.deb from Beowulf and installed it with dpkg -i. I think I had to install an additional dependency. The older program is working.
To keep the package, I added a file five-or-more to /etc/apt/preferences.d with the contents:
Package: five-or-more
Pin: version 3.30.0*
Pin-Priority: 1001
When I run an apt update this setting is ignored, I still get the version 3.32.3 listed as installation candidate.
What is wrong in my setup? Why is the preference ignored? Shouldn't I see the setting immediately in apt-cache policy?
#2 2022-12-16 18:07:40
Re: [SOLVED] Five-or-more pinning to older version
Can we see
apt policy
apt policy five-or-more
Thanks!
#3 2022-12-16 18:14:30
# apt policy
Paketdateien:
 100 /var/lib/dpkg/status
     release a=now
 500 http://deb.devuan.org/merged daedalus/non-free i386 Packages
     release v=5.0,o=Devuan,a=testing,n=daedalus,l=Devuan,c=non-free,b=i386
     origin deb.devuan.org
 500 http://deb.devuan.org/merged daedalus/non-free amd64 Packages
     release v=5.0,o=Devuan,a=testing,n=daedalus,l=Devuan,c=non-free,b=amd64
 500 http://deb.devuan.org/merged daedalus/contrib i386 Packages
     release v=5.0,o=Devuan,a=testing,n=daedalus,l=Devuan,c=contrib,b=i386
 500 http://deb.devuan.org/merged daedalus/contrib amd64 Packages
     release v=5.0,o=Devuan,a=testing,n=daedalus,l=Devuan,c=contrib,b=amd64
 500 http://deb.devuan.org/merged daedalus/main i386 Packages
     release v=5.0,o=Devuan,a=testing,n=daedalus,l=Devuan,c=main,b=i386
 500 http://deb.devuan.org/merged daedalus/main amd64 Packages
     release v=5.0,o=Devuan,a=testing,n=daedalus,l=Devuan,c=main,b=amd64
Mit Pinning verwaltete Pakete:
# apt policy five-or-more
five-or-more:
  Installiert:           1:3.30.0-2
  Installationskandidat: 1:3.32.3-1
  Versionstabelle:
     1:3.32.3-1 500
 *** 1:3.30.0-2 100
#4 2022-12-16 18:16:01
You forgot to add the epoch:
Package: five-or-more*
Pin: version 1:3.30.0*
Pin-Priority: 1001
Tested and works for me.
EDIT: added asterisk after package name to cover multi-arch systems.
#5 2022-12-16 18:37:41
Why is this "1:" you call it epoch required? Well it works this way.
I scanned through the man apt_preferences, the Ubuntu wiki article, and other in the internet before posting here, didn't see that in the examples given ....
#6 2022-12-16 18:43:05
The epoch is part of the version string. See also https://www.debian.org/doc/debian-polic … ml#version.
#7 2022-12-16 18:49:43
Well, don't fully understand the reasoning. The filename did not include the epoch, and I used that info for the pref file. The epoch is present in Synpatic and when you look closely to the printout of apt policy, but I never thought it would be important, based on the examples I saw.
So far so bad, its solved. Again what learned ....
